查看: 3050|回复: 3
[求助]用CFX计算降落伞气动力怎么弄啊?
发表于 2007-5-31 12:37:55 | 显示全部楼层 |阅读模式
哪位高手知道怎么用CFX计算降落伞气动力啊?有没有从ICEM到CFX的具体步骤?谢谢。
发表于 2007-8-7 08:19:44 | 显示全部楼层
first, u should know what physical model will be used, whether u consider the FSI effects, if not considering that, the model is assumed to be rigid, second what turbulence model will be adopted, generally u should use the K-E model to see the result, if ur turbulence model and mesh grids is realiable, u can use the SST model to simualte it, but for FSI the problems are more complicated and complex, before u simulate the model, the most important is that the mesh model, u should get the fine grid geometry model
发表于 2007-8-13 10:43:15 | 显示全部楼层
楼上的朋友能用中文不
偶不大懂外国字
发表于 2009-4-9 10:25:27 | 显示全部楼层
见过国外使用lsdyna计算降落伞的问题,是FSI问题,而且降落伞要考虑透气性,否则误差大。
你可搜索fsi irvin lsdyna关键词。
较难的,呵呵!
