查看: 1604|回复: 0
运行出错如何解决
发表于 2005-9-28 15:48:08 | 显示全部楼层 |阅读模式
各位前辈
我刚接触ANSYS,安装并CRACK后,运行时出如下错误,请多多赐教!
/COM,ANSYS RELEASE  9.0    UP20041104       14:54:08    09/28/2005
*** FATAL ***                           CP =       0.391   TIME= 14:54:09
The database (-db) space requested is not currently available.
Reenter ANSYS command line with less database space requested.
The above error is non-recoverable by ANSYS
  ANSYS run terminated by the indicated error
  Current data base saved if possible.
/COM,ANSYS RELEASE  9.0    UP20041104       15:11:34    09/28/2005
*** FATAL ***                           CP =       0.453   TIME= 15:11:34
