查看: 4994|回复: 14
Code for a large range of turbulence models (Example1)
发表于 2003-12-3 01:35:01 | 显示全部楼层 |阅读模式
为表示对原作者的敬意, 请在下载前看完上贴的版权声明。
ISAAC Public Source License
Version 1.0
October 2001
Copyright (c) 2001 Joseph H. Morrison
Everyone is hereby permitted to copy and distribute verbatim copies of
this license.
TERMS AND CONDITIONS FOR COPYING, DISTRIBUTING, AND MODIFYING THE PROGRAM
0. This License applies to the ISAAC (Integrated Solution Algorithm for
Arbitrary Configurations) computational fluid dynamics code, its related
documentation, and related sample cases and helper applications. The
"Author" below refers to Joseph H. Morrison, the original author of
the ISAAC source code, documentation, sample cases, and helper
applications. The "rogram" below refers to the ISAAC source code and
associated helper applications that are distributed with ISAAC by the
Author. Each licensee is referred to as "You".
1. You may use, reproduce, and distribute verbatim copies of the Program
source code provided that You retain and reproduce intact all of the
copyright notices, references to this license, notices of absence of
any warranty, and disclaimers; give any other recipients of the Program
a copy of this License along with the Program.
2. You may modify Your copy or copies of the Program or any portion therof
and copy and distribute Your modifications under the terms of Section 1,
provided that:
a) You must include a prominent notice in the modified files stating
that you changed the files and the date of the changes
b) You must make Source Code of changes that you distribute publicly
available under the terms of this license.
3. You may copy and distribute the Program or a modified version of the
Program in object code or executable form under the terms of Sections 1
and 2 provided that:
a) You accompany it with the complete corresponding machine
readable source code distributed under the terms of Section 1
and 2 above; OR
b) You include a prominent notice in the code itself, the executable
form of the code, and the related documentation, stating that the
source code is available under the terms of this License with
information on how and where to obtain the source code of
the Program.
4. You may only copy, modify, sublicense, or distribute the Program as
expressly provided by this License. Any attempt to copy, modify,
sublicense, or distribute the Program in a manner not expressly
provided by this License is void and will automatically terminate
Your rights under this License. However, parties who have received
copies of the Program from You but remain in compliance with this
License will not have their licenses terminated.
5. You are not required to accept the terms of this License. However, by
downloading, using, modifying, or distributing the Program, You
acknowledge that you have read this License Agreement, that you
understand it, and that you agree to be bound by its terms.
6. Any recipient of the Program from You automatically receives a license
from the original licensor to copy, modify, or distribute the Program
subject to these terms and conditions. You may not impose additional
restrictions on the recipient's rights granted herein.
7. If any part of this License is found invalid or unenforceable by a
court of competent jurisdiction, the remainder of this License shall
be interpreted so as to reasonably effect the intentions of the parties.
If you cannot distribute the Program so as to satisfy the terms of this
License, then You may not distribute the Program at all.
8. The Author of this License may publish revised and/or new versions of
the License from time to time. Each new version will be given a
distinguishing version number. Once a version of the Program has
been published under a particular version of the License, You can
continue to use the Program under that version of the License or
You may choose to use the Program under the terms of any subsequent
version of the License published by the Author.
10. If you wish to incorporate parts of the Program into other free
programs whose distribution conditions differ from this License,
contact the Author to ask for permission. ALL distributions of the
Program require copmpliance with Sections 11, 12, 13, and 14 below.
NO SALE TO U.S. GOVERNMENT
11. The PROGRAM, and/or any modified version thereof, shall not, in
any manner, be offered for sale to the U.S. Government, without
the written consent of the U.S. Government. The U.S. Government
shall not pay a second time for the PROGRAM or any enhanced/modified
version therof. The PROGRAM may be used in contract with the
U.S. Government, but no charge may be made for its use. If the
PROGRAM is modified using or enhanced using U.S. Government funds,
the Government will be provided the complete source code of that
modified/enhanced version and the intellectual property rights of
the resulting modification/enhancement shall be controlled by such
funding agreement.
