查看: 2274|回复: 0
求助:cfx5solver 运行错误
发表于 2007-8-17 00:11:11 | 显示全部楼层 |阅读模式
ANSYS11,安装都很顺利,用的是破解软件,本机做License Server,License中的HostName已改为计算机名,网卡号也是对的。其他软件如ICEM都可以运行,只是在用CFX Slover计算时出现了以下错误,各位看看有没有办法解决?小弟拜谢!
|                An error has occurred in cfx5solve:                 |
| Remote connection to lijia was interrupted by signal HUP (1)  It   |
| gave the following output:                                         |
|    ';d:\mplay.com'; 不是内部或外部命令,也不是可运行的程序           |
|    或批处理文件                                                    |
|    TRUE                                                            |
| Check that you have typed the hostname correctly, that you have an |
| account "LiJia" on the specified host with permission to rsh from  |
| this host, and that (particularly for Windows hosts) it is running |
| an rsh daemon.  You can use the following command to check the     |
| connection to a UNIX machine:                                      |
|   rsh lijia uname                                                  |
| or the following command if it is a Windows machine:               |
|   rsh lijia cmd /c echo working                                    |
