查看: 2949|回复: 2
[求助]有关CFX-TASCFLOW 2.12按装问题
发表于 2003-6-19 14:43:26 | 显示全部楼层 |阅读模式
[求助]我按照以下的内容在WINDOW XP中按装CFX-TASCFLOW 2.12,出现
License check has failed.
Stop-Program terminated.
请各位前辈指点,license.dat如附件,帮忙修改或e-mail一个新的license,谢谢。
E-mail:k2836103@ms28.hinet.net
按装内容:
CFX-TASCflow v2.12.01 (NT/2000/XP)
Note: You should use the XP install for  NT/2000/XP
      if you have Exceed 7.1 or later and have a P4
      based computer.
Requirements for NT/2000:
a) Exceed and Exceed 3D v6.1 for NT and 6.2 for
   Windows 2000.
b) Optional: Visual Fortran v5.0
Requirements for XP (2000/NT with the following
3rd party software on newer P4 based systems):
a) Exceed and Exceed 3D v7.1 or later
b) Optional: Visual Fortran v6.0
1. Install Exceed and Exceed 3D then reboot.You should Refer
   to the installation documentation "rimer.pdf" in the crack
   directory before proceeding with the rest of the installations.
2. Install CFX-TASCflow.
3. Copy the license.dat to E.g. C:\CFX\TASCflow\02.12.01\Misc
   \license\WinNT. Open the license.dat and change "host" on
   the first line to your computer name. Edit "C:\CFX\TASCflow
   \02.12.01\Misc\license\WinNT\CFXd.exe" on the second line
   to your installed path (don't change the CFXd.exe).
4. Manually install flexlm services using the flexlm applet. Start
   Flexlm services.
5. Set the license environment:
   LM_LICENSE_FILE = 9151@host (host is you computer name)
6. Run the program.
发表于 2003-6-21 09:50:30 | 显示全部楼层
你在那里搞到的TASCFLOW2.12.
发表于 2003-12-2 13:03:45 | 显示全部楼层
你在那里搞到的TASCFLOW2.12
