查看: 4599|回复: 1
http://www.nvidia.com/object/tesla_computing_solutions.html
发表于 2007-11-20 00:38:01 | 显示全部楼层 |阅读模式
Running electromagnetic simulations using NVIDIA';s compute hardware and CUDA accelerate processing times by factors of 25 or more
 楼主| 发表于 2007-11-20 02:08:04 | 显示全部楼层
the GPU is architected for compute-intensive,
highly parallel computation–exactly what is required for graphics rendering.
Therefore on a GPU, more transistors are devoted to data processing than are to
data caching and flow control
The GPU is especially well-suited to address problems that can be expressed as
data-parallel computations with high arithmetic intensity–in other words when the
same program is executed on many data elements in parallel with a high ratio of
arithmetic to memory operations.
