查看: 3369|回复: 3
请教
发表于 2002-7-15 09:31:55 | 显示全部楼层 |阅读模式
请教各位大虾,本人目前手头有GAMBIT_V1.3,exceed6.2,exceed3d6.2,以及fluent5.5。(都是从网上DOWN的,很感谢那些提供者),因为我以后从事流体方面的研究课题,侧重于流固耦合,所以我想问问我应该装上上面这些东东的哪些,或者需要的话,我还缺些什么呢。我知道GAMBIT_V1.3是专用的CFD前置处理器,目前都已经有2.0了,fluent5.5基于结构化网格的通用CFD求解器 ,是不是还缺个后处理器呢。或者针对具体的研究领域应该用不同的处理器呢?请赐教
发表于 2002-7-15 10:28:30 | 显示全部楼层
请教
I think those softwares are enough for you to get the flowfield, you could install either exceed6.2 or exceed3d6.2, but I tried the first.
I guess you could download tecplot to visualize your result.
 楼主| 发表于 2002-7-17 22:52:17 | 显示全部楼层
请教
boling2000, 3x for your advice. someone advise me to install both exceed6.2 and  exceed3d6.2.how should i do!Besides, can you tell me how to install this sofeware i detail.? thank you very much!
发表于 2002-7-20 00:12:21 | 显示全部楼层
请教
I tried to find those files for you but I failed. I guess you could find .nfo file in your package which could tell you how to install these software. I guess you should install exceed first and then you could install gambit and fluent.
