查看: 8481|回复: 3
[求助]SYM不是平行面设置的问题
发表于 2007-12-20 17:50:44 | 显示全部楼层 |阅读模式
我在做3D pipejunction 例题的时候画好了网格,前期准备工作按教程用ICEM CFD都完成了,自己想尝试用CFX试算,在计算中报错如下,请教各位大侠该如何解决?!!
谢谢!!
| ERROR #002100013 has occurred in subroutine Chk_Splane.            |
| The symmetry boundary condition requires that the boundary patch   |
| mesh faces form a plane or axis.  However, face set   5 in the     |
| symmetry boundary patch                                            |
|  SYM                                                               |
| is not in a strict plane, which means that at least one of its     |
| faces is not parallel to the others.  To make the solver run       |
| you can do one of the following:                                   |
|  (1) Make sure that this symmetry boundary patch is in a plane or  |
|      axis by checking and regenerating the mesh.                   |
|  (2) If the symmetry boundary patch is an axis rather than a       |
|      plane, change the tolerance of the degeneracy check by        |
|      increasing the value of the Solver Expert Parameter           |
|      ';degeneracy check tolerance'; (the default value is 1.e-4).    |
|  (3) Increase the value of the Solver Expert Parameter             |
|      ';vector parallel tolerance'; (the default value is 1 deg.).    |
|      Note that the accuracy of the symmetry condition may decrease |
|      as the tolerance is increased.  This is because the tolerance |
|      is the number of degrees that a mesh face normal is allowed   |
|      to deviate from the average normal for the entire face set.   |
[br][br][以下内容由 liangxia 在 2007年12月20日 05:51pm 时添加] [br]
不知道在哪里能找到';vector parallel tolerance'; 。[br][br][以下内容由 liangxia 在 2007年12月20日 05:51pm 时添加] [br]
发表于 2007-12-26 16:08:30 | 显示全部楼层
[求助]SYM不是平行面设置的问题
你可能在创建几何或划分网格时没注意,有的地方出现了误差,积累起来造成这个问题。
你可以在CFX-POST中检查这个问题。
要设定';vector parallel tolerance'; 需要用到CFX的高级参数模式,GUI里是没有的。
发表于 2011-8-14 09:47:33 | 显示全部楼层
有人说修改路径是
Create > expert objects>expert parameter > Discretisation ->last one
请问在哪里操作啊?一直没研究出来,遇到这个问题,解决不了
发表于 2017-2-18 15:57:53 | 显示全部楼层
The symmetry boundary condition requires that the boundary patch  mesh faces form a plane or axis.  However, face set   7 in the    symmetry boundary patch。我也遇到了这个问题,请问楼主是怎么解决的,谢谢啦
