查看: 4701|回复: 3
[数据库]European Research Community on Flow,Turbulence and Combust
发表于 2007-4-6 20:05:05 | 显示全部楼层 |阅读模式
LBHIDDEN[0]LBHIDDEN[这个贴子最后由yxjbuaa在 2007/04/06 08:09pm 第 1 次编辑]
大量实验(包括DNS和LES)数据免费下载,网址:
http://cfd.me.umist.ac.uk/ercoftac/
Welcome to the ERCOFTAC "Classic Collection" Database. From these pages you can access the test cases of the original ERCOFTAC Database, which was started in 1995. In 1999 the CFD group at UMIST took over responsibility for it, and following the merger of UMIST and the Victoria University of Manchester it is now administered by the CFD research group in the School of Mechanical, Aerospace and Civil Engineering at The University of Manchester.
The database has undergone some re-structuring and expansion to include, amongst other things, more details of the test cases, computational results, and results and conclusions drawn from the ERCOFTAC Workshops on Refined Turbulence Modelling. At the moment, each case should contain at least a brief description, some data to download, and references to published work. Some cases contain significantly more information than this.
The database is open to all fluid dynamicists worldwide. However, to enable us to keep track of how the database is being used it is necessary to register in order to download any of the datasets. For those already using the original database, your username and password remain unaltered. New users can register from the link towards the top of the page.
If you have any comments or suggestions for further improvements, please either make use of the discussion forum from the link on the left, or e-mail Tim Craft or Dominique Laurence.
 楼主| 发表于 2007-4-6 20:06:10 | 显示全部楼层
[数据库]European Research Community on Flow,Turbulence and Combustion Database
现在免费提供的数据有(在不断增加中):
C.01 Isothermal dump combustor with swirl
  Author(s): Nejad et al, Year: 1987, Type: EXP
C.02 3D flow in wedge-plate junction
  Author(s): Anderson & Eaton, Year: 1985, Type: EXP
C.03 Plane Wake after a Circular Cylinder
  Author(s): Antonia & Browne, Year: 1985, Type: EXP
C.04 Swirling and Non-Swirling Flows in Curved Pipe
  Author(s): Anwer, Year: 1989, Type: EXP
C.05 Unsteady Boundary Layer
  Author(s): Brereton & Reynolds, Year: 1988, Type: EXP
C.06 Square-Sectioned Duct 180 degree Bend
  Author(s): Choi et al, Year: 1990, Type: EXP
C.07 Circular to Rectangular Transition Duct
  Author(s): Davis & Gessner, Year: 1990, Type: EXP
C.08 Wing-Body Junction with Separation
  Author(s): Fleming et al , Year: 1988, Type: EXP
C.09 Natural Convection Boundary Layer
  Author(s): Tsuji & Nagano, Year: 1987, Type: EXP
C.10 Couette Flow with Fixed Wavy Wall
  Author(s): Nakabayashi et al, Year: 1989, Type: EXP
C.11 Airfoil Boundary Layer and Wake
  Author(s): Nakayama, Year: 1983, Type: EXP
C.12 Vortices in Boundary Layer
  Author(s): Pauley & Eaton, Year: 1987, Type: EXP
C.13 Sudden Pipe Expansion
  Author(s): Szczepura, Year: 1985, Type: EXP
C.14 Homogeneous Curved Flow
  Author(s): Holloway & Tavoularis, Year: 1990, Type: EXP
C.15 Transitional Cascade Flow
  Author(s): Zierke & Deutsch, Year: 1989, Type: EXP
C.16 Horizontal Convective Boundary Layer
