查看: 3451|回复: 1
还有一个问题,请问如何解决
发表于 2003-4-19 22:18:40 | 显示全部楼层 |阅读模式
某多级co2压缩机的最后一级,流道狭长,Pin=100bar,Tin=360k,采有BL模型、3重网格计算。
当initial solution为for turbomachinery是,计算几步就出错了
查看.std文件,
APPLY BOUNDARY CONDITIONS
  ITER GL RMS_RES. MAX_RES. DOM  I   J   K    MF_IN     MF_OUT       FORCE      TORQUE
      1  1   0.0000   3.9036   1  32  44  21  5.0556E+01  1.0908E+01  0.0000E+00  0.0000E+00
      1  3  -0.5484   2.0207   1   8  11   7  6.6857E+01  1.1039E+02  0.0000E+00  0.0000E+00
      2  3
run-time error M6104: MATH
- floating-point error: overflow
0E+00  0.0000E+00
      3  3  -0.2186   2.3403   1   1  11  20  7.2107E+01  1.4062E+02  0.0000E+00  0.0000E+00
      4  3  -0.3661   2.2692   1   1  11  21  7.5523E+01  1.5734E+02  0.0000E+00  0.0000E+00
      5  3  -0.3467   2.2169   1   1  10  21  7.8820E+01  1.7547E+02  0.0000E+00  0.0000E+00
      6  3  -0.3724   2.2372   1   1   8  21  8.1787E+01  1.9551E+02  0.0000E+00  0.0000E+00
DENSITY NEGATIVE IN DOMAIN     1
PRESSURE NEGATIVE IN DOMAIN     1
      7  3  -0.4255   2.1719   1   1   8  21  8.4345E+01  2.1867E+02  0.0000E+00  0.0000E+00
initial solution改为constant values时也不行:
      1  1   0.0000   3.6243   1   1  44  82  1.0165E+01  8.0053E-02  0.0000E+00  0.0000E+00
      1  3  -0.9707   1.4627   1   8   1  20  1.2739E+01 -4.7584E-01  0.0000E+00  0.0000E+00
      2  3  -0.9248   1.6609   1   8   1  14  1.4690E+01 -7.7366E-01  0.0000E+00  0.0000E+00
PR
请问
这错误是怎么回事,如何解决,谢谢
发表于 2003-4-21 14:43:06 | 显示全部楼层
还有一个问题,请问如何解决
请联系  support@numeca-beijing.com,并确知您的NUMECA版本及工作单位。
Thanks
