查看: 7416|回复: 6
chemkin源程序
发表于 2006-5-10 22:30:11 | 显示全部楼层 |阅读模式
今天从网上搜到了一段chemkin的源程序,贴出来给大家看看,我觉得主要是读取链接文件,以及计算反应速率的程序,请高手鉴别一下。我想知道这有没有包括化学平衡反应的计算
C----------------------------------------------------------------------C
C        C
      SUBROUTINE CKLEN (LINC, LOUT, LI, LR, LC, IFLAG)
C
C  START PROLOGUE
C
C  SUBROUTINE CKLEN (LINC, LOUT, LENI, LENR, LENC, IFLAG)
C     Returns the lengths required for the work arrays.
C
C  INPUT
C
C     LINC  -  Logical file number for the binary file.
C                   Data type - integer scalar
C     LOUT  -  Output file for printed diagnostics.
C
C  OUTPUT
C     LENI  -  Minimum length required for the integer work array.
C     LENR  -  Minimum length required for the real work array.
C     LENC  -  Minimum length required for the character work array.
C     IFLAG  - IFLAG=0 indicates successful reading of
C              binary linking file; IFLAG>0 indicates
C              error type.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER IFLAG,II,KK,LC,LENC,LENCCK,LENI,LENICK,LENR,LENRCK,LI,
     1        LINC,LOUT,LR,MAXORD,MAXSP,MAXTB,MAXTP,MM,N,NCHRG,NFL,
     2        NIFAR,NIPAR,NITAR,NLIST,NLT,NOR,NRL,NRV,NSTO,NTB,NTHCF,
     3        NW
      DOUBLE PRECISION
     1        CKMN
      PARAMETER (NLIST = 5)
      LOGICAL KERR, VOK, POK
      CHARACTER LIST(NLIST)*16, PREC*16, VERS*16
      COMMON /CKCONS/ PREC, VERS, KERR, LENI, LENR, LENC
C      DATA LIST/';1.9';,';2.0';,';2.1';,';2.2';,';2.3';,';2.4';,';2.5';,';2.6';,
C     1          ';2.7';,';2.8';,';2.9';,';3.0';,';3.1';,';3.2';,';3.3';/
C      DATA LIST /';3.4';,';3.5';,';3.6';/
      DATA LIST /';3.6b';,';3.6c';,';3.6d';,';3.8';, ';3.9';/
C
      VERS = '; ';
      PREC = '; ';
      LENI = 0
      LENR = 0
      LENC = 0
C
      KERR = .FALSE.
      IFLAG = 0
      REWIND LINC
      READ (LINC, ERR=999) VERS, PREC, KERR
C
      VOK = .FALSE.
      DO 5 N = 1, NLIST
         IF (VERS .EQ. LIST(N)) VOK = .TRUE.
    5 CONTINUE
C
      POK = .FALSE.
C*****precision > double
      IF (INDEX(PREC, ';DOUB';) .GT. 0) POK = .TRUE.
C*****END precision > double
C*****precision > single
C      IF (INDEX(PREC, ';SING';) .GT. 0) POK = .TRUE.
C*****END precision > single
C
      IF (KERR .OR. (.NOT.POK) .OR. (.NOT.VOK)) THEN
         IF (KERR) THEN
            WRITE (LOUT,';(/A,/A)';)
     1      '; There is an error in the Chemkin binary file...';,
     2      '; Check CHEMKIN INTERPRETER output for error conditions.';
         ENDIF
         IF (.NOT. VOK) THEN
            WRITE (LOUT,';(/A,A)';)
     1      '; Chemkin binary file is incompatible with Chemkin';,
     2      '; Library Version 4.5';
         ENDIF
         IF (.NOT. POK) THEN
     1      '; Precision of Chemkin binary file does not agree with';,
     2      '; precision of Chemkin library';
         ENDIF
         IFLAG = 20
         RETURN
      ENDIF
C
      READ (LINC, ERR=1111) LENICK, LENRCK, LENCCK, MM, KK, II,
     1                     MAXSP, MAXTB, MAXTP, NTHCF, NIPAR, NITAR,
     2                     NIFAR, NRV, NFL, NTB, NLT, NRL, NW, NCHRG,
     3                     NSTO, NOR, MAXORD, CKMN
      REWIND LINC
C
      LENI = LENICK
      LENR = LENRCK
      LENC = LENCCK
      LI   = LENI
      LR   = LENR
      LC   = LENC
      RETURN
C
  999 CONTINUE
      WRITE (LOUT, 50)
   50 FORMAT ('; Error reading Chemkin binary file.';)
      IFLAG = 1
      RETURN
1111 CONTINUE
      WRITE (LOUT, 50)
      IFLAG = 2
      RETURN
      END
C
C        C
      SUBROUTINE CKINIT (LENIWK, LENRWK, LENCWK, LINC, LOUT, ICKWRK,
     1                   RCKWRK, CCKWRK, IFLAG)
C
C  START PROLOGUE
C
C  SUBROUTINE CKINIT (LENIWK, LENRWK, LENCWK, LINC, LOUT, ICKWRK,
C                     RCKWRK, CCKWRK, IFLAG)*
C     Reads the binary file and creates the internal work arrays
C     ICKWRK, CCKWRK, and RCKWORK.  CKINIT must be called before any
C     other CHEMKIN subroutine is called.  The work arrays must then
C     be made available as input to the other CHEMKIN subroutines.
C
C  INPUT
C     LENIWK - Length of the integer work array, ICKWRK.
C     LENCWK - Length of the character work array, CCKWRK.
C              The minimum length of CCKWRK(*) is MM + KK.
C     LENRWK - Length of the real work array, WORK.
C
C  OUTPUT
C     ICKWRK - Array of integer workspace.
C                   Data type - integer array
C                   Dimension ICKWRK(*) at least LENIWK.
C     RCKWRK - Array of real work space.
C                   Data type - real array
C                   Dimension RCKWRK(*) at least LENRWK.
C     CCKWRK - Array of character work space.
C                   Data type - CHARACTER*16 array
C                   Dimension CCKWRK(*) at least LENCWK.
C              error type.
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INCLUDE ';ckstrt.h';
C
      INTEGER I,ICKWRK,IFLAG,II,ITOC,ITOT,K,KK,L,LC,LENC,LENCWK,
     1        LENI,LENIWK,LENR,LENRWK,LI,LINC,LOUT,LR,M,MAXORD,MAXSP,
     2        MAXTB,MAXTP,MM,MXOR,N,NCHRG,NEI,NEX,NF1,NFL,NIF1,NIFAR,
     3        NIJAN,NIPAR,NITAR,NJA,NLT,NOR,NRL,NRV,NSTO,NTB,NTHCF,
     4        NTOT,NW
      DOUBLE PRECISION
     1        BIG,CKMIN,CKMN,EXPARG,PA,RCKWRK,RU,RUC,SMALL
      DIMENSION ICKWRK(*), RCKWRK(*)
      CHARACTER*(*) CCKWRK(*)
      CHARACTER*16 VERS, PREC
      LOGICAL IOK, ROK, COK, KERR
      COMMON /MACH/ SMALL,BIG,EXPARG
      COMMON /CMIN/ CKMIN
C
C     Data about the machine dependent constants is carried in
C
C     COMMON/MACH/SMALL,BIG,EXPARG
C
C        Set the gas constant to the 1986 CODATA recommended
C        value - Gas constant in cals/mole is determined by
C        division of the later value by 4.184.
C
C        The number for conversion to one atmosphere is exact.
