查看: 4276|回复: 2
多相流中间保存时计算失败
发表于 2007-6-19 09:34:30 | 显示全部楼层 |阅读模式
在多相流计算过程中出现如问题,请指教,谢谢各位
| Writing backup file 600_full.bak                                   |
|   Name   : Backup Results 1                                        |
|   Type   : Standard                                                |
|   Option : Iteration Interval                                      |
  Fatal bounds error detected
  Variable: cat | gas.Drag Coefficient
  Locale  : Domain 1
|                    Writing crash recovery file                     |
Details of error:-
Error detected by routine MAKDAT
CDANAM =  LVAR CDTYPE =  INTR ISIZE =  160
CRESLT = OLD
Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX  |
| solver have been saved in the directory                            |
| F:\cfd\tl284\tl4m_014:                         |
| 600_full.bak, 400_full.bak                                         |
| Error reported by IO module: iocntc: offset array input is wrong   |
| Error from IO module while getting dataset list for                |
| F:\cfd\tl284\tl4m_014.dir\crash:               |
|  "iocntc: offset array input is wrong"                             |
| IO_MEMORY_ERR(14): Not enough allocated memory for requested IO    |
| operation.                                                         |
| Unable to retrieve crash from working directory: Cannot move to    |
| F:\cfd\tl284\tl4m_014.res.err: Permission      |
| denied                                                             |
|                              Warning!                              |
| The ANSYS CFX Solver has written a crash recovery file, but an     |
| error occurred while trying to save the file.  The working         |
| directory                                                          |
|   F:\cfd\tl284\tl4m_014.dir                   |
| will not be deleted: please tidy up and remove this directory      |
| manually.  Note that a lock file was left for the crash file when  |
| the solver exited, and so it is probably incomplete.               |
[br][br][以下内容由 zh160 在 2007年06月19日 09:39am 时添加] [br]
计算过程只要保存两次中间结果,计算计算就会停止,不知何原因
发表于 2007-6-19 10:36:07 | 显示全部楼层
多相流中间保存时计算失败
检查一下F 盘下还有没有足够的空间试试
 楼主| 发表于 2007-6-22 15:02:28 | 显示全部楼层
多相流中间保存时计算失败
谢谢chjuan。
最近计算来出现类似问题,硬盘空间足够大,不是硬盘空间问题
