查看: 4883|回复: 3
请教安装CFDRC出现的问题
发表于 2007-6-5 10:18:32 | 显示全部楼层 |阅读模式
按照破解文件一步步做,安装完毕之后,打开任何一个程序,都提示:YOU must have at least one licensed cfdrc product to run ,,,请教大侠是为何,以前装成功过,这次不知道怎么回事就不行了,,望大家解答
发表于 2007-6-12 20:17:26 | 显示全部楼层
请教安装CFDRC出现的问题
可能是LICENSE文件设置有问题,或者路径设置的问题
发表于 2007-6-12 20:26:34 | 显示全部楼层
请教安装CFDRC出现的问题
楼主的问题解决了没有?  我也遇到这个问题,
发表于 2007-6-13 10:21:12 | 显示全部楼层
请教安装CFDRC出现的问题
2003的license不用设置啊,按照说明装下去就会出现楼主的问题,不知道是怎么回事?
哪位大侠装成功了,说说经验,非常感谢
CFDRC 2003
1.
Run setup and select all options.
When prompted for license
   type select floating.
You will be asked to type in your
   hostname.
If you are not on a domain just type in you
   host name with no other characters.
If your on a domain
   then type in the full qualified path.
See the getting started
   PDF in the root directory of the CD.
2. Install Python.
3. Install MPICH only if you have network with more than two
   computers.
4. Open the crack directory and copy the lservrc file to
   C:\Program Files\CFDRC\V2003\licensing.
5. Reboot and run the program.
6. Optional: Open the tutorial folder and run setup
   to install the tutorial.