C
      PARAMETER (RU=8.314510D+07, RUC=RU/4.184D+07, PA=1.01325D+06)
C*****exponent range > +/-300
      SMALL = 10.0D00**(-300)
      BIG   = 10.0D00**(+300)
C*****END exponent range > +/-300
      EXPARG = DLOG(BIG)
C
      WRITE (LOUT,15)
   15 FORMAT (/1X,'; CKLIB:  Chemical Kinetics Library';,
     1        /1X,';         CHEMKIN-II Version 4.5, January 1995';,
     2        /1X,';         DOUBLE PRECISION';)
C
      CALL CKLEN (LINC, LOUT, LI, LR, LC, IFLAG)
C
      IF (IFLAG .GT. 0) RETURN
      IOK = (LENIWK .GE. LI)
      ROK = (LENRWK .GE. LR)
      COK = (LENCWK .GE. LC)
      IF (.NOT.IOK .OR. .NOT.ROK .OR. .NOT.COK) THEN
         IF (.NOT. IOK) WRITE (LOUT, 300) LI
         IF (.NOT. ROK) WRITE (LOUT, 350) LR
         IF (.NOT. COK) WRITE (LOUT, 375) LC
         IFLAG = 20
         RETURN
      ENDIF
C
      REWIND LINC
      READ (LINC, ERR=110) VERS, PREC, KERR
      READ (LINC, ERR=110) LENI, LENR, LENC, MM, KK, II,
     3                     NEI, NJA, NIJAN, NF1, NIF1, NEX,
     4                     NSTO, NOR, MAXORD, CKMN
C
      IF (LEN(CCKWRK(1)) .LT. 16) THEN
         WRITE (LOUT,475)
         IFLAG = 21
         RETURN
      ENDIF
C
      NMM = MM
      NKK = KK
      NII = II
      MXSP = MAXSP
      MXTB = MAXTB
      MXTP = MAXTP
      MXOR = MAXORD
      NCP  = NTHCF
      NCP1 = NTHCF+1
      NCP2 = NTHCF+2
      NCP2T = NCP2*(MAXTP-1)
      NPAR = NIPAR
      NLAR = NITAR
      NFAR = NIFAR
      NTHB = NTB
      NLAN = NLT
      NFAL = NFL
      NREV = NRV
      NRLT = NRL
      NWL  = NW
      NEIM = NEI
      NJAR = NJA
      NJAN = NIJAN
      NFT1 = NIF1
      NF1R = NF1
      NEXC = NEX
      NRNU= NSTO
      NORD = NOR
      MXORD= MAXORD
      CKMIN= CKMN
C
C             APPORTION work arrays
C
C             SET  ICKWRK(*)=1  TO FLAG THAT CKINIT HAS BEEN CALLED
C
      ICKWRK(1) = 1
C
C             STARTING LOCATIONS OF INTEGER SPACE
C
C! elemental composition of species
      IcNC = 2
C! species phase array
      IcPH = IcNC + KK*MM
C! species charge array
      IcCH = IcPH + KK
C! # of temperatures for fit
      IcNT = IcCH + KK
C! stoichiometric coefficients
      IcNU = IcNT + KK
C! species numbers for the coefficients
      IcNK = IcNU + MAXSP*II
C! &#35; of non-zero coefficients  (<0=reversible, >0=irreversible)
      IcNS = IcNK + MAXSP*II
C! &#35; of reactants
      IcNR = IcNS + II
C! Landau-Teller reaction numbers
      IcLT = IcNR + II
C! Reverse Landau-Teller reactions
      IcRL = IcLT + NLAN
C! Fall-off reaction numbers
      IcFL = IcRL + NRLT
C! Fall-off option numbers
      IcFO = IcFL + NFAL
C! Fall-off enhanced species
      IcKF = IcFO + NFAL
C! Third-body reaction numbers
      IcTB = IcKF + NFAL
C! number of 3rd bodies for above
      IcKN = IcTB + NTHB
C! array of species &#35;';s for above
      IcKT = IcKN + NTHB
C! Reverse parameter reaction numbers
      IcRV = IcKT + MAXTB*NTHB
C! Radiation wavelength reactions
      IcWL = IcRV + NREV
C! Electon-impact reaction numbers
      IcEI = IcWL + NWL
C! Electron-impact temperature dependence flags
      IcTD = IcEI + NEIM
C! Janev-Langer_Evans&ost type reaction numbers
      IcJN = IcTD + NEIM
C! Reaction numbers using fit&#35;1
      IcF1 = IcJN + NJAN
C! Reaction numbers for excitation-only reactions
      IcEX = IcF1 + NFT1
C! Real stoichometry reactions
      IcRNU= IcEX + NEXC
C! Change of order reactions
      IcORD= IcRNU + NRNU
C! Species for which there is a change of order
      IcKOR= IcORD + NORD
C
      ITOT = IcKOR + NORD*MXORD - 1
C
C             STARTING LOCATIONS OF CHARACTER SPACE
C
C! start of element names
      IcMM = 1
C! start of species names
      IcKK = IcMM + MM
      ITOC = IcKK + KK - 1
C
C             STARTING LOCATIONS OF REAL SPACE
C
C! atomic weights
      NcAW = 1
C! molecular weights
      NcWT = NcAW + MM
C! temperature fit array for species
      NcTT = NcWT + KK
C! thermodynamic coefficients
      NcAA = NcTT + MAXTP*KK
C! Arrhenius coefficients (3)
      NcCO = NcAA + (MAXTP-1)*NCP2*KK
C! Reverse coefficients
      NcRV = NcCO + (NPAR+1)*II
C! Landau-Teller &#35;';s for NLT reactions
      NcLT = NcRV + (NPAR+1)*NREV
C! Reverse Landau-Teller &#35;';s
      NcRL = NcLT + NLAR*NLAN
C! Fall-off parameters for NFL reactions
      NcFL = NcRL + NLAR*NRLT
C! 3rd body coef';nts for NTHB reactions
      NcKT = NcFL + NFAR*NFAL
C! wavelength
      NcWL = NcKT + MAXTB*NTHB
C! Janev-type coefficients
      NcJN = NcWL + NWL
C! Fit&#35;1 parameters
      NcF1 = NcJN + NJAR*NJAN
C! Excitation-only reaction energy loss
      NcEX = NcF1 + NF1R*NFT1
C! real stoichometric coefficients
      NcRNU= NcEX + NEXC
C! change of order for species/reactions
      NcKOR= NcRNU + NRNU*MXSP
C! universal gas constant
      NcRU = NcKOR + NORD*MXORD
C! universal gas constant in units
      NcRC = NcRU + 1
C! pressure of one atmosphere
      NcPA = NcRC + 1
C! intermediate temperature-dependent forward rates
      NcKF = NcPA + 1
C! intermediate temperature-dependent reverse rates
      NcKR = NcKF + II
C! internal work space of length kk
      NcK1 = NcKR + II
C!          ';ditto';
      NcK2 = NcK1 + KK
C!          ';ditto';
      NcK3 = NcK2 + KK
C!          ';ditto';
      NcK4 = NcK3 + KK
      NcI1 = NcK4 + KK
      NcI2 = NcI1 + II
      NcI3 = NcI2 + II
      NcI4 = NcI3 + II
      NTOT = NcI4 + II - 1
C
C        SET UNIVERSAL CONSTANTS IN CGS UNITS
C
      RCKWRK(NcRU) = RU
      RCKWRK(NcRC) = RUC
      RCKWRK(NcPA) = PA
C
C!element names, !atomic weights
      READ (LINC,err=111) (CCKWRK(IcMM+M-1), RCKWRK(NcAW+M-1), M=1,MM)
C
C!species names, !composition, !phase, !charge, !molec weight,
C!&#35; of fit temps, !array of temps, !fit coeff';nts
      READ (LINC,err=222) (CCKWRK(IcKK+K-1),
     1     (ICKWRK(IcNC+(K-1)*MM + M-1),M=1,MM),
     2     ICKWRK(IcPH+K-1),
     3     ICKWRK(IcCH+K-1),
     4     RCKWRK(NcWT+K-1),
     5     ICKWRK(IcNT+K-1),
     6     (RCKWRK(NcTT+(K-1)*MAXTP + L-1),L=1,MAXTP),
     7     ((RCKWRK(NcAA+(L-1)*NCP2+(K-1)*NCP2T+N-1),
     8     N=1,NCP2), L=1,(MAXTP-1)),    K = 1,KK)
C
      IF (II .EQ. 0) RETURN
C
C!&#35; spec,reactants, !Arr. coefficients, !stoic coef, !species numbers
      READ (LINC,end=100,err=333)
     1     (ICKWRK(IcNS+I-1), ICKWRK(IcNR+I-1),
     2      (RCKWRK(NcCO+(I-1)*(NPAR+1)+N-1), N=1,NPAR),
     3      (ICKWRK(IcNU+(I-1)*MAXSP+N-1),
     4       ICKWRK(IcNK+(I-1)*MAXSP+N-1), N=1,MAXSP),
     5      I = 1,II)
C
C     PERTURBATION FACTOR
C
      DO 10 I = 1, II
         RCKWRK(NcCO + (I-1)*(NPAR+1) + NPAR) = 1.D00
   10 CONTINUE
C
      IF (NREV .GT. 0) READ (LINC,err=444)
     1   (ICKWRK(IcRV+N-1), (RCKWRK(NcRV+(N-1)*(NPAR+1)+L-1),
     1   L=1,NPAR), N = 1,NREV)
C
      IF (NFAL .GT. 0) READ (LINC,err=555)
     1   (ICKWRK(IcFL+N-1), ICKWRK(IcFO+N-1), ICKWRK(IcKF+N-1),
     2   (RCKWRK(NcFL+(N-1)*NFAR+L-1),L=1,NFAR),N=1,NFAL)
C
      IF (NTHB .GT. 0) READ (LINC,err=666)
     1   (ICKWRK(IcTB+N-1), ICKWRK(IcKN+N-1),
     2   (ICKWRK(IcKT+(N-1)*MAXTB+L-1),
     3     RCKWRK(NcKT+(N-1)*MAXTB+L-1),L=1,MAXTB),N=1,NTHB)
C
      IF (NLAN .GT. 0) READ (LINC,err=777)
     1   (ICKWRK(IcLT+N-1), (RCKWRK(NcLT+(N-1)*NLAR+L-1),L=1,NLAR),
     2    N=1,NLAN)
C
      IF (NRLT .GT. 0) READ (LINC,err=888)
     1   (ICKWRK(IcRL+N-1), (RCKWRK(NcRL+(N-1)*NLAR+L-1),L=1,NLAR),
     2    N=1,NRLT)
C
      IF (NWL .GT. 0) READ (LINC,err=999)
     1   (ICKWRK(IcWL+N-1), RCKWRK(NcWL+N-1), N=1,NWL)
C
      IF (NEIM .GT. 0) READ (LINC,err=1001)
     1   (ICKWRK(IcEI+N-1), ICKWRK(IcTD+N-1), N=1,NEIM)
      IF (NJAN .GT. 0) READ (LINC,err=1002)
     1   (ICKWRK(IcJN+N-1), (RCKWRK(NcJN+(N-1)*NJAR+L-1),L=1,NJAR),
     2    N=1,NJAN)
      IF (NFT1 .GT. 0) READ (LINC,err=1003)
     1   (ICKWRK(IcF1+N-1), (RCKWRK(NcF1+(N-1)*NF1R+L-1),L=1,NF1R),
     2    N=1,NFT1)
      IF (NEXC .GT. 0) READ (LINC,err=1004)
     1   (ICKWRK(IcEX+N-1), RCKWRK(NcEX+N-1), N=1,NEXC)
C
      IF (NRNU .GT. 0) READ (LINC,err=1111)
     1   (ICKWRK(IcRNU+N-1), (RCKWRK(NcRNU+(N-1)*MAXSP+L-1),L=1,MAXSP),
     2    N=1,NRNU)
C
      IF (NORD .GT. 0) READ (LINC,err=2222)
     1   (ICKWRK(IcORD+N-1), (ICKWRK(IcKOR+(N-1)*MXORD+L-1),
     2                        RCKWRK(NcKOR+(N-1)*MXORD+L-1),
     3   L = 1, MXORD), N=1, NORD)
C
  100 CONTINUE
      RETURN
C
  110 WRITE (LOUT,*) '; Error reading binary file...';
      IFLAG = 1
      RETURN
  111 WRITE (LOUT,*) '; Error reading element data...';
      IFLAG = 2
      RETURN
  222 WRITE (LOUT,*) '; Error reading species data...';
      IFLAG = 3
      RETURN
  333 WRITE (LOUT,*) '; Error reading reaction data...';
      IFLAG = 4
      RETURN
  444 WRITE (LOUT,*) '; Error reading reverse Arrhenius parameters...';
      IFLAG = 5
      RETURN
  555 WRITE (LOUT,*) '; Error reading Fall-off data...';
      IFLAG = 6
      RETURN
  666 WRITE (LOUT,*) '; Error reading third-body data...';
      IFLAG = 7
      RETURN
  777 WRITE (LOUT,*) '; Error reading Landau-Teller data...';
      IFLAG = 8
      RETURN
  888 WRITE (LOUT,*) '; Error reading reverse Landau-Teller data...';
      IFLAG = 9
      RETURN
  999 WRITE (LOUT,*) '; Error reading Wavelength data...';
      IFLAG = 10
      RETURN
1001 WRITE (LOUT,*) '; Error reading Electron-impact data...';
      IFLAG = 11
      RETURN
1002 WRITE (LOUT,*) '; Error reading Janev-Langer-Evans-Post data...';
      IFLAG = 12
      RETURN
1003 WRITE (LOUT,*) '; Error reading Fit &#35; 1 data...';
      IFLAG = 13
      RETURN
1004 WRITE (LOUT,*) '; Error reading excitation-reaction data...';
      IFLAG = 14
      RETURN
1111 WRITE (LOUT,*) '; Error reading real stoichometric data...';
      IFLAG = 15
      RETURN
2222 WRITE (LOUT,*) '; Error reading order data...';
      IFLAG = 16
      RETURN
C
  300 FORMAT (10X,';ICKWRK MUST BE DIMENSIONED AT LEAST ';,I5)
  350 FORMAT (10X,';RCKWRK MUST BE DIMENSIONED AT LEAST ';,I5)
  375 FORMAT (10X,';CCKWRK MUST BE DIMENSIONED AT LEAST ';,I5)
  475 FORMAT (10X,';CHARACTER LENGTH OF CCKWRK MUST BE AT LEAST 16 ';)
      END
C
C        C
      SUBROUTINE CKINDX (ICKWRK, RCKWRK, MM, KK, II, NFIT)
C
C  START PROLOGUE
C
C  SUBROUTINE CKINDX (ICKWRK, RCKWRK, MM, KK, II, NFIT)*
C     Returns a group of indices defining the size of the particular
C     reaction mechanism
C
C  INPUT
C
C  OUTPUT
C     MM     - Total number of elements in mechanism.
