查看: 4201|回复: 3
[求助]急!!!ACE求解出错,错误代码41,请求高人帮忙
发表于 2008-4-7 23:38:32 | 显示全部楼层 |阅读模式
错误输出:
     CFD-ACE-SOLVER Run Platform Information :
     Run Date           : 04/07/2008 23:13:11
     Run OS             : Windows
     Run OS Release     :
     Run OS Version     :
     Run Machine        : 111D3AEB40E3461
  The current problem is being run in a serial mode.
    Summary of Input Information
    Problem has been setup using : CFD-ACE-GUI
    Model Options
    Shared
    Model Name : rocket1
    Modules : FLOW TURBULENCE
    DTF File Name : rocket1.DTF
    Simulation Number =   1
    Diagnostic : OFF
    Geometry: Three Dimensional
    Iterations =    400
    Time Dependance : Steady
    Output Frequency =    400
    Summary of 3D Grid Data
    Total No. of nodes =  1314492
    No. of tri faces =      478
    No. of quad faces =  3749372
    No. of poly faces =    39255
    Total No. of faces =    3789105
    No. of hexa cells =   1211960
    No. of poly cells =     25418
    Total No. of cells =   1237378
  |                        Summary of Properties                     |
  |  Key No.  |  Zone No.  |  VC Name  |  Mat. Type  | No. of Cells  |
  |       1   |      1     | NoName    |    Fluid    |   1237378     |
         | Property Name | Evaluation Method |    Value     |
         |       Density |   Constant        |    1.161E+00 |
         |     Viscosity |   Constant_Dyn    |    1.846E-05 |
   No epsilon or length-scale provided at BC key =            1
   Epsilon reset to   1.000000000000000E-002
|                       Summary of Solver Control Paramters                   |
| Prop. |  Diff.  |        Solver        |    Relaxation    |      Limits     |
|       |         |  Name  |Sweep|Criter.| Inertial|Linear  |  Min.  | Max.   |
  |     U |2ndOrder | CGS+Pre|   50|1.0E-04|  2.0E-01|   -    |-1.0E+20| 1.0E+20|
  |     V |2ndOrder | CGS+Pre|   50|1.0E-04|  2.0E-01|   -    |-1.0E+20| 1.0E+20|
  |     W |2ndOrder | CGS+Pre|   50|1.0E-04|  2.0E-01|   -    |-1.0E+20| 1.0E+20|
  |P-Corr |    -    | CGS+Pre|  500|1.0E-04|  2.0E-01|   -    |   -    |    -   |
  |     P |    -    |    -   |  -  |   -   |   -     | 1.0E+00|-1.0E+20| 1.0E+20|
  |   Rho |    -    |    -   |  -  |   -   |   -     | 1.0E+00| 1.0E-06| 1.0E+20|
  |    Mu |    -    |    -   |  -  |   -   |   -     | 1.0E+00| 1.0E-10| 1.0E+02|
  | Turb. |Upwind   | CGS+Pre|   50|1.0E-04|  2.0E-01|   -    |    -   |    -   |
  |     K |    -    |    -   |  -  |   -   |   -     |    -   | 1.0E-30| 1.0E+20|
  |     D |    -    |    -   |  -  |   -   |   -     |    -   | 1.0E-30| 1.0E+20|
   Error in dbm_alloc_arr :
   Memory Allocation Problem
   Module Index =            1
   Action String = PERMANENT
   Integer Array Index =           64
   Array Length =      9997139
   Data  Type = REAL
   Error Code Returned =           41
  Error Exit from CFD-ACE-SOLVER
[color=#DC143C]曾经网格比较疏(57万多个)的时候,运算正常;网格增多后(其他参数未变)就出现上述错误
希望达人帮忙,谢谢
发表于 2008-4-8 09:52:08 | 显示全部楼层
内存分配错误——你的内存不足
造成的原因可能两种:一、物理内存少;二 操作系统支持的单进程内存少(32位Windows支持的单进程内存与系统进程占用内存之和最高不超过2G)。
解决办法:一、增加物理内存或减少网格;二、采用Linux或64位Windows系统;三、并行计算。
 楼主| 发表于 2008-4-8 11:04:35 | 显示全部楼层
好的,谢谢,还有一个Viscast网格生成的问题,之前没遇到过,现在网格生成后保存为.dtf格式时不成功,总出现Add X coordinates to dtf failed!!! Length=681723 的警告,怎么解决?谢谢
发表于 2008-4-8 23:59:35 | 显示全部楼层
ACE[br][br][以下内容由 紫薇星的契约 在 2008年04月09日 00:00am 时添加] [br]
ACE的并行计算是不是需要在LUIX下运行?
