查看: 2694|回复: 1
求网格到入问题?
发表于 2005-8-29 18:51:56 | 显示全部楼层 |阅读模式
gambit网格
 楼主| 发表于 2005-8-29 18:54:35 | 显示全部楼层
求网格到入问题?
18.DAT
GUI      >Version: v2003.0.0
FASTRAN  >Version: v2003.0.0
                             FASTRAN Model Name
                             Problem Title
64a210
                    Additional Problem Information
                        Problem Specifications
  NZONES    NCYCLES    STEADY    NEWRUN   AXI-SYM  OVERSET
      1 10000     1     T     F     0
                      Function Definition/Timing
  MOTION_MODELS   START_TIME     END_TIME     PLOTF   FORCE_SUMMARY
      0   0.000D+00   0.100D+03         1       0
  MONITOR_POINTS   FORCE_BY_SECTIONS
                          Cycle Control Flags
  CYC/SOLVE   CYC/PLOT   CYC/CHIMERA   CYC/6DOF   CYC/RESTART
     1     1     5     1  1000
WARNING...WARNING...WARNING
For DTF format, CYC/RESTART   = ABS(CYC/PLOT)
Reset CYC/RESTART = ABS(CYC/PLOT)
                          Tolerances/Debug
  TINY        BIG        GEOMIN       CONVERGENCE
  0.100D-19   0.100D+21   0.100D-19   0.100D-19
                          Tolerances for Chimera Hole Cutting
EPSILON_DIST    EPSILON_AREA    EPSILON_RATIO
  0.100D-13   0.100D-04   0.100D-04
                         Thermo and Transport
Gas_Model
Mol_Weight     Ratio_Specific_Heats     Prt_Lam     Prt_Turb
  0.290D+02   0.140D+01   0.700D+00   0.900D+00
Vis_Model      Suth_Coeff1     Suth_Coeff2     Dyn_Viscosity
      1 0.146D-05   0.112D+03   0.171D-04
                    Zone Control
Zone-Order    Iterations    CFL_Start/dt    CFL_End/dt    Nitcfl
      1     1 0.100D+00   0.100D+01     100
                       Zone      1
Zone   Grid_type  Chimera_type  Moving  T_scheme  N_stage  Inner   Inntol
    1     5     0     0     6     1    20   0.100D-03
Ivisc   Flux   S_scheme   Limit_N   Limit_L   Entf_L    Entf_N    Kappa
    1     1     4     1     1   0.200D+00   0.200D+00   0.333D+00
Init  Re_init
    0     0
U               V               W               p               T
  0.21300D+03   0.61000D+02   0.00000D+00   0.10132D+06   0.30000D+03
k||n              e||w              Tint
  0.00000D+00   0.00000D+00   0.30000D+03
Mixture Number
  0.10000D+01
Error Exit from CFD-FASTRAN
CFD-FASTRAN Error Number :    25
GET_BLOCKAGES:  WARNING
Original Blockage array not detected
using default values of 1
******* Grid Zonal Parameters
--- Zone            1
nface (OBFAC)            -4
nface (INTERI)            0
nface (BOUNDA)           -4
nface (TOTAL)             2
ncell (TOTAL)             1
nnode (TOTAL)             0
                              GRID INFO FOR ZONE #   1
  Grid Type: Quadralaterals/Structured
             I-Dimension   J-Dimension   K-Dimension    Cells
                   0             0             2           1
--- Allocating and Reading IBOUND and QBOUND
*** Allocated  0.000 I-MWords for BC Arrays
*** Allocated  0.000 R-MWords for BC Arrays
*** Initializing Zone   1 with Freestream
--- Allocating Q, XYZ, AREA, VOL
     Allocated  0.000 R-MWords for Zone   1
--- Allocating IBLANK, IFPOIN, ICPOIN, IFCELL
     Allocated  0.000 I-MWords for S-Zone   1
*** Allocated  0.000 R-MWords for Grid Arrays
*** Allocated  0.000 I-MWords for Grid Arrays