C     KK     - Total number of species in mechanism.
C     II     - Total number of reactions in mechanism.
C     NFIT   - number of coefficients in fits to thermodynamic data
C              for one temperature range; NFIT = number of
C              coefficients in polynomial fits to CP/R  +  2.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
C
      INTEGER ICKWRK,II,KK,MM,NFIT
      DOUBLE PRECISION
     1        RCKWRK
C
      MM = NMM
      KK = NKK
      II = NII
      NFIT = NCP2
      RETURN
      END
C
C        C
      SUBROUTINE CKRHOY (P, T, Y, ICKWRK, RCKWRK, RHO)
C
C  START PROLOGUE
C
C  SUBROUTINE CKRHOY (P, T, Y, ICKWRK, RCKWRK, RHO)
C     Returns the mass density of the gas mixture given the pressure,
C     temperature and mass fractions;  see Eq. (2).
C
C  INPUT
C     P      - Pressure.
C                   cgs units - dynes/cm**2
C                   Data type - real scalar
C     T      - Temperature.
C                   cgs units - K
C     Y      - Mass fractions of the species.
C                   cgs units - none
C                   Dimension Y(*) at least KK, the total number of
C                   species.
C
C  OUTPUT
C     RHO    - Mass density.
C                   cgs units - gm/cm**3
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
C
      INTEGER ICKWRK,K
      DOUBLE PRECISION
     1        P,RCKWRK,RHO,SUMYOW,T,Y
      DIMENSION ICKWRK(*), RCKWRK(*), Y(*)
C
      SUMYOW = 0.D00
      DO 150 K = 1, NKK
         SUMYOW = SUMYOW + Y(K)/RCKWRK(NcWT + K - 1)
150   CONTINUE
      RHO = P / (SUMYOW*T*RCKWRK(NcRU))
      RETURN
      END
C
C        C
      SUBROUTINE CKYTX  (Y, ICKWRK, RCKWRK, X)
C
C  START PROLOGUE
C
C  SUBROUTINE CKYTX  (Y, ICKWRK, RCKWRK, X)
C     Returns the mole fractions given the mass fractions;  see Eq. (6).
C
C  INPUT
C                   cgs units - none
C                   species.
C
C  OUTPUT
C     X      - Mole fractions of the species.
C                   cgs units - none
C                   Dimension X(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
C
      INTEGER ICKWRK,K
      DOUBLE PRECISION
     1        RCKWRK,SUMYOW,X,Y
      DIMENSION ICKWRK(*), RCKWRK(*), Y(*), X(*)
C
      SUMYOW = 0.D00
      DO 150 K = 1, NKK
150   CONTINUE
      DO 200 K = 1, NKK
         X(K) = Y(K)/(SUMYOW*RCKWRK(NcWT + K - 1))
200   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKWYP  (P, T, Y, ICKWRK, RCKWRK, WDOT)
C
C  START PROLOGUE
C
C  SUBROUTINE CKWYP  (P, T, Y, ICKWRK, RCKWRK, WDOT)
C     Returns the molar production rates of the species given the
C     pressure, temperature and mass fractions;  see Eq. (49).
C
C  INPUT
C     P      - Pressure.
C     T      - Temperature.
C                   cgs units - K
C                   cgs units - none
C                   species.
C
C  OUTPUT
C     WDOT   - Chemical molar production rates of the species.
C                   cgs units - moles/(cm**3*sec)
C                   Dimension WDOT(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
C
      INTEGER I,ICKWRK,K,L,N
      DOUBLE PRECISION
     1        P,RCKWRK,ROP,T,WDOT,Y
      DIMENSION ICKWRK(*), RCKWRK(*), Y(*), WDOT(*)
C
      CALL CKRATT (RCKWRK, ICKWRK, NII, MXSP, RCKWRK(NcRU),
     1             RCKWRK(NcPA), T, ICKWRK(IcNS), ICKWRK(IcNU),
     2             ICKWRK(IcNK), NPAR+1, RCKWRK(NcCO), NREV,
     3             ICKWRK(IcRV), RCKWRK(NcRV), NLAN, NLAR, ICKWRK(IcLT),
     4             RCKWRK(NcLT), NRLT, ICKWRK(IcRL), RCKWRK(NcRL),
     5             RCKWRK(NcK1), NRNU, ICKWRK(IcRNU), RCKWRK(NcRNU),
     6             NEIM, ICKWRK(IcEI), ICKWRK(IcTD), NJAN, NJAR,
     7             ICKWRK(IcJN), RCKWRK(NcJN), NFT1, NF1R,
     8             ICKWRK(IcF1), RCKWRK(NcF1),
     9             RCKWRK(NcKF), RCKWRK(NcKR), RCKWRK(NcI1))
C
      CALL CKYTCP (P, T, Y, ICKWRK, RCKWRK, RCKWRK(NcK1))
C
      CALL CKRATX (NII, NKK, MXSP, MXTB, T, RCKWRK(NcK1),
     1             ICKWRK(IcNU), ICKWRK(IcNK), NPAR+1, RCKWRK(NcCO),
     2             NFAL, ICKWRK(IcFL), ICKWRK(IcFO), ICKWRK(IcKF), NFAR,
     3             RCKWRK(NcFL), NTHB, ICKWRK(IcTB), ICKWRK(IcKN),
     4             RCKWRK(NcKT), ICKWRK(IcKT), RCKWRK(NcKF),
     5             RCKWRK(NcKR), RCKWRK(NcI1), RCKWRK(NcI2),
     6             RCKWRK(NcI3), NRNU, ICKWRK(IcRNU), RCKWRK(NcRNU),
     7             NORD, ICKWRK(IcORD), MXORD, ICKWRK(IcKOR),
     8             RCKWRK(NcKOR))
C
      DO 50 K = 1, NKK
         WDOT(K) = 0.D00
   50 CONTINUE
      DO 100 N = 1, MXSP
         DO 100 I = 1, NII
            K = ICKWRK(IcNK + (I-1)*MXSP + N - 1)
            IF (K .NE. 0) THEN
               ROP = RCKWRK(NcI1+I-1) - RCKWRK(NcI2+I-1)
               WDOT(K) = WDOT(K) + ROP *
     1         DBLE(ICKWRK(IcNU + (I-1)*MXSP + N - 1))
            ENDIF
  100 CONTINUE
C
      IF (NRNU .LE. 0) RETURN
      DO 200 L = 1, NRNU
         I = ICKWRK(IcRNU + L - 1)
         DO 200 N = 1, MXSP
            IF (K .NE. 0) WDOT(K) = WDOT(K) + ROP *
     1         RCKWRK(NcRNU + (L-1)*MXSP + N - 1)
  200 CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKCPBS (T, Y, ICKWRK, RCKWRK, CPBMS)
C
C  START PROLOGUE
C
C  SUBROUTINE CKCPBS (T, Y, ICKWRK, RCKWRK, CPBMS)
C     Returns the mean specific heat at constant pressure;
C     see Eq. (34).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C                   cgs units - none
C                   species.
C
C  OUTPUT
C     CPBMS  - Mean specific heat at constant pressure in mass units.
C                   cgs units - ergs/(gm*K)
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
C
      INTEGER ICKWRK,K
      DOUBLE PRECISION
     1        CPBMS,RCKWRK,T,Y
C
      CALL CKCPMS (T, ICKWRK, RCKWRK, RCKWRK(NcK1))
C
      CPBMS = 0.D00
      DO 100 K = 1, NKK
         CPBMS = CPBMS + Y(K)*RCKWRK(NcK1 + K - 1)
  100 CONTINUE
C
      RETURN
      END
C
C        C
      SUBROUTINE CKHBMS (T, Y, ICKWRK, RCKWRK, HBMS)
C
C  START PROLOGUE
C
C  SUBROUTINE CKHBMS (T, Y, ICKWRK, RCKWRK, HBMS)
C     Returns the mean enthalpy of the mixture in mass units;
C     see Eq. (38).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C                   cgs units - none
C                   species.
C
C  OUTPUT
C     HBMS   - Mean enthalpy in mass units.
C                   cgs units - ergs/gm
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
C
      INTEGER ICKWRK,K
      DOUBLE PRECISION
     1        HBMS,RCKWRK,T,Y
C
      CALL CKHMS (T, ICKWRK, RCKWRK, RCKWRK(NcK1))
C
      HBMS = 0.D00
      DO 100 K = 1, NKK
         HBMS = HBMS + Y(K)*RCKWRK(NcK1 + K - 1)
  100 CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKMMWY (Y, ICKWRK, RCKWRK, WTM)
C
C  START PROLOGUE
C
C  SUBROUTINE CKMMWY (Y, ICKWRK, RCKWRK, WTM)
C     Returns the mean molecular weight of the gas mixture given the
C     mass fractions;  see Eq. (3).
C
C  INPUT
C                   cgs units - none
C                   species.
C
C  OUTPUT
C     WTM    - Mean molecular weight of the species mixture.
