查看: 4645|回复: 5
Where to set the molecular weight for the solid phase?
发表于 2002-5-9 01:13:00 | 显示全部楼层 |阅读模式
I am trying to simulate a 2-phase flow. One phase is gas, the other is solid particulates. But the *.fc file failed to be run by the CFX solver. The generated *.fo file keeps telling me fhe following,
####> ERROR. IN DATA FOR PHASE      2
THE MOLECULAR WEIGHT =  -1.0000E+00 THIS MUST BE SET BY THE USER AND HAVE A VALUE GREATER THAN 0.0
THE CFX-4 SOLVER HAS BEEN STOPPED BY SUBROUTINE SPEC1
Can anyone please tell me where I am supposed to set the molecular weight for the solid phase? Thanks in advance.
发表于 2002-5-9 05:08:34 | 显示全部楼层
我正在做一些混合流动的问题,没有两相的问题,但是里面也有多成分的定义问题.
有关的定义是这样做的:
>>CFX4
>>OPTIONS
    MASS FRACTION EQUATIONS 1 /* 设定设计传质的组分数目 */
    MAXIMUM NUMBER OF MATERIAL TYPES 1
>> VARIABLE NAMES
    MASS FRACTION1 "H2"
>> MODEL DATA
  >> PHYSICAL PROPERTIES
   >> MASS TRANSFER PARAMETERS
     >>MOLECULAR WEIGHTS
       H2 2.0     /*  组分分子量 */
 楼主| 发表于 2002-5-10 05:59:31 | 显示全部楼层
Windhair, thanks for your information.
I am aware of the command lines you wrote, which is about the case of Multi-component flow. My question is if I am to model a multi-phase single-component flow, where am I supposed to set the parameters (e.g. molecular weight, thermal diffusivity,etc.)for a specific phase, especially a solid phase, the physical properties of which are not provided in the PCP database of CFX program.
发表于 2002-5-10 06:28:53 | 显示全部楼层
我没有做过multi-phase 的计算,不过我在手册里面查到一些设置方法,看看有没有用.
>>MODEL DATA
  >>HYSICAL PROPERTIES
    >>FLUID PARAMETERS
      PHASE NAME 'PHASE1'
      VISCOSITY 1.0E-5
      DENSITY 1.0
    >>FLUID PARAMETERS
      PHASE NAME 'PHASE2'
      VISCOSITY 1.0E-3
      DENSITY 1.0E+3
    >>HEAT TRANSFER PARAMETERS
      PHASE NAME 'PHASE1'
      THERMAL CONDUCTIVITY 1.0E-2
      FLUID SPECIFIC HEAT 1.0E+3
      PHASE NAME 'PHASE2'
   >>MASS TRANSFER PARAMETERS
     >>DIFFUSIVITIES
      PHASE NAME 'PHASE1'
      DIFFUSIVITIES 1E-05
     >>MOLECULAR WEIGHTS
      PHASE NAME 'PHASE1'
      MOLECULAR 23.0
     >>DIFFUSIVITIES
      PHASE NAME 'PHASE2'
      DIFFUSIVITIES 2E-05
     >>MOLECULAR WEIGHTS
      PHASE NAME 'PHASE2'
      MOLECULAR 38.0
发表于 2002-5-21 11:11:14 | 显示全部楼层
我觉得你试试检查一下,两相的体积分数是否加起来为1.0。
发表于 2002-7-12 21:12:26 | 显示全部楼层
That is a example, not real parameters