NO WARRANTY
12. THE AUTHOR AND NASA MAKE NO REPRESENTATIONS REGARDING THE PROGRAM
AND EXTENDS NO WARRANTIES OF ANY KIND, WHETHER EXPRESS, IMPLIED,
OR STATUTORY, INCLUDING BUT NOT LIMITED TO ANY WARRANTY THAT THE
PROGRAM WILL CONform TO SPECIFICATIONS, ANY WARRANTY OF MERCHANTABILITY
OR FITNESS FOR A PARTICULAR PURPOSE, ANY WARRANTY THAT THE DOCUMENTATION
WILL CONform TO THE PROGRAM, AND ANY WARRANTY THAT THE PROGRAM WILL
BE ERROR-FREE, WHETHER OR NOT THE ERROR IS DISCOVERABLE, AND ASSUMES
NO RESPONSIBILITY WHATSOEVER WITH RESPECT TO USE, SALE, OR OTHER
DISPOSITION BY UNDERSIGNED OR ITS VENDEES OR OTHER TRANSFEREES OF
PRODUCTS INCORPORATING OR MADE BY THE USE OF PROGRAM OR INformATION,
IF ANY, FURNISHED UNDER THIS AGREEMENT. NOTHING IN THIS AGREEMENT
SHALL BE CONSTRUED AS A REPRESENTATION MADE OR WARRANTY GIVEN BY
NASA OR THE AUTHOR THAT THE PRACTICE BY UNDERSIGNED OF THE USE GRANTED
HEREUNDER SHALL NOT INFRINGE THE COPYRIGHT OR PATENT RIGHTS OF ANY
THIRD PARTY. IN NO EVENT SHALL NASA OR THE AUTHOR BE LIABLE FOR ANY
DAMAGES, INCLUDING BUT NOT LIMITED TO DIRECT, INDIRECT, SPECIAL,
OR CONSEQUENTIAL DAMAGES ARISING OUT OF, RESULTING FROM, OR IN ANY
WAY CONNECTED WITH THE USE OF THE PROGRAM, WHETHER OR NOT BASED
UPON WARRANTY, CONTRACT, TORT, OR OTHERWISE, WHETHER OR NOT INJURY
WAS ECONOMIC, LOST PROFITS OR SUSTAINED BY PERSONS OR PROPERTY
OR OTHERWISE, WHETHER OR NOT DAMAGES ARE BASED ON A THIRD PARTY
CLAIM, WHETHER OR NOT LOSS WAS SUSTAINED FROM, OR AROSE OUT OF,
THE RESULTS OR USE OF THE PROGRAM, AND REGARDLESS OF WHETHER NASA
OR THE AUTHOR SHALL BE ADVISED, SHALL HAVE OTHER REASON TO KNOW,
OR IN FACT SHALL KNOW OF THE POSSIBILITY OF THE FOREGOING.
13. UNDERSIGNED SHALL INDEMNIFY AND HOLD THE AUTHOR, THE U.S. GOVERNMENT
AND ITS OFFICERS AND EMPLOYEES, HARMLESS AGAINST ALL CLAIMS,
PROCEEDINGS, LIABILITIES, DEMANDS, DAMAGES, EXPENSES, OR LOSSES,
INCLUDING LEGAL EXPENSES AND ATTORNEY'S FEES, ARISING (1) OUT OF
THE USE BY UNDERSIGNED OR ITS TRANSFEREES OF THE PROGRAM OR ANY
TECHNICAL DATA DERIVED FROM THE USE OF THE PROGRAM OR (2) OUT OF
ANY USE, SALE, LEASE, OR OTHER DISPOSITION BY UNDERSIGNED OR ITS
TRANFEREES OF PRODUCTS MADE BY USE OF SUCH PROGRAM OR TECHNICAL DATA
DERIVED FROM USE OF THE PROGRAM.
14. The conditions imposed by this Agreement shall also apply to any
software developed by UNDERSIGNED that incorporates any portion
of the PROGRAM SOURCE CODE.
This Agreement constitutes the entire understanding and agreement
between the parties hereto relating to release of the Program and
may not be superseeded, modified, or ammended except by further
written agreement duly executed by the parties.
END OF TERMS AND CONDITIONS
 楼主| 发表于 2003-12-3 01:36:37 | 显示全部楼层
part01
 楼主| 发表于 2003-12-3 01:37:26 | 显示全部楼层
part02
 楼主| 发表于 2003-12-3 01:37:56 | 显示全部楼层
part03
 楼主| 发表于 2003-12-3 02:40:22 | 显示全部楼层
LBHIDDEN[1]LBHIDDEN
下面引用由sillybear在 2003/12/03 01:37am 发表的内容:
part03
Enjoy it!
发表于 2003-12-11 14:48:14 | 显示全部楼层
怎么打开呀
发表于 2003-12-11 15:01:29 | 显示全部楼层
你是自己编的程序,不是用软件的。听牛的
发表于 2003-12-14 20:59:45 | 显示全部楼层
用什么打开呢?
发表于 2003-12-15 11:27:44 | 显示全部楼层
附件保密!
(您没有权限看这个帖子,您的威望至少需要 1)
这是什么意思啊?
发表于 2003-12-22 10:56:13 | 显示全部楼层
就是,怎么样威望才会上升?
发表于 2004-4-23 19:52:05 | 显示全部楼层
附件保密?
发表于 2004-6-2 11:15:00 | 显示全部楼层
part4怎么下载嗄?
发表于 2004-6-29 21:41:40 | 显示全部楼层
什么意思嘛,这个也要威望值?
发表于 2005-3-16 21:03:02 | 显示全部楼层
怎么上升威望值啊?
急啊!
发表于 2005-3-18 17:28:50 | 显示全部楼层
我觉得有点不公平,因为知识是无价的,虽然我不是很赞成你用威望来限制阅读权,但这是个人问题我无权干涉,但我觉得对于很多求知若渴的人有点残酷!唉,我只能等我有1分威望的时候在来向大家学习了,不好意思!