C                   cgs units - gm/mole
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK,K
      DOUBLE PRECISION
     1        RCKWRK,SUMYOW,WTM,Y
      DIMENSION Y(*), ICKWRK(*), RCKWRK(*)
C
      SUMYOW=0.D00
      DO 150 K = 1, NKK
150   CONTINUE
      WTM = 1.D00/SUMYOW
      RETURN
      END
C
C        C
      SUBROUTINE CKRP   (ICKWRK, RCKWRK, RU, RUC, PA)
C
C  START PROLOGUE
C
C  SUBROUTINE CKRP   (ICKWRK, RCKWRK, RU, RUC, PA)
C     Returns universal gas constants and the pressure of one standard
C     atmosphere
C
C  INPUT
C
C  OUTPUT
C     RU     - Universal gas constant.
C                   cgs units - 8.314510E7 ergs/(mole*K)
C     RUC    - Universal gas constant used only in conjuction with
C              activation energy.
C                   preferred units - RU / 4.184 cal/(mole*K)
C     PA     - Pressure of one standard atmosphere.
C                   cgs units - 1.01325E6 dynes/cm**2
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK
      DOUBLE PRECISION
     1        PA,RCKWRK,RU,RUC
C
      RU  = RCKWRK(NcRU)
      RUC = RCKWRK(NcRC)
      PA  = RCKWRK(NcPA)
      RETURN
      END
C
C        C
      SUBROUTINE CKSYME (CCKWRK, LOUT, ENAME, KERR)
C
C  START PROLOGUE
C
C  SUBROUTINE CKSYME (CCKWRK, LOUT, ENAME, KERR)*
C     Returns the character strings of element names.
C
C  INPUT
C     LOUT   - Output unit for printed diagnostics.
C
C  OUTPUT
C     ENAME  - Element names.
C                   Data type - CHARACTER*(*) array
C                   Dimension ENAME at least MM, the total number of
C                   elements in the problem.
C     KERR   - Error flag; character length error will result in
C              KERR = .TRUE.
C                   Data type - logical
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ILASCH,ILEN,LOUT,LT,M
      CHARACTER*(*) CCKWRK(*), ENAME(*)
      LOGICAL KERR
C
      KERR = .FALSE.
      ILEN = LEN(ENAME(1))
      DO 150 M = 1, NMM
         LT = ILASCH(CCKWRK(IcMM+M-1))
         ENAME(M) = '; ';
         IF (LT .LE. ILEN) THEN
            ENAME(M) = CCKWRK(IcMM+M-1)
         ELSE
            WRITE (LOUT,';(A)';)
     1      '; Error in CKSYME...character string length too small ';
            KERR = .TRUE.
         ENDIF
150   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKRATT (RCKWRK, ICKWRK, II, MAXSP, RU, PATM, T, NSPEC,
     1                   NU, NUNK, NPAR, PAR, NREV, IREV, RPAR, NLAN,
     2                   NLAR, ILAN, PLT, NRLT, IRLT, RPLT, SMH, NRNU,
     3                   IRNU, RNU, NEIM, IEIM, ITDEP, NJAN, NJAR, IJAN,
     4                   PJAN, NFT1, NF1R, IFT1, PF1, RKFT, RKRT, EQK)
C
C  START PROLOGUE
C
C  SUBROUTINE CKRATT (RCKWRK, ICKWRK, II, MAXSP, RU, PATM, T, NSPEC,
C 1                   NU, NUNK, NPAR, PAR, NREV, IREV, RPAR, NLAN,
C 2                   NLAR, ILAN, PLT, NRLT, IRLT, RPLT, SMH, NRNU,
C 3                   IRNU, RNU, NEIM, IEIM, ITDEP, NJAN, NJAR, IJAN,
C 4                   PJAN, NFT1, NF1R, IFT1, PF1, RKFT, RKRT, EQK)
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER I,I2,ICKWRK,IEIM,IFT1,II,IJAN,ILAN,IREV,IRLT,IRNU,ITDEP,
     1        J,L,MAXSP,N,N2,NEIM,NF1R,NFT1,NJAN,NJAR,NLAN,NLAR,NPAR,
     2        NREV,NRLT,NRNU,NSPEC,NU,NUNK,NUSUMK
      DOUBLE PRECISION
     1        ALOGT,BIG,EQK,EXPARG,PAR,PATM,PF1,PFAC,PFAC2,PFR,PJAN,
     2        PLT,POWR1,POWR2,RCKWRK,RKFT,RKRT,RNU,RNUSUM,ROOTJ,
     3        RPAR,RPLT,RU,SMALL,SMH,SUMJ,SUMSMH,T,TEMP,TEV,TFAC
      DIMENSION RCKWRK(*), ICKWRK(*), NSPEC(*), NU(MAXSP,*),
     1          NUNK(MAXSP,*), PAR(NPAR,*), IREV(*), RPAR(NPAR,*),
     2          ILAN(*), IRLT(*), PLT(NLAR,*), RPLT(NLAR,*), SMH(*),
     3          RKFT(*), RKRT(*), EQK(*), IRNU(*), RNU(MAXSP,*),
     4          T(*), IEIM(*), ITDEP(*), IJAN(*), PJAN(NJAR,*),
     5          IFT1(*), PF1(NF1R,*)
C
C
      ALOGT = DLOG(T(1))
C
      DO 20 I = 1, II
         RKFT(I) = PAR(1,I) *DEXP(PAR(2,I)*ALOGT - PAR(3,I)/T(1))
   20 CONTINUE
C
C        Landau-Teller reactions
C
      POWR1 = 1.D00/3.D00
      POWR2 = 2.D00/3.D00
      DO 25 N = 1, NLAN
         I = ILAN(N)
         TFAC = PLT(1,N)/T(1)**POWR1 + PLT(2,N)/T(1)**POWR2
         RKFT(I) = RKFT(I) * DEXP(TFAC)
   25 CONTINUE
C
      CALL CKSMH (T(1), ICKWRK, RCKWRK, SMH)
      DO 50 I = 1, II
          SUMSMH = 0.D00
          DO 40 N = 1, MAXSP
             IF (NUNK(N,I).NE.0)
     1         SUMSMH = SUMSMH + DBLE(NU(N,I))*SMH(NUNK(N,I))
   40     CONTINUE
          IF (SUMSMH .NE. 0.0) EQK(I) = DEXP(DMIN1(SUMSMH,EXPARG))
   50 CONTINUE
C
      DO 55 N = 1, NRNU
         SUMSMH = 0.D00
         I = IRNU(N)
         DO 45 L = 1, MAXSP
            IF (NUNK(L,I).NE.0) SUMSMH=SUMSMH+RNU(L,N)*SMH(NUNK(L,I))
   45    CONTINUE
   55 CONTINUE
C
      PFAC = PATM / (RU*T(1))
      DO 60 I = 1, II
         NUSUMK = NU(1,I)+NU(2,I)+NU(3,I)+NU(4,I)+NU(5,I)+NU(6,I)
         EQK(I) = EQK(I) * PFAC**NUSUMK
   60 CONTINUE
      DO 65 N = 1, NRNU
         RNUSUM = RNU(1,N)+RNU(2,N)+RNU(3,N)+RNU(4,N)+RNU(5,N)+RNU(6,N)
         I = IRNU(N)
         PFR = PFAC ** RNUSUM
         EQK(I) = EQK(I) * PFR
   65 CONTINUE
C
      DO 68 I = 1, II
C
C     RKR=0.0 for irreversible reactions, else RKR=RKF/MAX(EQK,SMALL)
C
         RKRT(I) = 0.D00
         IF (NSPEC(I).GT.0) RKRT(I) = RKFT(I) / DMAX1(EQK(I),SMALL)
   68 CONTINUE
C
C     if reverse parameters have been given:
C
      DO 70 N = 1, NREV
         I = IREV(N)
         RKRT(I) = RPAR(1,N) * DEXP(RPAR(2,N)*ALOGT - RPAR(3,N)/T(1))
         EQK(I)  = RKFT(I)/RKRT(I)
   70 CONTINUE
C
C     if reverse Landau-Teller parameters have been given:
C
      POWR1 = 1.D00/3.D00
      POWR2 = 2.D00/3.D00
      DO 75 N = 1, NRLT
         I = IRLT(N)
         TFAC = RPLT(1,N)/T(1)**POWR1 + RPLT(2,N)/T(1)**POWR2
         RKRT(I) = RKRT(I) * DEXP(TFAC)
   75 CONTINUE
C
C     electron-impact reactions
C
      DO 85 N = 1, NEIM
         I = IEIM(N)
         RKRT(I) = 0.D00
         TEMP = T(ITDEP(N))
         RKFT(I) = PAR(1,I) * DEXP(PAR(2,I) * DLOG(TEMP)
     1             - PAR(3,I)/TEMP)
         PFAC2 = PATM/(RU*TEMP)
         EQK(I) = EQK(I) * (PFAC2/PFAC)**NUSUMK
C
         DO 80 L = 1, NRNU
            IF (IRNU(L) .EQ. I) THEN
               RNUSUM=RNU(1,L)+RNU(2,L)+RNU(3,L)+RNU(4,L)+RNU(5,L)+
     1                RNU(6,L)
               PFR = (PFAC2/PFAC) ** RNUSUM
            ENDIF
   80    CONTINUE
C
         IF (NSPEC(I) .GT. 0) RKRT(I) = RKFT(I)/DMAX1(EQK(I),SMALL)
         DO 83 N2 = 1, NREV
            I2 = IREV(N2)
            IF (I2.EQ.I) THEN
               RKRT(I) = RPAR(1,N2) * DEXP(RPAR(2,N2) *DLOG(TEMP)
     1                       - RPAR(3,N2)/TEMP)
               EQK(I) = RKFT(I)/DMAX1(RKRT(I),SMALL)
            ENDIF
  83     CONTINUE
  85  CONTINUE
C
C      jannev, langer, evans & post - type reactions
C
      DO 95 N = 1, NJAN
         I = IJAN(N)
         RKRT(I) = 0.D00
C
C       CONVERT E- TEMPERATURE TO eV';s
C
         TEMP = T(2)
         TEV = TEMP/ 11600.0D00
     1             - PAR(3,I)/TEMP)
         SUMJ = 0.D00
         DO 90 J = 1, NJAR
            SUMJ = SUMJ + PJAN(J,N) * (DLOG(TEV))**(J-1)
  90     CONTINUE
         RKFT(I) = RKFT(I) * DEXP(SUMJ)
  95  CONTINUE
C
C      reactions using fit&#35;1:  k = A * T^B * exp(v1/T+v2/T^2+v3/T^3...)
