查看: 3263|回复: 1
MATLAB求助!各位高手请出手相助啊~~~
发表于 2003-10-10 15:44:37 | 显示全部楼层 |阅读模式
TOOLBOX里面的OPTIMIZATION里面有个函数:LINPROG(),想求助怎么用啊?(解线性规划
问题)
具体问题:
min X1-2*X2+X3
S.T. X1+X2-2*X3+X4=10
2*X1-X2+4*X3<=8
-X1+2*X2-4*X3<=4
Xj>=0,j=1,...,4
谢谢拉!!!
附help文档:
LINPROG Linear programming.
X=LINPROG(f,A,b) solves the linear programming problem:
min f'*x subject to: A*x <= b
X=LINPROG(f,A,b,Aeq,beq) solves the problem above while additionally
satisfying the equality constraints Aeq*x = beq.
X=LINPROG(f,A,b,Aeq,beq,LB,UB) defines a set of lower and upper
bounds on the design variables, X, so that the solution is in
the range LB <= X <= UB. Use empty matrices for LB and UB
if no bounds exist. Set LB(i) = -Inf if X(i) is unbounded below;
set UB(i) = Inf if X(i) is unbounded above.
X=LINPROG(f,A,b,Aeq,beq,LB,UB,X0) sets the starting point to X0. This
option is only available with the active-set algorithm. The default
interior point algorithm will ignore any non-empty starting point.
X=LINPROG(f,A,b,Aeq,Beq,LB,UB,X0,OPTIONS) minimizes with the default
optimization parameters replaced by values in the structure OPTIONS, an
argument created with the OPTIMSET function. See OPTIMSET for details.
Use options are Display, Diagnostics, TolFun, LargeScale, MaxIter.
Currently, only 'final' and 'off' are valid values for the parameter
Display when LargeScale is 'off' ('iter' is valid when LargeScale is 'on')
[X,FVAL]=LINPROG(f,A,b) returns the value of the objective function at X:
FVAL = f'*X.
[X,FVAL,EXITFLAG] = LINPROG(f,A,b) returns EXITFLAG that
describes the exit condition of LINPROG.
If EXITFLAG is:
> 0 then LINPROG converged with a solution X.
0 then LINPROG reached the maximum number of iterations without conve
rging.
< 0 then the problem was infeasible or LINPROG failed.
[X,FVAL,EXITFLAG,OUTPUT] = LINPROG(f,A,b) returns a structure
OUTPUT with the number of iterations taken in OUTPUT.iterations, the type
of algorithm used in OUTPUT.algorithm, the number of conjugate gradient
iterations (if used) in OUTPUT.cgiterations.
[X,FVAL,EXITFLAG,OUTPUT,LAMBDA]=LINPROG(f,A,b) returns the set of
Lagrangian multipliers LAMBDA, at the solution: LAMBDA.ineqlin for the
linear inequalities A, LAMBDA.eqlin for the linear equalities Aeq,
LAMBDA.lower for LB, and LAMBDA.upper for UB.
NOTE: the LargeScale (the default) version of LINPROG uses a primal-dual
method. Both the primal problem and the dual problem must be feasibl
e
for convergence. Infeasibility messages of either the primal or dual
or both, are given as appropriate. The primal problem in standard
form is
min f'*x such that A*x = b, x >= 0.
The dual problem is
max b'*y such that A'*y + s = f, s >= 0.
发表于 2003-10-10 16:20:33 | 显示全部楼层
A=  2,-1,4,0   b=(8,4)   Aeq=(1,1,-2,1)  beq=10   Lb=0
   -1 2 -4 0
f'=(1,-2,1)       X=Trans(X1,X2,X3,X4)
hope to be helpful.