  Author(s): Schmidt & Schumann, Year: 1988, Type: LES
C.17 Laterally Strained Boundary Layers
  Author(s): Pompeo et al, Year: 1992, Type: EXP
C.18 2D Model Hill Wake Flows
  Author(s): Almeida et al, Year: 1990, Type: EXP
C.19 Boundary Layer with Adverse Pressure Gradient
  Author(s): Gasser & Thomann, Year: 1992, Type: EXP
C.20 Flat Plate Transitional Boundary Layers
  Author(s): Coupland, Year: 1990, Type: EXP
C.21 Sink Flow Boundary Layer
  Author(s): Spalart, Year: 1986, Type: DNS
C.22 Boundary Layer in and Downstream from a Convex Bend
  Author(s): Alving et al, Year: 1988, Type: EXP
C.23 Boundary Layer in a Concave Bend
  Author(s): Johnson, Year: 1989, Type: EXP
C.24 Stably Curved Mixing Layer
  Author(s): Castro & Bradshaw, Year: 1976, Type: EXP
C.25 Normally Impinging Jet from a Circular Nozzle
  Author(s): Cooper et al, Year: 1992, Type: EXP
C.26 Single Stream Swirling Jet in Still Air
  Author(s): Morse, Year: 1980, Type: EXP
C.27 Infinite 35 Degree Swept Wing
  Author(s): Van den Berg et al, Year: 1975, Type: EXP
C.28 Pseudo-Eckman Boundary layer
  Author(s): Spalart, Year: 1989, Type: DNS
C.29 Time-Periodic Boundary Layer
  Author(s): Jensen et al, Year: 1989, Type: EXP
C.30 Backward-Facing Step with Inclined Opposite Wall
  Author(s): Driver & Seegmiller, Year: 1985, Type: EXP
C.31 Backward-Facing Step
  Author(s): Le & Moin, Year: 1992, Type: DNS
C.32 Channel Flow
  Author(s): Kim et al, Year: 1987, Type: DNS
C.33 Constant Pressure Boundary Layer
  Author(s): Spalart, Year: 1987, Type: DNS
C.34 Plane Mixing Layer
  Author(s): Bonnet & Delville, Year: 1991, Type: EXP
C.35 Plane Wake
  Author(s): Gough & Hancock, Year: 1986, Type: EXP
C.36 Plane Couette-Poiseuille Flow
  Author(s): Corenflos et al, Year: 1992, Type: EXP
C.37 Pulsed Channel Flow
  Author(s): Tardu et al, Year: 1993, Type: EXP
C.38 Circular Air-Air Jet
  Author(s): Anselmet & Fulachier, Year: 1993, Type: EXP
C.39 Rotating Homogeneous Turbulence in Axisymmetric Contraction
  Author(s): Leuchter, Year: 1993, Type: EXP
C.40 Plane Wake near a Swept Wing
  Author(s): Pailhas et al, Year: 1989, Type: EXP
C.41 Flow around Surface-Mounter Cubical Obstacle
  Author(s): Martinuzzi & Tropea, Year: 1992, Type: EXP
C.42 Flows over 3D and 2D Hills
  Author(s): Thompson & Lawson, Year: 1990, Type: EXP
C.43 Vortex Shedding past Square Cylinder
  Author(s): Lyn, Year: 1992, Type: EXP
C.44 2D Channel Flow with/without Scalar Transport
  Author(s): Horiuti, Year: 1992, Type: DNS
C.45 2D Channel Flow with/without Thermal Field
  Author(s): Kasagi & Kuroda, Year: 1992, Type: DNS
C.46 Plane Couette-Poiseuille Flow
  Author(s): Kuroda & Kasagi, Year: 1992, Type: DNS
C.47 Homogeneous Isotropic Flow with/without Mean Temperature Gradient
  Author(s): Iida & Kasagi, Year: 1992, Type: DNS
C.48 Homogeneous Isotropic Flow with Passive Scalar
  Author(s): Miyauchi et al , Year: 1991, Type: DNS
C.49 Homogeneous Turbulent Shear Flow
  Author(s): Matsumoto et al, Year: 1992, Type: DNS
C.50 Boundary Layer on the Verge of Separation
  Author(s): Dengel & Fernholz, Year: 1989, Type: EXP
C.51 Boundary Layer in an S-Shaped Channel
  Author(s): Truong & Brunet, Year: 1989, Type: EXP