C
      DO 105 N = 1, NFT1
         I = IFT1(N)
         RKRT(I) = 0.D00
C
C         CHECK IF REACTION IS ALSO AN ELECTRON-IMPACT REAX
C
         TEMP = T(1)
         DO 100 N2 = 1, NEIM
            IF (IEIM(N2) .EQ. I) TEMP = T(ITDEP(N2))
100     CONTINUE
C
         RKFT(I) = PAR(1,I) * TEMP**PAR(2,I)
         SUMJ = 0.D00
         DO 103 J = 1, NF1R
            ROOTJ = 1.0D00/DFLOAT(J)
            IF (TEMP.GE.BIG**ROOTJ .OR. SUMJ .GE. DLOG(BIG)) THEN
               SUMJ = DLOG(BIG)
            ELSE
               SUMJ = SUMJ + PF1(J,N)/TEMP**DFLOAT(J)
            ENDIF
103     CONTINUE
         IF (SUMJ .GE. DLOG(BIG)) SUMJ = DLOG(BIG)
         RKFT(I) = DMIN1(BIG, RKFT(I) * DEXP(SUMJ))
105  CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKYTCP (P, T, Y, ICKWRK, RCKWRK, C)
C
C  START PROLOGUE
C
C  SUBROUTINE CKYTCP (P, T, Y, ICKWRK, RCKWRK, C)
C     Returns the molar concentrations given the pressure,
C     temperature and mass fractions;  see Eq. (7).
C
C  INPUT
C     P      - Pressure.
C     T      - Temperature.
C                   cgs units - K
C                   cgs units - none
C                   species.
C
C  OUTPUT
C     C      - Molar concentrations of the species.
C                   cgs units - mole/cm**3
C                   Dimension C(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK,K
      DOUBLE PRECISION
     1        C,P,RCKWRK,SUMYOW,T,Y
      DIMENSION ICKWRK(*), RCKWRK(*), Y(*), C(*)
C
      SUMYOW = 0.D00
      DO 150 K = 1, NKK
         SUMYOW = SUMYOW + Y(K) / RCKWRK(NcWT + K - 1)
150   CONTINUE
      SUMYOW = SUMYOW * T * RCKWRK(NcRU)
      DO 200 K = 1, NKK
         C(K) = P * Y(K) / (SUMYOW * RCKWRK(NcWT + K - 1))
200   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKRATX (II, KK, MAXSP, MAXTB, T, C, NU, NUNK, NPAR,
     1                   PAR, NFAL, IFAL, IFOP, KFAL, NFAR, FPAR, NTHB,
     2                   ITHB, NTBS, AIK, NKTB, RKFT, RKRT, RKF, RKR,
     3                   CTB, NRNU, IRNU, RNU, NORD, IORD, MXORD, KORD,
     4                   RORD)
C
C  START PROLOGUE
C
C  SUBROUTINE CKRATX (II, KK, MAXSP, MAXTB, T, C, NU, NUNK, NPAR,
C 1                   PAR, NFAL, IFAL, IFOP, KFAL, NFAR, FPAR, NTHB,
C 2                   ITHB, NTBS, AIK, NKTB, RKFT, RKRT, RKF, RKR,
C 3                   CTB, NRNU, IRNU, RNU, NORD, IORD, MXORD, KORD,
C 4                   RORD)
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER I,IFAL,IFOP,II,IORD,IRNU,ITHB,K,KFAL,KK,KORD,L,MAXSP,
     1        MAXTB,MXORD,N,NFAL,NFAR,NK,NKTB,NORD,NPAR,NRNU,NTBS,
     2        NTHB,NU,NUNK
      DOUBLE PRECISION
     1        AIK,ALOGT,BIG,C,C1,C2,C3,C4,C5,C6,CNK,CPRLOG,CTB,CTOT,
     2        EXPARG,FC,FCENT,FCLOG,FLOG,FPAR,PAR,PCOR,PR,PRLOG,RKF,
     3        RKFT,RKLOW,RKR,RKRT,RNU,RORD,SMALL,T,XN,XP
      DIMENSION C(*), NU(MAXSP,*), NUNK(MAXSP,*), PAR(NPAR,*),
     1          IFAL(*), IFOP(*), KFAL(*), FPAR(NFAR,*), ITHB(*),
     2          NTBS(*), AIK(MAXTB,*), NKTB(MAXTB,*), RKFT(*),
     3          RKRT(*), RKF(*), RKR(*), CTB(*), IRNU(*), RNU(MAXSP,*),
     4          IORD(*), KORD(MXORD,*), RORD(MXORD,*)
C
C
      DO 20 I = 1, II
         CTB(I) = 1.D00
         RKF(I) = 0.D00
         RKR(I) = 0.D00
   20 CONTINUE
C
C     third-body reactions
C
      IF (NTHB .GT. 0) THEN
         CTOT = 0.D00
         DO 10 K = 1, KK
            CTOT = CTOT + C(K)
   10    CONTINUE
         DO 80 N = 1, NTHB
            CTB(ITHB(N)) = CTOT
            DO 80 L = 1, NTBS(N)
               CTB(ITHB(N)) = CTB(ITHB(N))+(AIK(L,N)-1.D00)*C(NKTB(L,N))
   80    CONTINUE
      ENDIF
C
C     If fall-off (pressure correction):
C
      IF (NFAL .GT. 0) THEN
         ALOGT = DLOG(T)
C
         DO 90 N = 1, NFAL
C
            RKLOW = FPAR(1,N) * DEXP(FPAR(2,N)*ALOGT - FPAR(3,N)/T)
C
C        CONCENTRATION OF THIRD BODY
C
            IF (KFAL(N) .EQ. 0) THEN
               PR = RKLOW * CTB(IFAL(N)) / RKFT(IFAL(N))
               CTB(IFAL(N)) = 1.D00
            ELSE
               PR = RKLOW * C(KFAL(N)) / RKFT(IFAL(N))
            ENDIF
C
            PCOR = PR / (1.D00 + PR)
C
            IF (IFOP(N) .GT. 1) THEN
               PRLOG = DLOG10(DMAX1(PR,SMALL))
C
               IF (IFOP(N) .EQ. 2) THEN
C
C              8-PARAMETER SRI FORM
C
                  XP = 1.D00/(1.D00 + PRLOG**2)
                  FC = ((FPAR(4,N)*DEXP(-FPAR(5,N)/T)
     1                   + DEXP(-T/FPAR(6,N))) **XP)
     2                  * FPAR(7,N) * T**FPAR(8,N)
C
               ELSE
C
C              6-PARAMETER TROE FORM
C
                  FCENT = (1.D00-FPAR(4,N)) * DEXP(-T/FPAR(5,N))
     1                  +       FPAR(4,N) * DEXP(-T/FPAR(6,N))
C
C              7-PARAMETER TROE FORM
C
                  IF (IFOP(N) .EQ. 4) FCENT = FCENT + DEXP(-FPAR(7,N)/T)
C
                  FCLOG = DLOG10(DMAX1(FCENT,SMALL))
                  XN    = 0.75D00 - 1.27D00*FCLOG
                  CPRLOG= PRLOG - (0.4D00 + 0.67D00*FCLOG)
                  FLOG = FCLOG/(1.D00 + (CPRLOG/(XN-0.14D00*CPRLOG))**2)
                  FC = 10.D00**FLOG
               ENDIF
               PCOR = FC * PCOR
            ENDIF
C
            RKFT(IFAL(N)) = RKFT(IFAL(N)) * PCOR
            RKRT(IFAL(N)) = RKRT(IFAL(N)) * PCOR
   90    CONTINUE
      ENDIF
C
C     Multiply by the product of reactants and product of products
C     PAR(4,I) is a perturbation factor
C
      DO 150 I = 1, II
         RKFT(I) = RKFT(I) * CTB(I) * PAR(4,I)
         RKRT(I) = RKRT(I) * CTB(I) * PAR(4,I)
C
         IF (NU(1,I) .NE. 0) THEN
            RKF(I) = RKFT(I)*C(NUNK(1,I))**IABS(NU(1,I))
            RKR(I) = RKRT(I)*C(NUNK(4,I))**NU(4,I)
            IF (NUNK(2,I) .NE. 0) THEN
               RKF(I)= RKF(I) * C(NUNK(2,I))**IABS(NU(2,I))
               IF (NUNK(3,I) .NE. 0)
     1         RKF(I) = RKF(I) * C(NUNK(3,I))**IABS(NU(3,I))
            ENDIF
            IF (NUNK(5,I) .NE. 0) THEN
               RKR(I) = RKR(I) * C(NUNK(5,I))**NU(5,I)
               IF (NUNK(6,I) .NE. 0) RKR(I)=RKR(I)*C(NUNK(6,I))**NU(6,I)
            ENDIF
         ENDIF
  150 CONTINUE
C
      DO 160 N = 1, NRNU
         I = IRNU(N)
         C1 = C(NUNK(1,I)) ** DABS(RNU(1,N))
         C4 = C(NUNK(4,I)) ** RNU(4,N)
         RKF(I) = RKFT(I) * C1
         RKR(I) = RKRT(I) * C4
            C2 = C(NUNK(2,I)) ** DABS(RNU(2,N))
            RKF(I) = RKF(I) * C2
            IF (NUNK(3,I) .NE. 0) THEN
               C3 = C(NUNK(3,I)) ** DABS(RNU(3,N))
               RKF(I) = RKF(I) * C3
            ENDIF
         ENDIF
            C5 = C(NUNK(5,I)) ** RNU(5,N)
            RKR(I) = RKR(I) * C5
            IF (NUNK(6,I) .NE. 0) THEN
               C6 = C(NUNK(6,I)) ** RNU(6,N)
               RKR(I) = RKR(I) * C6
            ENDIF
         ENDIF
  160 CONTINUE
C
      DO 200 N = 1, NORD
         I = IORD(N)
         RKF(I) = RKFT(I)
         RKR(I) = RKRT(I)
C
         DO 190 L = 1, MXORD
            NK = KORD(L,N)
            IF (NK .LT. 0) THEN
               NK = IABS(NK)
               CNK = C(NK) ** RORD(L,N)
               RKF(I) = RKF(I) * CNK
            ELSEIF (NK .GT. 0) THEN
               RKR(I) = RKR(I) * CNK
            ENDIF
  190    CONTINUE
  200 CONTINUE
C
      RETURN
      END
C
C        C
      SUBROUTINE CKCPMS (T, ICKWRK, RCKWRK, CPMS)
C
C  START PROLOGUE
C
C  SUBROUTINE CKCPMS (T, ICKWRK, RCKWRK, CPMS)
C     Returns the specific heats at constant pressure in mass units;
C     see Eq. (26).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C
C  OUTPUT
C     CPMS   - Specific heats at constant pressure in mass units
C              for the species.
