查看: 3557|回复: 2
请教RANS的一个概念。
发表于 2003-5-31 00:24:57 | 显示全部楼层 |阅读模式
K-epislon模型被称为one-point closure方法下导出的一种雷诺平均N-S方程(RANS), 相对于(two-point closure)而言。
请教:什么是one-point closure?
      什么是two-point closure?
能不能解释:
one-point closure:
If the flow is statistically steady, over a coordinate in which the mean flow does not vary, or over an ensemble of realizations(an imagined set of flows in which all controllable factors are kept fixed).
two-point closure:
use equations for the correlation of the velocity components at two distinct points or more oftern, the Fourier transform of these equations.
发表于 2003-6-2 14:57:01 | 显示全部楼层
请教RANS的一个概念。
找几本书看看,能有答案的。
其实单点封闭说的是仅仅针对对于u(x,t)而言。而两点封闭是对u(x,t)u(x+x',t+t').
你可以看看准正态eddy model,以及直接相互作用原理,它们都是两点封闭的。
 楼主| 发表于 2003-6-2 22:21:59 | 显示全部楼层
请教RANS的一个概念。
Thanks