C.52 Duct Flows with Smooth and Rough Walls
  Author(s): Fujita et al, Year: 1988, Type: EXP
C.53 Backward-Facing Inclined Step
  Author(s): Ruck & Makiola, Year: 1992, Type: EXP
C.54 Upslope and Vertical Convective Boundary Layer
  Author(s): Schumann, Year: 1990, Type: LES
C.55 2D Plane Turbulent Wall Jet
  Author(s): Karlsson et al, Year: 1991, Type: EXP
C.56 Backward-Facing Step with Uniform Normal Bleed
  Author(s): Yang et al, Year: 1994, Type: EXP
C.57 Spinning Body
  Author(s): Driver & Johnston, Year: 1990, Type: EXP
C.58 Pipe Contraction
  Author(s): Durst & Wang, Year: 1991, Type: EXP
C.59 Swirling Mixing Layer
  Author(s): Mehta et al, Year: 1991, Type: EXP
C.60 Swirling Boundary Layer in Conical Diffuser
  Author(s): Clausen et al, Year: 1993, Type: EXP
C.61 Wake of a Streamwise Axially Rotating Cylinder
  Author(s): Wood et al, Year: 1994, Type: EXP
C.62 Developing Flow in Curved Rectangular Duct
  Author(s): Kim & Patel, Year: 1991, Type: EXP
C.63 Wing-Body Junction Flow
  Author(s): Olcmen & Simpson, Year: 1990, Type: EXP
C.64 Flow Approaching a Wall-Mounter Circular Cylinder
  Author(s): Dechow & Felsch, Year: 1977, Type: EXP
C.65 Turning Flow over a Flat Plate
  Author(s): Muller, Year: 1982, Type: EXP
C.66 Strained Flow over a Streamwise Axially Rotating Cylinder
  Author(s): Bissonnette & Mellor, Year: 1974, Type: EXP
C.67 Flow over a Streamwise Axially Rotating Cylinder
  Author(s): Lohmann, Year: 1976, Type: EXP
C.68 Near-Wake Flow of a V-Gutter with Slit Bleed
  Author(s): Yang & Tsai, Year: 1991, Type: EXP
C.69 Flow over Isolated 2D Hill
  Author(s): Khurshudyan et al, Year: 1991, Type: EXP
C.70 Flow over Isolated 2D Valley
C.71 Turbulent Plane Couette Flow
  Author(s): Bech et al, Year: 1995, Type: DNS
C.72 Turbulent Pipe Flow with Swirl
  Author(s): Steenbergen, Year: 1995, Type: EXP
C.73 Flat Plate Transitional Boundary Layers
  Author(s): Yang & Voke, Year: 1995, Type: LES
C.74 Flow around Inclined Prolate Spheroid
  Author(s): Kreplin, Year: 1993, Type: EXP
C.75 Flow Through Axisymmetric Expansions
  Author(s): Stieglmeier et al, Year: 1989, Type: EXP
C.76 Flow over a Wavy Wall
  Author(s): Hudson et al, Year: 1995, Type: EXP
C.77 Separated Turbulent Flow over a Wavy Wall
  Author(s): Maass & Schumann, Year: 1995, Type: DNS
C.78 Flow Through Staggered Tube Bundle
  Author(s): Simonin and Barcouda, Year: 1986, Type: EXP
C.79 Turbulent Natural Convection in an Enclosed Tall Cavity
  Author(s): Betts & Bokhari, Year: 1996, Type: EXP
C.80 Steady Flow Past Tube Bundles
  Author(s): Balabani, Year: 1996, Type: EXP
C.81 Flow over Periodic Hills
  Author(s): L. Temmerman and M.A. Leschziner, Year: 2001, Type: LES
C.82 Flow Around a Simplified Car Body (Ahmed Body)
  Author(s): S. Becker, H. Lienhart, C. Stoots, Year: 2000, Type: EXP
C.83 Wall-mounted two-dimensional hump with oscillatory zero-mass-flux jet or suction through a slot
  Author(s): Greenblatt et al, Year: 2004, Type: EXP
C.84 Turbulent Boundary Layer Flow Over a Cube
  Author(s): Lim and Castro, Year: 2006, Type: EXP
发表于 2007-4-25 13:04:21 | 显示全部楼层
基本都是低速的,而且很多是附面层方面的!
希望更多其它方面的,谢谢了!
发表于 2007-10-9 10:03:42 | 显示全部楼层
求教版主,那有些高速的实验数据库啊?多谢了!