C                   Dimension CPMS(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK,K,L,N,NA1
      DOUBLE PRECISION
     1        CPMS,RCKWRK,SUM,T,TEMP,TN
      DIMENSION ICKWRK(*), RCKWRK(*), CPMS(*), TN(10)
C
      TN(1) = 1.D00
      DO 150 N = 2, NCP
         TN(N) = T**(N-1)
150   CONTINUE
C
      DO 250 K = 1, NKK
         L = 1
         DO 220 N = 2, ICKWRK(IcNT + K - 1)-1
            TEMP = RCKWRK(NcTT + (K-1)*MXTP + N - 1)
            IF (T .GT. TEMP) L = L+1
220     CONTINUE
C
         NA1 = NcAA + (L-1)*NCP2 + (K-1)*NCP2T
         SUM = 0.D00
         DO 240 N = 1, NCP
            SUM = SUM + TN(N)*RCKWRK(NA1 + N - 1)
  240    CONTINUE
         CPMS(K) = RCKWRK(NcRU) * SUM / RCKWRK(NcWT + K - 1)
C
250   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKHMS  (T, ICKWRK, RCKWRK, HMS)
C
C  START PROLOGUE
C
C  SUBROUTINE CKHMS  (T, ICKWRK, RCKWRK, HMS)
C     Returns the enthalpies in mass units;  see Eq. (27).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C  OUTPUT
C     HMS    - Enthalpies in mass units for the species.
C                   Dimension HMS(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      DOUBLE PRECISION
     1        HMS,RCKWRK,RUT,SUM,T,TEMP,TN
      DIMENSION ICKWRK(*), RCKWRK(*), HMS(*), TN(10)
C
      RUT = T*RCKWRK(NcRU)
      TN(1)=1.D00
      DO 150 N = 2, NCP
         TN(N) = T**(N-1)/N
150   CONTINUE
C
      DO 250 K = 1, NKK
         L = 1
220     CONTINUE
C
         SUM = 0.D00
         DO 225 N = 1, NCP
  225    CONTINUE
         HMS(K) = RUT * (SUM + RCKWRK(NA1 + NCP1 - 1)/T)
     1               / RCKWRK(NcWT + K - 1)
250   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKSMH  (T, ICKWRK, RCKWRK, SMH)
C
C  START PROLOGUE
C
C  SUBROUTINE CKSMH  (T, ICKWRK, RCKWRK, SMH)*
C     Returns the array of entropies minus enthalpies for the species.
C     It is normally not called directly by the user.
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C
C  OUTPUT
C     SMH    - Entropy minus enthalpy for the species,
C              SMH(K) = S(K)/R - H(K)/RT.
C                   cgs units - none
C                   Dimension SMH(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      DOUBLE PRECISION
     1        RCKWRK,SMH,SUM,T,TEMP,TN
      DIMENSION ICKWRK(*), RCKWRK(*), SMH(*), TN(10)
C
      TN(1) = DLOG(T) - 1.D00
      DO 150 N = 2, NCP
         TN(N) = T**(N-1)/((N-1)*N)
150  CONTINUE
C
      DO 250 K = 1, NKK
         L = 1
220     CONTINUE
C
         SUM = 0.D00
         DO 225 N = 1, NCP
  225    CONTINUE
         SMH(K) = SUM + RCKWRK(NA1 + NCP2 - 1)
     1                - RCKWRK(NA1 + NCP1 - 1)/T
C
250  CONTINUE
      RETURN
      END
C
C        C
      FUNCTION IPPLEN (LINE)
C
C  BEGIN PROLOGUE
C
C  FUNCTION IPPLEN (LINE)
C     Returns the effective length of a character string, i.e.,
C     the index of the last character before an exclamation mark (!)
C     indicating a comment.
C
C  INPUT
C     LINE  - A character string.
C
C  OUTPUT
C     IPPLEN - The effective length of the character string.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER IFIRCH,ILASCH,IN,IPPLEN
      CHARACTER LINE*(*)
C
      IN = IFIRCH(LINE)
      IF (IN.EQ.0 .OR. LINE(IN:IN) .EQ. ';!';) THEN
         IPPLEN = 0
      ELSE
         IN = INDEX(LINE,';!';)
         IF (IN .EQ. 0) THEN
            IPPLEN = ILASCH(LINE)
         ELSE
            IPPLEN = ILASCH(LINE(:IN-1))
         ENDIF
      ENDIF
      RETURN
      END
C
C        C
      FUNCTION IFIRCH   (STRING)
C   BEGIN PROLOGUE  IFIRCH
C   DATE WRITTEN   850626
C   REVISION DATE  850626
C   CATEGORY NO.  M4.
C   KEYWORDS  CHARACTER STRINGS,SIGNIFICANT CHARACTERS
C   AUTHOR  CLARK,G.L.,GROUP C-3 LOS ALAMOS NAT';L LAB
C   PURPOSE  Determines first significant (non-blank) character
C            in character variable
C   DESCRIPTION
C
C-----------------------------------------------------------------------
C  IFIRCH locates the first non-blank character in a string of
C  arbitrary length.  If no characters are found, IFIRCH is set = 0.
C  When used with the companion routine ILASCH, the length of a string
C  can be determined, and/or a concatenated substring containing the
C  significant characters produced.
C
C   REFERENCES  (NONE)
C   ROUTINES CALLED  (NONE)
C   END PROLOGUE IFIRCH
      IMPLICIT NONE
C
      INTEGER I,IFIRCH,NLOOP
      CHARACTER* (*)STRING
C
C   FIRST EXECUTABLE STATEMENT IFIRCH
      NLOOP = LEN(STRING)
C
      IF (NLOOP.EQ.0 .OR. STRING.EQ.'; ';) THEN
         IFIRCH = 0
         RETURN
      ENDIF
C
      DO 100 I = 1, NLOOP
         IF (STRING(I:I) .NE. '; ';) GO TO 120
100   CONTINUE
C
      IFIRCH = 0
      RETURN
120   CONTINUE
      IFIRCH = I
      END
C
      FUNCTION ILASCH   (STRING)
C   BEGIN PROLOGUE  ILASCH
C   CATEGORY NO.  M4.
C   PURPOSE  Determines last significant (non-blank) character
C   DESCRIPTION
C
C  IFIRCH locates the last non-blank character in a string of
C  arbitrary length.  If no characters are found, ILASCH is set = 0.
C  When used with the companion routine IFIRCH, the length of a string
C  Note that the FORTRAN intrinsic function LEN returns the length
C  of a character string as declared, rather than as filled.  The
C  declared length includes leading and trailing blanks, and thus is
C  not useful in generating ';significant'; substrings.
C
C   REFERENCES  (NONE)
      IMPLICIT NONE
C
      INTEGER I,ILASCH,NLOOP
      CHARACTER*(*) STRING
C
C   FIRST EXECUTABLE STATEMENT ILASCH
      NLOOP = LEN(STRING)
         ILASCH = 0
         RETURN
      ENDIF
C
      DO 100 I = NLOOP, 1, -1
         ILASCH = I
         IF (STRING(I:I) .NE. '; ';) RETURN
100   CONTINUE
C
      END
C
C        C
      SUBROUTINE CKNCF  (MDIM, ICKWRK, RCKWRK, NCF)
C
C  START PROLOGUE
C
C  SUBROUTINE CKNCF  (MDIM, ICKWRK, RCKWRK, NCF)
C     Returns the elemental composition of the species
C
C  INPUT
C     MDIM   - First dimension of the two-dimensional array NCF;
C              MDIM must be equal to or greater than the number of
C              elements, MM.
C
C  OUTPUT
C     NCF    - Matrix of the elemental composition of the species;
C              NCF(M,K) is the number of atoms of the Mth element
C              in the Kth species.
C                   Dimension NCF(MDIM,*) exactly MDIM (at least MM,
C                   the total number of elements in the problem) for
C                   the first dimension and at least KK, the total
C                   number of species, for the second.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK,J,K,M,MDIM,NCF
      DOUBLE PRECISION
     1        RCKWRK
      DIMENSION ICKWRK(*), RCKWRK(*), NCF(MDIM,*)
C
      DO 150 K = 1, NKK
         J = IcNC + (K-1)*NMM
         DO 150 M = 1, NMM
            NCF(M,K) = ICKWRK(J + M - 1)
150   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKXNUM (LINE, NEXP, LOUT, NVAL, RVAL, KERR)
C
C  START PROLOGUE
C
C  SUBROUTINE CKXNUM (LINE, NEXP, LOUT, NVAL, RVAL, KERR)
C     This subroutine is called to parse a character string, LINE,
C     that is composed of several blank-delimited substrings.
C     Each substring is expected to represent a number, which
C     is converted to entries in the array of real numbers, RVAL(*).
C     NEXP is the number of values expected, and NVAL is the
C     number of values found.  This allows format-free input of
C     numerical data.  For example:
C
C     input:  LINE    = " 0.170E+14 0 47780.0"
C             NEXP    = 3, the number of values requested
C             LOUT    = 6, a logical unit number on which to write
C                       diagnostic messages.
C     output: NVAL    = 3, the number of values found
C             RVAL(*) = 1.700E+13, 0.000E+00, 4.778E+04
C             KERR    = .FALSE.
C
C  INPUT
C                   Data type - CHARACTER*80
C     NEXP   - Number of real values to be found in character string.
C              If NEXP is negative, then IABS(NEXP) values are
C              expected.  However, it is not an error condition,
C              if less values are found.
C
C  OUTPUT
C     NVAL   - Number of real values found in character string.
C     RVAL   - Array of real values found.
C                   Dimension RVAL(*) at least NEXP
C     KERR   - Error flag;  syntax or dimensioning error results
C              in KERR = .TRUE.
C
C  END PROLOGUE
C
C     A ';!'; will comment out a line, or remainder of the line.
C
      IMPLICIT NONE
C
      INTEGER IERR,ILEN,IPPLEN,LOUT,N,NEXP,NVAL
      DOUBLE PRECISION
     1        RTEMP,RVAL
      CHARACTER LINE*(*), ITEMP*80
      DIMENSION RVAL(*), RTEMP(80)
      LOGICAL KERR
C
C----------Find Comment String (! signifies comment)
C
      ILEN = IPPLEN(LINE)
      NVAL = 0
      KERR = .FALSE.
