查看: 4364|回复: 8
Code for a large range of turbulence models (下)
发表于 2003-12-3 01:28:44 | 显示全部楼层 |阅读模式
ISAAC Public Source License
Version 1.0
October 2001
Copyright (c) 2001 Joseph H. Morrison
Everyone is hereby permitted to copy and distribute verbatim copies of
this license.
TERMS AND CONDITIONS FOR COPYING, DISTRIBUTING, AND MODIFYING THE PROGRAM
0. This License applies to the ISAAC (Integrated Solution Algorithm for
  Arbitrary Configurations) computational fluid dynamics code, its related
  documentation, and related sample cases and helper applications. The
  "Author" below refers to Joseph H. Morrison, the original author of
  the ISAAC source code, documentation, sample cases, and helper
  applications. The "rogram" below refers to the ISAAC source code and
  associated helper applications that are distributed with ISAAC by the
  Author. Each licensee is referred to as "You".
1. You may use, reproduce, and distribute verbatim copies of the Program
  source code provided that You retain and reproduce intact all of the
  copyright notices, references to this license, notices of absence of
  any warranty, and disclaimers; give any other recipients of the Program
  a copy of this License along with the Program.
2. You may modify Your copy or copies of the Program or any portion therof
  and copy and distribute Your modifications under the terms of Section 1,
  provided that:
a) You must include a prominent notice in the modified files stating
          that you changed the files and the date of the changes
b) You must make Source Code of changes that you distribute publicly
          available under the terms of this license.
3. You may copy and distribute the Program or a modified version of the
  Program in object code or executable form under the terms of Sections 1
  and 2 provided that:
a) You accompany it with the complete corresponding machine
          readable source code distributed under the terms of Section 1
          and 2 above; OR
b) You include a prominent notice in the code itself, the executable
          form of the code, and the related documentation, stating that the
          source code is available under the terms of this License with
          information on how and where to obtain the source code of
          the Program.
4. You may only copy, modify, sublicense, or distribute the Program as
  expressly provided by this License. Any attempt to copy, modify,
  sublicense, or distribute the Program in a manner not expressly
  provided by this License is void and will automatically terminate
  Your rights under this License. However, parties who have received
  copies of the Program from You but remain in compliance with this
  License will not have their licenses terminated.
5. You are not required to accept the terms of this License. However, by
  downloading, using, modifying, or distributing the Program, You
  acknowledge that you have read this License Agreement, that you
  understand it, and that you agree to be bound by its terms.
6. Any recipient of the Program from You automatically receives a license
  from the original licensor to copy, modify, or distribute the Program
  subject to these terms and conditions. You may not impose additional
  restrictions on the recipient's rights granted herein.
7. If any part of this License is found invalid or unenforceable by a
  court of competent jurisdiction, the remainder of this License shall
  be interpreted so as to reasonably effect the intentions of the parties.
  If you cannot distribute the Program so as to satisfy the terms of this
  License, then You may not distribute the Program at all.
8. The Author of this License may publish revised and/or new versions of
  the License from time to time. Each new version will be given a
  distinguishing version number. Once a version of the Program has
  been published under a particular version of the License, You can
  continue to use the Program under that version of the License or
  You may choose to use the Program under the terms of any subsequent
  version of the License published by the Author.
10. If you wish to incorporate parts of the Program into other free
   programs whose distribution conditions differ from this License,
   contact the Author to ask for permission. ALL distributions of the
   Program require copmpliance with Sections 11, 12, 13, and 14 below.
NO SALE TO U.S. GOVERNMENT
11. The PROGRAM, and/or any modified version thereof, shall not, in
   any manner, be offered for sale to the U.S. Government, without
   the written consent of the U.S. Government. The U.S. Government
   shall not pay a second time for the PROGRAM or any enhanced/modified
   version therof. The PROGRAM may be used in contract with the
   U.S. Government, but no charge may be made for its use. If the
   PROGRAM is modified using or enhanced using U.S. Government funds,
   the Government will be provided the complete source code of that
   modified/enhanced version and the intellectual property rights of
   the resulting modification/enhancement shall be controlled by such
   funding agreement.
