查看: 2792|回复: 2
ug导入gambit一问
发表于 2003-11-11 14:00:50 | 显示全部楼层 |阅读模式
ug做好的图如何导入gambit啊,大侠帮忙^_^
发表于 2003-11-29 11:08:00 | 显示全部楼层
ug导入gambit一问
UG18: file -> export -> parasolid -> version: 12.0 - Ug17.0 (or lower) -> select the feature to be exported with pointer -> click OK -> fill in your file name and select file type *.xmt_txt -> OK
Gambit2.1: file -> import -> parosolid ->
发表于 2004-2-14 14:58:59 | 显示全部楼层
ug导入gambit一问
或者用ug导出igs文件,然后输入gambit也可以的
