查看: 3890|回复: 0
PhD opportunity at University of Durham
发表于 2007-6-25 02:46:54 | 显示全部楼层 |阅读模式
http://www.cfd-online.com/Jobs/showjob.php?record_id=4741
Applications are invited for a three-year research studentship (starting from
Sept/Oct 2007). The work will be on computational modelling development for
efficient and accurate predictions of unsteady aerodynamic and heat transfer
performance. The student is expected to carry out the research project,
leading to Ph.D. degree at the School of Engineering, University of Durham. The
studentship will cover the university fees and living maintenance.
The candidates should have a good honours degree (first class or top upper 2nd
class)in Engineering, Physics or Applied Mathematics. A M.Sc. degree in a fluid
dynamics related subject will be an advantage.
If you are inerested, please email your C.V. with names and addresses of two
referees to: Prof L. He,(Li.He@durham.ac.uk)
德国西门子公司的项目,steam turbine flutter相关的课题。不管能否拿到ORS,导师都给交全部学费还给生活费。开始生活费会少一点(600英镑左右/月,如果没有ORS(国内来做访问学者的,中国政府也有给600英镑/月),但是survive绝对没问题),看业绩加。能力强,出成果快的话,living allowance加的也很快的。
