查看: 2380|回复: 4
[求助]Fortran高手看看:我在调试Fortran时出现如下情况咋办啊
发表于 2004-9-10 01:02:07 | 显示全部楼层 |阅读模式
forrtl: info (58): format syntax error at or near
forrtl: severe (62): syntax error in format, unit -4, file CONIN$
Image              PC        Routine            Line        Source
flow.exe           0040F609  Unknown               Unknown  Unknown
flow.exe           0040F421  Unknown               Unknown  Unknown
flow.exe           0040E5F4  Unknown               Unknown  Unknown
flow.exe           0040EA5D  Unknown               Unknown  Unknown
flow.exe           004078DA  Unknown               Unknown  Unknown
flow.exe           004010E8  Unknown               Unknown  Unknown
flow.exe           00438FE9  Unknown               Unknown  Unknown
flow.exe           0042C594  Unknown               Unknown  Unknown
kernel32.dll       77E614C7  Unknown               Unknown  Unknown
Incrementally linked image--PC correlation disabled.
Press any key to continue
发表于 2004-10-13 13:58:30 | 显示全部楼层
把工程模式调成Debug模式,再运行,就知道哪里出错了
发表于 2004-10-22 16:33:03 | 显示全部楼层
好像是你的输出format写错了
发表于 2004-10-23 21:36:56 | 显示全部楼层
应该是程序中读写文件格式出错,出来编号为4的文件中读写中!
发表于 2004-11-18 18:47:33 | 显示全部楼层
楼上说的有道理!