NO WARRANTY
12. THE AUTHOR AND NASA MAKE NO REPRESENTATIONS REGARDING THE PROGRAM
   AND EXTENDS NO WARRANTIES OF ANY KIND, WHETHER EXPRESS, IMPLIED,
   OR STATUTORY, INCLUDING BUT NOT LIMITED TO ANY WARRANTY THAT THE
   PROGRAM WILL CONform TO SPECIFICATIONS, ANY WARRANTY OF MERCHANTABILITY
   OR FITNESS FOR A PARTICULAR PURPOSE, ANY WARRANTY THAT THE DOCUMENTATION
   WILL CONform TO THE PROGRAM, AND ANY WARRANTY THAT THE PROGRAM WILL
   BE ERROR-FREE, WHETHER OR NOT THE ERROR IS DISCOVERABLE, AND ASSUMES
   NO RESPONSIBILITY WHATSOEVER WITH RESPECT TO USE, SALE, OR OTHER
   DISPOSITION BY UNDERSIGNED OR ITS VENDEES OR OTHER TRANSFEREES OF
   PRODUCTS INCORPORATING OR MADE BY THE USE OF PROGRAM OR INformATION,
   IF ANY, FURNISHED UNDER THIS AGREEMENT. NOTHING IN THIS AGREEMENT
   SHALL BE CONSTRUED AS A REPRESENTATION MADE OR WARRANTY GIVEN BY
   NASA OR THE AUTHOR THAT THE PRACTICE BY UNDERSIGNED OF THE USE GRANTED
   HEREUNDER SHALL NOT INFRINGE THE COPYRIGHT OR PATENT RIGHTS OF ANY
   THIRD PARTY. IN NO EVENT SHALL NASA OR THE AUTHOR BE LIABLE FOR ANY
   DAMAGES, INCLUDING BUT NOT LIMITED TO DIRECT, INDIRECT, SPECIAL,
   OR CONSEQUENTIAL DAMAGES ARISING OUT OF, RESULTING FROM, OR IN ANY
   WAY CONNECTED WITH THE USE OF THE PROGRAM, WHETHER OR NOT BASED
   UPON WARRANTY, CONTRACT, TORT, OR OTHERWISE, WHETHER OR NOT INJURY
   WAS ECONOMIC, LOST PROFITS OR SUSTAINED BY PERSONS OR PROPERTY
   OR OTHERWISE, WHETHER OR NOT DAMAGES ARE BASED ON A THIRD PARTY
   CLAIM, WHETHER OR NOT LOSS WAS SUSTAINED FROM, OR AROSE OUT OF,
   THE RESULTS OR USE OF THE PROGRAM, AND REGARDLESS OF WHETHER NASA
   OR THE AUTHOR SHALL BE ADVISED, SHALL HAVE OTHER REASON TO KNOW,
   OR IN FACT SHALL KNOW OF THE POSSIBILITY OF THE FOREGOING.
13. UNDERSIGNED SHALL INDEMNIFY AND HOLD THE AUTHOR, THE U.S. GOVERNMENT
   AND ITS OFFICERS AND EMPLOYEES, HARMLESS AGAINST ALL CLAIMS,
   PROCEEDINGS, LIABILITIES, DEMANDS, DAMAGES, EXPENSES, OR LOSSES,
   INCLUDING LEGAL EXPENSES AND ATTORNEY'S FEES, ARISING (1) OUT OF
   THE USE BY UNDERSIGNED OR ITS TRANSFEREES OF THE PROGRAM OR ANY
   TECHNICAL DATA DERIVED FROM THE USE OF THE PROGRAM OR (2) OUT OF
   ANY USE, SALE, LEASE, OR OTHER DISPOSITION BY UNDERSIGNED OR ITS
   TRANFEREES OF PRODUCTS MADE BY USE OF SUCH PROGRAM OR TECHNICAL DATA
   DERIVED FROM USE OF THE PROGRAM.
14. The conditions imposed by this Agreement shall also apply to any
   software developed by UNDERSIGNED that incorporates any portion
   of the PROGRAM SOURCE CODE.
This Agreement constitutes the entire understanding and agreement
between the parties hereto relating to release of the Program and
may not be superseeded, modified, or ammended except by further
written agreement duly executed by the parties.
END OF TERMS AND CONDITIONS
The bear is silly, but he always smiles.