C
      IF (ILEN .LE. 0) RETURN
      IF (ILEN .GT. 80) THEN
         WRITE (LOUT,*)     '; Error in CKXNUM...line length > 80 ';
         WRITE (LOUT,';(A)';) LINE
         KERR = .TRUE.
         RETURN
      ENDIF
C
      ITEMP = LINE(:ILEN)
      IF (NEXP .LT. 0) THEN
         CALL IPPARR (ITEMP, -1, NEXP, RTEMP, NVAL, IERR, LOUT)
      ELSE
         CALL IPPARR (ITEMP, -1, -NEXP, RTEMP, NVAL, IERR, LOUT)
         IF (IERR .EQ. 1) THEN
            WRITE (LOUT, *)    '; Syntax errors in CKXNUM...';
            KERR = .TRUE.
         ELSEIF (NVAL .NE. NEXP) THEN
            WRITE (LOUT,*) '; Error in CKXNUM...';
            KERR = .TRUE.
            WRITE (LOUT,*) NEXP,'; values expected, ';,
     1                     NVAL,'; values found.';
         ENDIF
      ENDIF
      IF (NVAL .LE. IABS(NEXP)) THEN
         DO 20 N = 1, NVAL
            RVAL(N) = RTEMP(N)
   20    CONTINUE
      ENDIF
C
      RETURN
      END
C
C        C
      SUBROUTINE IPPARR (STRING,ICARD,NEXPEC,RVAL,NFOUND,IERR,LOUT)
C   BEGIN PROLOGUE  IPPARR
C   REFER TO  IPGETR
C   DATE WRITTEN  850625   (YYMMDD)
C   REVISION DATE 851625   (YYMMDD)
C   CATEGORY NO.  J3.,J4.,M2.
C   KEYWORDS  PARSE
C   PURPOSE  Parses real variables from a character variable.  Called
C            by IPGETR, the IOPAK routine used for interactive input.
C   DESCRIPTION
C
C  IPPARR may be used for parsing an input record that contains real
C  values, but was read into a character variable instead of directly
C  into real variables.
C  The following benefits are gained by this approach:
C    - specification of only certain elements of the array is allowed,
C      thus letting the others retain default values
C    - variable numbers of values may be input in a record, up to a
C      specified maximum
C    - control remains with the calling program in case of an input
C      error
C    - diagnostics may be printed by IPPARR to indicate the nature
C      of input errors
C
C   The contents of STRING on input indicate which elements of RVAL
C   are to be changed from their entry values, and values to which
C   they should be changed on exit.  Commas and blanks serve as
C   delimiters, but multiple blanks are treated as a single delimeter.
C   Thus, an input record such as:
C     ';   1.,   2,,4.e-5   , ,6.e-6';
C   is interpreted as the following set of instructions by IPGETR:
C
C     (1) set RVAL(1) = 1.0
C     (2) set RVAL(2) = 2.0
C     (3) leave RVAL(3) unchanged
C     (4) set RVAL(4) = 4.0E-05
C     (5) leave RVAL(5) unchanged
C     (6) set RVAL(6) = 6.0E-06
C
C   IPPARR will print diagnostics on the default output device, if
C   desired.
C
C   IPPARR is part of IOPAK, and is written in ANSI FORTRAN 77
C
C   Examples:
C
C      Assume RVAL = (0., 0., 0.) and NEXPEC = 3 on entry:
C
C   input string           RVAL on exit            IERR    NFOUND
C   -------------          ----------------------  ----    ------
C  ';  2.34e-3,  3 45.1';    (2.34E-03, 3.0, 45.1)     0       3
C  ';2,,3.-5';               (2.0, 0.0, 3.0E-05)       0       3
C  ';,1.4,0.028E4';          (0.0, 1.4, 280.0)         0       3
C  ';1.0, 2.a4, 3.0';        (1.0, 0.0, 0.0)           1       1
C  ';1.0';                   (1.0, 0.0, 0.0)           2       1
C
C      Assume RVAL = (0.,0.,0.,0.) and NEXPEC = -4 on entry:
C
C  ';1.,2.';                 (1.0, 2.0)                0       2
C  ';,,3  4.0';              (0.0, 0.0, 3.0, 4.0)      0       4
C  ';1,,3,,5.0';             (0.0, 0.0, 3.0, 0.0)      3       4
C
C  arguments: (I=input,O=output)
C  -----------------------------
C  STRING (I) - the character string to be parsed.
C
C  ICARD  (I) - data statement number, and error processing flag
C         < 0 : no error messages printed
C         = 0 : print error messages, but not ICARD
C         > 0 : print error messages, and ICARD
C
C  NEXPEC (I) - number of real variables expected to be input.  If
C         < 0, the number is unknown, and any number of values
C         between 0 and abs(nexpec) may be input.  (see NFOUND)
C
C  PROMPT (I) - prompting string, character type.  A question
C         mark will be added to form the prompt at the screen.
C
C  RVAL (I,O) - the real value or values to be modified.  On entry,
C       the values are printed as defaults.  The formal parameter
C       corresponding to RVAL must be dimensioned at least NEXPEC
C       in the calling program if NEXPEC > 1.
C
C  NFOUND (O) - the number of real values represented in STRING,
C         only in the case that there were as many or less than
C         NEXPEC.
C
C  IERR (O) - error flag:
C       = 0 if no errors found
C       = 1 syntax errors or illegal values found
C       = 2 for too few values found (NFOUND < NEXPEC)
C       = 3 for too many values found (NFOUND > NEXPEC)
C
C   REFERENCES  (NONE)
C   ROUTINES CALLED  IFIRCH,ILASCH
C   END PROLOGUE  IPPARR
      IMPLICIT NONE
C
      INTEGER IBS,ICARD,IE,IERR,IES,ILASCH,LOUT,NC,NCH,NEXP,NEXPEC,
     1        NFOUND
      DOUBLE PRECISION
     1        RVAL
      CHARACTER STRING*(*), ITEMP*80
      DIMENSION RVAL(*)
      CHARACTER *8 FMT(16)
      LOGICAL OKINCR
C
C   FIRST EXECUTABLE STATEMENT  IPPARR
      IERR   = 0
      NFOUND = 0
      NEXP = IABS(NEXPEC)
      IE = ILASCH(STRING)
      IF (IE .EQ. 0) GO TO 500
      NC = 1
C
C--- OKINCR is a flag that indicates it';s OK to increment
C--- NFOUND, the index of the array into which the value
C--- should be read.  It is set negative when a space follows
C--- a real value substring, to keep incrementing from
C--- occurring if a comma should be encountered before the
C--- next value.
C
      OKINCR = .TRUE.
C
C--- begin overall loop on characters in string
C
100   CONTINUE
C
      IF (STRING(NC:NC) .EQ. ';,';) THEN
         IF (OKINCR) THEN
            NFOUND = NFOUND + 1
         ELSE
            OKINCR = .TRUE.
         ENDIF
C
         GO TO 450
      ENDIF
      IF (STRING(NC:NC) .EQ. '; ';) GO TO 450
C
C--- first good character (non-delimeter) found - now find
C--- last good character
C
      IBS = NC
160   CONTINUE
      NC = NC + 1
      IF (NC .GT. IE) GO TO 180
      IF (STRING(NC:NC) .EQ. '; ';)THEN
         OKINCR = .FALSE.
      ELSEIF (STRING(NC:NC) .EQ. ';,';)THEN
         OKINCR = .TRUE.
      ELSE
         GO TO 160
      ENDIF
C
C--- end of substring found - read value into real array
C
180   CONTINUE
      NFOUND = NFOUND + 1
      IF (NFOUND .GT. NEXP) THEN
         IERR = 3
         GO TO 500
      ENDIF
C
      DATA FMT/     '; (E1.0)';, '; (E2.0)';, '; (E3.0)';, '; (E4.0)';,
     1   '; (E5.0)';, '; (E6.0)';, '; (E7.0)';, '; (E8.0)';, '; (E9.0)';,
     2   ';(E10.0)';, ';(E11.0)';, ';(E12.0)';, ';(E13.0)';, ';(E14.0)';,
     3   ';(E15.0)';, ';(E16.0)';/
      IES = NC - 1
      NCH = IES - IBS + 1
      ITEMP = '; ';
      ITEMP = STRING(IBS:IES)
      READ (ITEMP(:NCH), FMT(NCH), ERR = 400) RVAL(NFOUND)
      GO TO 450
400   CONTINUE
      IERR = 1
      GO TO 510
450   CONTINUE
      NC = NC + 1
      IF (NC .LE. IE) GO TO 100
C
500   CONTINUE
      IF (NEXPEC .GT. 0 .AND. NFOUND .LT. NEXP) IERR = 2
510   CONTINUE
C
      IF (IERR .EQ. 0 .OR. ICARD .LT. 0) RETURN
      IF (ICARD .NE. 0) WRITE(LOUT,';(A,I3)';)
     1   ';!! ERROR IN DATA STATEMENT NUMBER';, ICARD
      IF (IERR .EQ. 1) WRITE(LOUT,';(A)';)';SYNTAX ERROR, OR ILLEGAL VALUE';
      IF (IERR .EQ. 2) WRITE(LOUT,';(A,I2, A, I2)';)
     1   '; TOO FEW DATA ITEMS.  NUMBER FOUND = '; , NFOUND,
     2   ';  NUMBER EXPECTED = ';, NEXPEC
      IF (IERR .EQ. 3) WRITE(LOUT,';(A,I2)';)
     1   '; TOO MANY DATA ITEMS.  NUMBER EXPECTED = ';, NEXPEC
      END
C
C        C
      SUBROUTINE CKCPOR (T, ICKWRK, RCKWRK, CPOR)
C
C  START PROLOGUE
C
C  SUBROUTINE CKCPOR (T, ICKWRK, RCKWRK, CPOR)
C     Returns the nondimensional specific heats at constant pressure;
C     see Eq. (19).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C
C  OUTPUT
C     CPOR   - Nondimensional specific heats at constant pressure
C              for the species.
C                   cgs units - none
C                   Dimension CPOR(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      DOUBLE PRECISION
     1        CPOR,RCKWRK,T,TEMP,TN
      DIMENSION ICKWRK(*), RCKWRK(*), TN(10), CPOR(*)
C
      TN(1) = 1.D00
      DO 150 N = 2, NCP
         TN(N) = T**(N-1)
150   CONTINUE
C
      DO 250 K = 1, NKK
         L = 1
220     CONTINUE
C
         CPOR(K) = 0.D00
         DO 250 N = 1, NCP
            CPOR(K) = CPOR(K) + TN(N)*RCKWRK(NA1 + N - 1)
250   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKPY   (RHO, T, Y, ICKWRK, RCKWRK, P)
C
C  START PROLOGUE
C
C  SUBROUTINE CKPY   (RHO, T, Y, ICKWRK, RCKWRK, P)
C     Returns the pressure of the gas mixture given the mass density,
C     temperature and mass fractions;  see Eq. (*).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C                   cgs units - none
C                   species.
