查看: 5764|回复: 4
Icem cfd的solidworks DCI问题
发表于 2004-11-23 15:52:30 | 显示全部楼层 |阅读模式
装了solidworks之后,打开一个三维图,没有在菜单上发现有Ansys Icem cfd,也就不能用Dci,请问高手怎么解决这个问题
发表于 2004-11-24 17:43:59 | 显示全部楼层
请问你有DCI吗??从那里DOWN的??
 楼主| 发表于 2004-11-25 17:12:35 | 显示全部楼层
我没有,不过在ftp.icemcfd.com中有.但我上不了国外网站
发表于 2007-8-9 21:30:41 | 显示全部楼层
lz看这个好了
大意就是打开solidworks 工具菜单下选择插件
然后 点选swmif这个插件 并随SW启动
然后就OK了
详情见:
http://www.ansys.com/products/icemcfd-tech-notes/solidworks/installation.htm
Installing the SolidWorks Direct CAD Interface
Prerequisites:
Operating Systems:  Windows NT 4.0 or Service Pack 5 or higher.  Or, Windows 2000 (NT 5.0)
SolidWorks Version:  2000 Service Pack 0 or higher.
ICEM CFD Installed:  Version 4.1 or higher must be installed and configured properly.
Note:   Please refer to the installation instructions in the  ICEM CFD/CAE Installation Guide . The instructions that follow will assume that ICEM CFD has been installed to:
       D:\icemcfd\4.1-win\
Installation:
The ICEM CFD installation process will put the SolidWorks DCI swmif_mmddyy.zip file onto your system at D:\icemcfd\4.1-win\dif\swmif.
Open the Swmif zip file with WinZip.
Inside WinZip double click on the file setup.exe.
This will start the install shield wizard. Select "Next", then designate a directory to install the interface, and click on "Finish". We recommend installing to the directory D:\icemcfd\4.1-win\dif\swmif.
Start SolidWorks.  Go to the "Tools" menu and select "Add-Ins".  In the dialog box which appears,  check the box named "Swmif".
Close SolidWorks.
Restart SolidWorks.  Once a Part or Assembly is loaded, the interface will appear automatically as a menu labeled "ICEM CFD".
If you receive a message stating that your license file is either "not configured" properly, or is "not visible", and the "ICEM CFD" menu does not appear,  then go to configure license.
Note:  If you are reinstalling the interface, make sure to uninstall any previous installations, before running the setup program.  To uninstall, perform:  Start->Settings->Control Panel->Add/Remove Programs->"SWMIF"; OK.
发表于 2010-2-24 21:30:40 | 显示全部楼层
请问一下,什么是DCI?
