查看: 2153|回复: 5
[求助]应该如何考虑约束?
发表于 2005-4-28 17:17:04 | 显示全部楼层 |阅读模式
   我在计算隧洞中,做了一个三维模型,为了计算简便,隧洞长度取0.2米,内部用BEAM23的园杆模拟钢筋。
   如果不考虑砼的破裂,即考虑成线弹性,前后两面(Z=0,Z=0.2)不加Z轴的位移约束,出现沿Z轴应力分布不对称现象,如果考虑,计算结果和2维相近;
   如果仅在中心(Z=0.1)加Z轴的位移约束,计算结果也和2维相近;
  为题在于考虑砼破裂后,即加入TB,CONCR属性,前后两面(Z=0,Z=0.2)加Z轴的位移约束的应力计算结果是仅在中心(Z=0.1)加Z轴的位移约束的应力计算结果的10倍
   这是怎么回事啊!
   帮帮忙!
   怎么处理 ?
前后两面(Z=0,Z=0.2)加Z轴的位移约束的计算:
/PREP7
!绘制砼断面关键点,单位,N,KG,M,S
LOCAL,11,1,20,20,0.1
K,9,3.3,-90
K,10,4.1067,-16.94229-36.52886
K,11,3.3,-16.94229
K,12,3.3,0
K,13,3.3,45
K,14,3.3,90
K,15,3.3,135
K,16,3.3,180
K,17,3.3,180+16.94229
K,18,4.1067,16.94229+36.52886+180
K,19,3.24,-90
K,21,3.24,-16.94229
K,20,3.24,-16.94229-36.52886
K,22,3.24,0
K,23,3.24,45
K,24,3.24,90
K,25,3.24,135
K,26,3.24,180
K,27,3.24,180+16.94229
K,28,3.24,180+16.94229+36.52886
K,29,2.76,-90
K,30,2.76,-16.94229-36.52886
K,31,2.76,-16.94229
K,32,2.76,0
K,33,2.76,45
K,34,2.76,90
K,44,2.7,90
K,45,2.7,135
K,35,2.76,135
K,36,2.76,180
K,46,2.7,180
K,37,2.76,180+16.94229
K,47,2.7,180+16.94229
K,38,2.76,180+16.94229+36.52886
K,48,2.7,180+16.94229+36.52886
K,39,2.7,-90
K,40,2.7,-16.94229-36.52886
K,41,2.7,-16.94229
K,42,2.7,0
K,43,2.7,45
SAVE
K,80,0,0,
LARC,17,16,80,3.3
LARC,16,15,80,3.3
LARC,15,14,80,3.3
LARC,14,13,80,3.3
LARC,13,12,80,3.3
LARC,12,11,80,3.3
SAVE
!生成面
A,39,40,41,42,43,44,45,46,47,48
A,29,30,31,32,33,34,35,36,37,38
ASBA,2,1
A,19,20,21,22,23,24,25,26,27,28
ASBA,2,1
CSYS,0
A,9,10,11,12,13,14,15,16,17,18
CSYS,11
ASBA,1,2
!绘制围岩断面关键点
CSYS,0
K,1,0,0,0.1
K,2,20,0,0.1
K,3,40,0,0.1
K,4,40,20,0.1
K,5,40,40,0.1
K,6,20,40,0.1
K,7,0,40,0.1
K,8,0,20,.1
GPLOT
A,1,2,3,4,5,6,7,8
ASBA,2,1
!定义基本图形
ET,1,PLANE42
!定义材料特性
!岩石
MP,EX,1,3E9
mp,prxy,1,0.25
mp,dens,1,2760
!TB,CONC,1,1,9,
!TBDATA,,0.3,1,4e5,6.5e7,,
!砼
MP,EX,2,2.8E10
mp,prxy,2,0.167
mp,dens,2,2500
TB,CONC,2,1,9,
TBDATA,,0.3,1,1.3e6,1.25e7,,
!钢筋
ET,2,BEAM23
R,2,0.018,
KEYOPT,2,2,0
KEYOPT,2,4,1
KEYOPT,2,6,2
KEYOPT,2,10,0
MP,EX,3,20E10
mp,prxy,3,0.25
mp,dens,3,7800
!划分网格个数控制
*do,i,41,48,1
LESIZE,i,,,8
*enddo
LESIZE,1,,,4
LESIZE,2,,,8
LESIZE,3,,,8
LESIZE,4,,,8
LESIZE,5,,,8
LESIZE,6,,,4
LESIZE,7,,,8
LESIZE,8,,,8
LESIZE,9,,,4
*do,i,10,13,1