C
C  OUTPUT
C     P      - Pressure.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK,K
      DOUBLE PRECISION
     1        Y,RCKWRK,SUMYOW,P,RHO,T
C
      SUMYOW = 0.0
      DO 150 K = 1, NKK
150   CONTINUE
      P = RHO * RCKWRK(NcRU) * T * SUMYOW
      RETURN
      END
C
C        C
      SUBROUTINE CKUMS  (T, ICKWRK, RCKWRK, UMS)
C
C  START PROLOGUE
C
C  SUBROUTINE CKUMS  (T, ICKWRK, RCKWRK, UMS)
C     Returns the internal energies in mass units;  see Eq. (30).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C
C  OUTPUT
C     UMS    - Internal energies in mass units for the species.
C                   Dimension UMS(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK(*),K
      DOUBLE PRECISION
     1        T, RCKWRK(*), UMS(*), RUT
C
      CALL CKHMS (T, ICKWRK, RCKWRK, UMS)
      DO 150 K = 1, NKK
         UMS(K) = UMS(K) - RUT/RCKWRK(NcWT+K-1)
150   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKCVBS (T, Y, ICKWRK, RCKWRK, CVBMS)
C
C  START PROLOGUE
C
C  SUBROUTINE CKCVBS (T, Y, ICKWRK, RCKWRK, CVBMS)
C     Returns the mean specific heat at constant volume in mass units;
C     see Eq. (36).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C                   cgs units - none
C                   species.
C
C  OUTPUT
C     CVBMS  - Mean specific heat at constant volume in mass units.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK(*),K
      DOUBLE PRECISION
     1        T,RCKWRK(*), Y(*), CVBMS
C
      CALL CKCVMS (T, ICKWRK, RCKWRK, RCKWRK(NcK1))
C
      CVBMS = 0.0
      DO 100 K = 1, NKK
         CVBMS = CVBMS + Y(K)*RCKWRK(NcK1 + K - 1)
  100 CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKCVMS (T, ICKWRK, RCKWRK, CVMS)
C
C  START PROLOGUE
C
C  SUBROUTINE CKCVMS (T, ICKWRK, RCKWRK, CVMS)
C     Returns the specific heats at constant volume in mass units;
C     see Eq. (29).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C
C  OUTPUT
C     CVMS   - Specific heats at constant volume in mass units
C              for the species.
C                   Dimension CVMS(*) at least KK, the total number of
C                   species.
C  END PROLOGUE
C
      IMPLICIT NONE
C
      INTEGER ICKWRK(*),K
      DOUBLE PRECISION
     1        T,RCKWRK(*), CVMS(*)
C
      CALL CKCPMS (T, ICKWRK, RCKWRK, CVMS)
C
      DO 150 K = 1, NKK
         CVMS(K) = CVMS(K) - RCKWRK(NcRU) / RCKWRK(NcWT + K - 1)
150   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKHORT (T, ICKWRK, RCKWRK, HORT)
C
C  START PROLOGUE
C
C  SUBROUTINE CKHORT (T, ICKWRK, RCKWRK, HORT)
C     Returns the nondimensional enthalpies;  see Eq. (20).
C
C  INPUT
C     T      - Temperature.
C                   cgs units - K
C
C  OUTPUT
C     HORT   - Nondimensional enthalpies for the species.
C                   cgs units - none
C                   Dimension HORT(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
      IMPLICIT NONE
C
      DOUBLE PRECISION
     x        HORT,RCKWRK,SUM,T,TEMP,TN
      DIMENSION TN(10), HORT(*), ICKWRK(*), RCKWRK(*)
C
      DO 150 N = 1, NCP
         TN(N) = T**(N-1)/N
150   CONTINUE
C
      DO 250 K = 1, NKK
         L = 1
220     CONTINUE
C
         SUM = 0.0
         DO 225 N = 1, NCP
  225    CONTINUE
         HORT(K) = SUM + RCKWRK(NA1 + NCP1 - 1)/T
250   CONTINUE
      RETURN
      END
C
C        C
      SUBROUTINE CKAWT  (ICKWRK, RCKWRK, AWT)
C
C  START PROLOGUE
C
C  SUBROUTINE CKAWT  (ICKWRK, RCKWRK, AWT)
C     Returns the atomic weights of the elements
C
C  INPUT
C
C  OUTPUT
C     AWT    - Atomic weights of the elements.
C                   Dimension AWT(*) at least MM, the total number of
C
C  END PROLOGUE
C
C
      INTEGER ICKWRK(*)
      DOUBLE PRECISION RCKWRK(*), AWT(*)
C
      INTEGER M
C
      DO 100 M = 1, NMM
         AWT(M) = RCKWRK(NcAW + M - 1)
  100 CONTINUE
C
      RETURN
      END
C
C        C
      SUBROUTINE CKWT   (ICKWRK, RCKWRK, WT)
C
C  START PROLOGUE
C
C  SUBROUTINE CKWT   (ICKWRK, RCKWRK, WT)
C     Returns the molecular weights of the species
C
C  INPUT
C
C  OUTPUT
C     WT     - Molecular weights of the species.
C                   Dimension WT(*) at least KK, the total number of
C                   species.
C
C  END PROLOGUE
C
C
      INTEGER ICKWRK(*)
      DOUBLE PRECISION RCKWRK(*), WT(*)
C
      INTEGER K
C
      DO 100 K = 1, NKK
         WT(K) = RCKWRK(NcWT + K - 1)
  100 CONTINUE
C
      RETURN
      END
C
C        C
      SUBROUTINE CKATHM (NDIM1, NDIM2, ICKWRK, RCKWRK, MAXTP, NT, TMP,
     1                   A)
C
C  START PROLOGUE
C
C  SUBROUTINE CKATHM (NDIM1, NDIM2, ICKWRK, RCKWRK, MAXTP, NT, TMP,
C                     A)
C     Returns the coefficients of the fits for thermodynamic properties
C     of the species; see Eqns. (19)-(21).
C
C  INPUT
C     NDIM1  - First dimension of the three-dimensional array of
C              thermodynamic fit coefficients, A; NDIM1 must be at
C              least NCP2, the total number of coefficients for one
C              temperature range.
C     NDIM2  - Second dimension of the three-dimensionalarray of
C              thermodynamic fit coefficients, A; NDIM2 must be at
C              least MXPT-1, the total number of temperature ranges.
C
C  OUTPUT
C     NT     - Number of temperatures used for fitting coefficients of
C              thermodynamic properties for the species.
C                   Dimension NT(*) at least KK, the total number of
C                   species.
C     TMP    - Common temperatures dividing the thermodynamic fits for
C              the species.
C                   cgs units - K
C                   Dimension TMP(MAXT,*) exactly MAXT for the first
C                   dimension (the maximum number of temperatures
C                   allowed for a species) , and at least KK for the
C                   second dimension (the total number of species)
C     A      - Three dimensional array of fit coefficients to the
C              thermodynamic data for the species.
C              The indicies in  A(N,L,K) mean-
C              N = 1,NN are polynomial coefficients in CP/R
C                CP/R(K)=A(1,L,K) + A(2,L,K)*T + A(3,L,K)*T**2 + ...
C              N = NN+1 is a6 in Eq. (20)
C              N = NN+2 is a7 in Eq. (21)
C              L = 1..MXTP-1 is for each temperature range.
C              K  is  the  species index
C                   Dimension A(NPCP2,NDIM2,*) exactly NPCP2 and MXTP-1
C                   for the first and second dimensions and at least
C                   KK for the third.
C
C  END PROLOGUE
C
C
      INTEGER NDIM1, NDIM2, MAXTP, ICKWRK(*), NT(*)
      DOUBLE PRECISION RCKWRK(*), TMP(MAXTP,*), A(NDIM1,NDIM2,*)
C
      INTEGER K,L,NA1,M
      DOUBLE PRECISION SUM
C
      DO 150 K = 1, NKK
         NT(K) = ICKWRK(IcNT + K - 1)
         TMP(MXTP,K) = RCKWRK(NcTT + K*MXTP - 1)
C
         DO 150 L = 1, MXTP-1
            TMP(L,K) = RCKWRK(NcTT + (K-1)*MXTP + L - 1)
            DO 150 M = 1, NCP2
               A(M, L, K) = RCKWRK(NA1 + M - 1)
150   CONTINUE
C
      RETURN
      END
C
发表于 2006-5-11 13:06:02 | 显示全部楼层
chemkin源程序
这是chemkin的库函数,chemkin平衡化学反应的计算有一个专门的程序。
 楼主| 发表于 2006-5-12 09:44:15 | 显示全部楼层
chemkin源程序
我现在想计算内燃机的燃烧,温度、压力、组分等条件给定,均匀混合,然后调用chemkin来计算化学反应,我现在不明白的问题是,只计算反应速率,然后得到组分及能量的改变是否不够?是否还要考虑化学平衡反应的计算?反应速率和化学平衡反应的关系是什么啊?是计算完反应速率后得到新的温度、组分等条件再进行化学平衡反应计算吗?当作是两步?另外你提到那个专门的程序是STANJAN吗?如何找到并使用?
发表于 2006-5-12 18:15:14 | 显示全部楼层
chemkin源程序
个人认为单独考虑反应没有多大的意义,需要与流动问题耦合考虑
发表于 2006-6-20 17:10:35 | 显示全部楼层
chemkin源程序
同意楼上的意见
发表于 2006-6-25 11:33:39 | 显示全部楼层
chemkin源程序
下面引用由knopp在 2006/05/12 09:44am 发表的内容:
我现在想计算内燃机的燃烧,温度、压力、组分等条件给定,均匀混合,然后调用chemkin来计算化学反应,我现在不明白的问题是,只计算反应速率,然后得到组分及能量的改变是否不够?是否还要考虑化学平衡反应的计 ...
平衡反应计算中仅仅用到各组分的物性参数和平衡反应常数,计算结果依赖于当地温度和压力,不会用到化学反应速率参数。通常应用于定常燃烧的计算。
发表于 2006-7-2 00:16:53 | 显示全部楼层
chemkin源程序
请教二楼-chemkin有没有可能模拟煤燃烧有机物的生成
