查看: 3048|回复: 1
请各位老师帮忙看下我的ACE求解喷雾问题,谢谢
发表于 2008-4-7 13:06:57 | 显示全部楼层 |阅读模式
[这个贴子最后由紫薇星的契约在 2008/04/07 01:09pm 第 1 次编辑]
WARNING in Spray: Max points on parcel trajectory exceeded
      Max points=  2000    Iter=     1    Parcel #     6
      Particle Size=  6.1735E-05   Velocity=   -2.9668E+01    1.5308E+01    4.1573E+00
      Local Gas Velocity=    5.1960E+01    1.0360E+01   -1.9262E+00
      Max points=  2000    Iter=     1    Parcel #    78
      Particle Size=  4.7708E-05   Velocity=   -9.0737E+00   -3.4971E+01   -3.9326E+00
      Local Gas Velocity=    3.9698E+01   -3.0545E+01    7.0886E-01
WARNING in Spray: Spray parcel temperature error. Trajectory terminated.
       Trajectory Point=   320    Iteration=     1    Parcel #     80
  Unusually small spray time step  calculated    13169 times. For the last occurence:
   Velocity time step=   1.0765E-08  Energy time step=   3.8673E-09  Particle diameter=   8.9829E-07
  If diameter is very small, consider  increasing minimum particle diameter.
  Stop Signal Received from User
计算时候出现这个问题是因为什么?
谢谢
发表于 2008-4-8 10:20:23 | 显示全部楼层
喷射粒子最大数量限制及粒子尺寸设置有误(你限制为最多2000,而实际的已超过这个数)。建议先手动算一下这两个参数,然后再设置。
