查看: 2040|回复: 2
紧急求助关于DUNS的problem
发表于 2004-9-3 22:09:22 | 显示全部楼层 |阅读模式
请问各位前辈、高手:
    DUNS能不能计算带压气机转子叶片通道的三维流畅?如果能,怎样才能把转速加进去?另外,在输入的脚本文件(*.script2)run mode 中, vnn是用来做啥的?
发表于 2004-9-5 17:22:16 | 显示全部楼层
紧急求助关于DUNS的problem
you can let vnn be 1 all the time and forget it then.
vnn is used to determine the local time step for computation,you can check the file named timestp.f where you may get some clues.
DUNS is incapable of unstructured grid computation,moving body computation.
 楼主| 发表于 2004-9-6 18:11:52 | 显示全部楼层
紧急求助关于DUNS的problem
Thank you very much!