编辑  2003/12/03 01:19am IP: 已设置保密
  sillybear
信息:
来自: 保密
总发贴数: 384 篇
注册日期: 2003/04/11
消息 查看 搜索 好友 邮件 主页 复制 引用 回复
  相关附件: (共 2631 字节)
为表示对原作者的敬意, 请在下载前看完上贴的版权声明。
 楼主| 发表于 2003-12-3 01:29:52 | 显示全部楼层
MAKE=make
FC = f77
#SRC=  $(HOME)/CFD/ISAAC/src
SRC=  $(CURDIR)
SRCTARFILE= isaacsrc.tar
MKTARFILE=  isaacmk.tar
RCSTARFILE= isaacrcs.tar
##FFLAGS= -ansi -O2
##FFLAGS= -ansi -O2 -trapuv -C -Olimit 3000
#FFLAGS= -ansi -trapuv -C
########FFLAGS= -ansi -trapuv -C -mips2 -O2 -noisam
#normalFFLAGS= -ansi -r8 -trapuv -C -mips2 -O2 -noisam -Nn20000
#too slowFFLAGS= -ansi -r8 -trapuv -C -mips2 -O2 -Olimit 5000 -noisam -Nn20000
#SGI Production flags
#FFLAGS= -ansi -r8 -trapuv -C -mips2 -O2 -noisam -Nn20000
#####FFLAGS= -mips2 -O2 -Olimit 3000 -noisam
#g77 flags
FFLAGS= -O2
CPPFLAGS = -DCPU_TIME
OBJ= main.o \
bc.o \
fourth.o \
io.o \
invscd.o \
mg.o \
misc.o \
resid.o \
viscos.o \
rk.o \
march.o \
af3f.o \
af3dia.o \
jacs.o \
solvr.o \
bldlmx.o \
kepsln.o \
komega.o \
les.o \
rij.o
all:
cd $(SRC)/main;\
$(MAKE) -f main.mk "HOME=$(HOME)" "SRC=$(SRC)" "FFLAGS=$(FFLAGS)" \
"FC=$(FC)" "CPPFLAGS=$(CPPFLAGS)";\
ln *.o $(SRC)
cd $(SRC)/rhs;\
$(MAKE) -f rhs.mk "HOME=$(HOME)" "SRC=$(SRC)" "FFLAGS=$(FFLAGS)" \
ln *.o $(SRC)
cd $(SRC)/explicit;\
$(MAKE) -f explicit.mk "HOME=$(HOME)" "SRC=$(SRC)" "FFLAGS=$(FFLAGS)" \
ln *.o $(SRC)
cd $(SRC)/implicit;\
$(MAKE) -f implicit.mk "HOME=$(HOME)" "SRC=$(SRC)" "FFLAGS=$(FFLAGS)" \
ln *.o $(SRC)
cd $(SRC)/march;\
$(MAKE) -f march.mk "HOME=$(HOME)" "SRC=$(SRC)" "FFLAGS=$(FFLAGS)" \
ln *.o $(SRC)
cd $(SRC)/turb;\
$(MAKE) -f turb.mk "HOME=$(HOME)" "SRC=$(SRC)" "FFLAGS=$(FFLAGS)" \
ln *.o $(SRC);\
        /bin/rm *.o
$(FC) $(FFLAGS) $(OBJ) -o isaac
/bin/rm *.o
# delete all binary files
clean:
/bin/rm *.o
# create a tar file of the source files
# use binary mode when using ftp to move this to a new machine
srctar:
tar -cvf $(SRCTARFILE) `find . \
-name "*.F" -print \
-o -name "*.h" -print \
mktar:
tar -cvf $(MKTARFILE)  `find . \
-name "*.mk" -print \
-o -name "makefile" -print \
# create a tar file of the RCS files
rcstar:
tar -cvf $(RCSTARFILE) `find . -name "RCS" -a -type d -print
 楼主| 发表于 2003-12-3 01:30:49 | 显示全部楼层
Other make file
 楼主| 发表于 2003-12-3 01:32:27 | 显示全部楼层
[DISABLELBCODE]
发表于 2003-12-8 19:21:22 | 显示全部楼层
The file 18_89_3.rar has some error when unpack
(Diagnostic messege error). Please check.
发表于 2003-12-15 11:26:19 | 显示全部楼层
建议这张的内容从传一遍。
发表于 2005-12-16 09:42:16 | 显示全部楼层
似有不解
发表于 2005-12-22 21:35:04 | 显示全部楼层
顶
发表于 2006-4-1 09:01:33 | 显示全部楼层
下面引用由sillybear在 2003/12/03 01:32am 发表的内容:
