查看: 6081|回复: 21
终于得到了计算结果
发表于 2002-4-21 10:59:52 | 显示全部楼层 |阅读模式
从NACA0012到NACA0015, 计算状态为Mach = 0.4, 迎角4度。
采用了梯度下降方法,计算了20次,才得到了计算结果。
红线是目标压力分布和翼型,绿线为设计得到的翼型和压力分布曲线。
发表于 2002-4-22 10:45:08 | 显示全部楼层
终于得到了计算结果
翼型为什么这么厚?是不是y方向坐标被放大了?
 楼主| 发表于 2002-4-26 07:36:44 | 显示全部楼层
终于得到了计算结果
翼型确实放大了,这样才可以看出差别。
另外这是基于控制理论所作的翼型反设计,一位朋友把它当作是欧拉方程计算了。
发表于 2002-4-27 21:28:26 | 显示全部楼层
终于得到了计算结果
有个想法:我们可不可以收集一些精彩的算例,加上简单的计算说明(软件、边界条件设定、网格划分等等),就象您这个帖子一样,然后开辟一个专门的栏目供大家欣赏。如果算例比较多的话,我们还可以考虑发行小型电子刊物,这样交流会更充分一些。
 楼主| 发表于 2002-4-28 00:39:18 | 显示全部楼层
终于得到了计算结果
I saw several websites about the verification and validation in CFD, it includes a lot of classical cases for CFD. most time you could find the experimental data and grid data used in CFD, so I think I could do something like that.
发表于 2002-4-28 11:11:23 | 显示全部楼层
终于得到了计算结果
请教 boling2000  ,通风算例在那里啊??
发表于 2002-5-7 17:56:33 | 显示全部楼层
终于得到了计算结果
Nice to see this good result.
As a freshman about design. What kind of restrict parameter was used during design?
Hehe, I just think abuot it, you need not answer this. ;o)
 楼主| 发表于 2002-5-8 00:35:12 | 显示全部楼层
终于得到了计算结果
Actually what I did here is just one reverse design with given pressure distribution. It is just a validation case.
发表于 2002-12-21 22:28:46 | 显示全部楼层
终于得到了计算结果
boling2000请问你说的那个有很多算例的网站名字,例外我得问题描述在换热器的帖子里,我想知道关于通风的算例,thank you
发表于 2002-12-21 22:31:57 | 显示全部楼层
终于得到了计算结果
o,I am from shaanxi province (weinan city),  if you don't mind,let's make friend  so that we studying cfd together.
 楼主| 发表于 2002-12-23 07:02:03 | 显示全部楼层
终于得到了计算结果
The following website belongs to NASA. There are a lot of cfd cases which could be used to verificate and validate your cfd codes.
It includes the following cases:
  Verification Cases:
    Supersonic Wedge
    Laminar Flat Plate
    Shock Tube
    Hypersonic Cylinder
    Hypersonic Ramp
  Validation Cases
    Turbulent Plate
    RAE Airfoil
    S-Duct
    Fraser Diffuser
    Axisymmetric Jet
    Back Step
    MADIC Nozzle
    Ejector Nozzle
    Transonic Diffuser
    ONERA M6 Wing
    MADIC 3D Nozzle
  Examples
    Driven Cavity
    NLR Airfoil w/Flap
发表于 2003-4-11 10:57:38 | 显示全部楼层
终于得到了计算结果
这样很好呀!!!
为什么不开始做呐???
发表于 2003-10-4 18:52:01 | 显示全部楼层
终于得到了计算结果
请问Boling2000,上面你提到的那些算例在NASA网站上的具体地址是什么?谢啦!
发表于 2003-10-4 19:11:22 | 显示全部楼层
终于得到了计算结果
请问Boling2000,你上面提到的算例在NASA上的具体地址是什么?能贴出来吗?
发表于 2003-11-1 21:13:11 | 显示全部楼层
终于得到了计算结果
是啊!!