LESIZE,i,,,8
*enddo
LESIZE,14,,,4
*do,i,15,18,1
LESIZE,i,,,8
*enddo
LESIZE,19,,,4
*do,i,20,23,1
LESIZE,i,,,8
*enddo
LESIZE,24,,,4
*do,i,25,28,1
LESIZE,i,,,8
*enddo
LESIZE,29,,,4
*do,i,30,33,1
LESIZE,i,,,8
*enddo
LESIZE,34,,,4
*do,i,35,40,1
LESIZE,i,,,8
*enddo
!生成平面网格
TYPE,1
MAT,1
AMESH,6
TYPE,1
MAT,2
smrtsize
AMESH,3,5,1
!生成钢筋网格
TYPE,2
real,2
MAT,3
lMESH,17,36,1
k,81,20,20,0
k,82,20,20,0.2
l,81,80
l,80,82
!生成3维网格,345为砼,6为围岩
esize,0.1
et,3,solid65
type,3
MAT,1
vdrag,6,,,,,,50,
vdrag,6,,,,,,49,
type,3
MAT,2
vdrag,3,4,5,,,,50,
vdrag,3,4,5,,,,49,
!清除平面网格
aclear,all
save
finish
/solu
!边界定义
NSEL,S,LOC,Y,0,0.01
nplot
NSEL,a,LOC,x,0,0.01
nplot
NSEL,a,LOC,x,39.9,40
nplot
D,all, ,0, , , ,ALL, , , , ,
NSEL,S,LOC,Z,0.0,0.01
NSEL,A,LOC,Z,0.19,0.2
D,all, ,0, , , ,UZ, , , , ,
!面荷载,压力隧洞水头116米
CSYS,11
ASEL,R,LOC,X,2.7-0.01,2.7+0.01
SFa,all,,PRES,1.16e6,
ACEL,0,9.8,0,
ALLSEL,ALL
cnvtol,f,,0.05,2 !定义收敛条件,使用缺省的VALUE
nsubst,25 !定义子步数
outres,all,all !输出每一子步的结果
autots,1 !打开自动时间步控制
lnsrch,1 !打开线性搜索
ncnv,2 !如果不收敛时结束而不退出
neqit,100 !每一子步中方程的迭代次数限值
pred,on !打开预测器
time,50 !定义时间
solve !求解
!--------------进入后处理过程-----------------------
finish
/post1
pldisp,0 !绘制变形图(缺省为最后一步的)
etable,IMOMENT,SMISC,6 !定义应力表
etable,JMOMENT,SMISC,12
plnsol,s,1,0,1 !绘制Z方向的应力
PRNSOL,S,COMP
PRNSOL,S,PRIN
ETABLE,IMOMENT,SMISC,6
ETABLE,JMOMENT,SMISC,12
ETABLE,IMFORX,SMISC,1
ETABLE,IMFORY,SMISC,2
ETABLE,JMFORX,SMISC,7
ETABLE,JMFORY,SMISC,8
ETABLE,smax,nMISC,1
ETABLE,smin,nMISC,2
PRETAB,IMOMENT,JMOMENT,IMFORX,IMFORY,JMFORX,JMFORY,smax,smin
   仅在中心(Z=0.1)加Z轴的位移约束:
改为
NSEL,S,LOC,Z,0.1,0.11
其余不变
发表于 2005-4-28 18:10:21 | 显示全部楼层
[求助]应该如何考虑约束?
你的plane42定义了平面应变没有?
发表于 2005-4-28 18:14:45 | 显示全部楼层
[求助]应该如何考虑约束?
XIALIBAREN19 兄弟,你这个是三维模型吗?
发表于 2005-4-28 18:48:48 | 显示全部楼层
[求助]应该如何考虑约束?
是3维阿!
是拉出来的阿!
SOLID65阿
你帮我运行以下看看吧!拜托了!
发表于 2005-4-28 18:50:36 | 显示全部楼层
[求助]应该如何考虑约束?
后面把平面的删除了的!
发表于 2005-4-28 19:01:15 | 显示全部楼层
[求助]应该如何考虑约束?
运行了你的模型,感觉建模有问题
隧道的端面尺寸和其纵向长度比较及其微小,完全可以看作平面应变问题处理,你建的这个三维模型似乎没什么必要;岩土体作为半无限体,在施加约束时,左右边界应该只施加x方向的约束,底部基岩可以x,y方向都施加约束,或者只在y方向施加。还有beam23单元是只具有平面自由度的塑性梁单元,用在三维中似乎不太好,另外,既然模型中有梁单元,在收敛准则中,也应该相应有弯矩的收敛准则,而你似乎只有f选项。敬请参考,大家互相学习。
   我的qq:236601853
