查看: 4939|回复: 3
[求助]CFDRC.2003安装出现的问题
发表于 2007-6-13 10:37:21 | 显示全部楼层 |阅读模式
[这个贴子最后由zhaodahai在 2007/06/13 11:40pm 第 2 次编辑]
CFDRC 2003的安装说明
1.Run setup and select all options.
When prompted for license
   type select floating.
You will be asked to type in your
   hostname.
If you are not on a domain just type in you
   host name with no other characters.
If your on a domain
   then type in the full qualified path.
See the getting started
   PDF in the root directory of the CD.
2. Install Python.
3. Install MPICH only if you have network with more than two
   computers.
4. Open the crack directory and copy the lservrc file to
   C:\Program Files\CFDRC\V2003\licensing.
5. Reboot and run the program.
6. Optional: Open the tutorial folder and run setup
   to install the tutorial.
按照上面的说明走完后,点击:开始\程序\CFDRC2003\CFD-ACE后出现了下面的问题:
"You must have at least one licensed CFDRC product to run CFD-GUI"
大家安装的时候出现了这个问题没有,请问是怎么解决的?
 楼主| 发表于 2007-6-13 22:18:38 | 显示全部楼层
已经搞定
发表于 2007-8-27 08:51:04 | 显示全部楼层
楼主,你是如何解决这个问题的,我也遇到类似的问题啊
发表于 2007-8-28 00:14:00 | 显示全部楼层
建议检查一下Licesense中的hostname(计算机名)相关字节
