查看: 2909|回复: 2
[求助]关于一个复杂体型的网格划分问题
发表于 2003-11-12 14:37:18 | 显示全部楼层 |阅读模式
 楼主| 发表于 2003-11-12 15:07:12 | 显示全部楼层
[求助]关于一个复杂体型的网格划分问题
错误信息:
initialization failed:perturb boundary nodes and try again.
intialization failed to mesh 79 nodes
error:TG_mesh_Domain failed with error code1.
error:Tetrahedral_meshing has failed for volume v_volumne.1
This is usually caused by problems in the face meshe. Check the skewness of your face meshs and make sure the face mesh sizes are not too large in  areas of small gaps.
我不知道该怎么解决好,请大家帮帮忙,谢谢
发表于 2003-11-14 00:53:48 | 显示全部楼层
[求助]关于一个复杂体型的网格划分问题
[这个贴子最后由windhair在 2003/11/14 01:01am 第 1 次编辑]
I do not know how this software will deal with such problem. From the error message, we can see that it is caused by the un-proper surface grid size. Prof. Yang Zhasheng or Huang Mingque (sorry, I do not remember which prof, because both of them are expert about generation of unstructured grid) from Nan hang has wrote a paper about how to deal with the problem of grid penetration if the surface grid size it larger than the distance between surface points.
