查看: 6062|回复: 6
交换Overflow,我用CFL3D交换
发表于 2006-7-4 23:23:19 | 显示全部楼层 |阅读模式
交换Overflow,wyjnan@163.com
发表于 2006-8-3 21:08:51 | 显示全部楼层
我有
呵呵
但是要交换好一点的代码
发表于 2006-8-6 21:46:40 | 显示全部楼层
cfl3d够好的
发表于 2006-9-7 03:10:52 | 显示全部楼层
V5我觉得不怎么样,呵呵
发表于 2006-10-24 22:28:10 | 显示全部楼层
什么是overflow ?
发表于 2011-6-2 15:06:54 | 显示全部楼层
OVERFLOW - the OVERset grid FLOW solver - is a software package for simulating fluid flow around solid bodies using computational fluid dynamics (CFD). It is a compressible 3-D flow solver that solves the time-dependent, Reynolds-averaged, Navier-Stokes equations using multiple overset structured grids.
发表于 2011-6-2 15:10:54 | 显示全部楼层
回复 5# nisaizhen 的帖子
OVERFLOW was developed as part of a collaborative effort between NASA's Johnson Space Center in Houston, Texas and NASA Ames Research Center (ARC) in Moffett Field, California. The driving force behind this work was the need for evaluating the flow about the Space Shuttle launch vehicle. Originally developed in the early 1990s by NASA's Pieter Buning, Dennis Jespersen and others, the code is an outgrowth of earlier codes F3D and ARC3D, and a result of ARC's long history of flow-solver development[1].
