查看: 3451|回复: 1
How to use DTF Utility to set VOF_HEAT_ON ?
发表于 2007-1-31 14:11:06 | 显示全部楼层 |阅读模式
when i use flow + heat + VOF module have this error.
登录/注册后可看大图
发表于 2007-2-3 01:09:45 | 显示全部楼层
GUI->tools->special DTF updates
  VOF_HEAT_ON int 1 1
anyway, the version is too old. with version v2004 or higher, there is no such updates, the coupling of heat with VOF is default with energy conserved.
