查看: 13274|回复: 29
[分享]Notes on Advanced Computational Fluid Dynamics-Dr C. Shu
发表于 2006-2-27 15:39:33 | 显示全部楼层 |阅读模式
LBSALE[5]LBSALE
 楼主| 发表于 2006-2-27 15:42:07 | 显示全部楼层
Table of Contents
1.     Domain-free Discretization (DFD) Method
      1.1 Introduction
      1.2 Domain-free discretization (DFD) method
      1.3 Sample Applications of DFD Method
      1.4 Application of DFD Method to Solve Navier-Stokes Equations
2.     Least Square-based Finite Difference (LSFD) Method
      2.1 Introduction
             2.2 LSFD Method
             2.3 Numerical Analysis of Convergence Rate
             2.4 Sample Applications of LSFD to Flow Problems
3.     Radial Basis Function-based Differential Quadrature (RBF-DQ) Method
      3.1 Introduction
      3.2 Radial Basis Functions (RBFs) and Function Approximation
      3.3 Differential Quadrature (DQ) Method for Derivative Approximation
      3.4 Global Radial Basis Function-based Differential Quadrature (RBF-DQ) Method
      3.5 Local RBF-DQ Method
      3.6 Sample Applications of Local RBF-DQ Method
      3.7 Application of Local RBF-DQ Method to Flow Problems
4.     Standard Lattice Boltzmann Method (LBM)
      4.1 Introduction
      4.2 Lattice Gas Cellular Automata (LGCA)
      4.3 Kinetic theory
      4.4 Lattice Boltzmann Method (LBM)
      4.5 Practical Implementation of LBM for Lid-Driven Square Cavity Flows
5.     Taylor Series Expansion- and Least Square- based Lattice Boltzmann Method (TLLBM)
      5.1 Introduction
      5.2 Conventional models for problems with complex geometry
      5.3 Taylor Series Expansion- and Least Square-based Lattice Boltzmann Method (TLLBM)
      5.4 Accuracy Analysis of TLLBM
      5.5 Practical Implementation of TLLBM for Flow around a Circular Cylinder
6.     Application of TLLBM to Simulate Thermal Flows
      6.1 Introduction
      6.2 Internal Energy Density Distribution Function (IEDDF) Thermal Model
      6.3 Application of IEDDF thermal model on arbitrary mesh by using TLLBM
      6.4 Boundary conditions
      6.5 Practical implementation of IEDDF thermal model for natural convection in a square cavity using the
            technique of TLLBM
 楼主| 发表于 2006-2-27 15:45:32 | 显示全部楼层
两个文件,1.86M的是part1,811k的是part2,下载完后修改一下文件名就可以解压缩了。
上传以后,亲自检验过的。 希望大家喜欢。
发表于 2006-6-30 20:36:04 | 显示全部楼层
[这个贴子最后由ring在 2006/07/01 07:16pm 第 2 次编辑]
俺错了.我付了5流币.跟我的真传版一样.你是Shu老师的学生吗?
发表于 2006-7-3 07:06:45 | 显示全部楼层
看看把
 楼主| 发表于 2006-7-3 10:16:30 | 显示全部楼层
下面引用由ring在 2006/06/30 08:36pm 发表的内容:
真传版什么意思?
发表于 2006-7-3 20:53:00 | 显示全部楼层
你是舒老师学生不?
发表于 2006-8-6 21:31:44 | 显示全部楼层
hao a
发表于 2006-8-7 22:27:02 | 显示全部楼层
为什么不能下载?
发表于 2006-9-29 00:00:48 | 显示全部楼层
顶
发表于 2006-9-30 14:51:05 | 显示全部楼层
多谢分享!
发表于 2006-10-15 09:01:29 | 显示全部楼层
xiexie
发表于 2006-10-15 09:12:00 | 显示全部楼层
请问你所说的shu老师是新加坡的舒昌老师吗
发表于 2006-11-24 15:34:26 | 显示全部楼层
买了,但不能下载?
发表于 2006-12-24 18:17:16 | 显示全部楼层
好东西,谢谢!5个流体金币花得值得。
