查看: 8193|回复: 11
李湘渝的 Delta Wing 論文
发表于 2006-9-15 06:53:57 | 显示全部楼层 |阅读模式
This is another paper that I presented to AIAA. This one is on delta wing lift and drag calculations.
You may notice that in the aerodynamics field, there is really no established complete theory on delta wings, although many airplanes have used the planform for amny years. The famouse ones are the Concord and the J-7 and J-8 fighters. If you have experimental data to check against my results, please do so.
Particularly missing is the evaluation on non-linear, or vortex lift. The only model that separates such force is the "Leading Edge Suction Analogy" method quoted in the paper. I also pointed out the falacy in that scheme.
On the linear lift and drag evaluation, traditional analysis utilizes the "Slendar Wing Theory". I am not cetain that that theory produce a correct results as the pure potential flow solution is very far off from the overall lift. In addition, the traditional analysis drag polar relationship also gives rediculous results.
As I mentioned before, I hope by presenting my viewpoints and new appraoches, I can inspire a movement within the Chinese fluid/aero experts to thouroughly investigate and clarify this entire field.
发表于 2006-9-22 18:39:06 | 显示全部楼层
李湘渝的 Delta Wing 論文
  Thank you very much
 楼主| 发表于 2006-9-23 04:12:50 | 显示全部楼层
李湘渝的 Delta Wing 論文
I am planning to visit Xian and Suzhou in October (10/13-10/27). Anyone interested please contact me at shiang_yulee@hotmail.com.
发表于 2006-9-26 19:46:17 | 显示全部楼层
李湘渝的 Delta Wing 論文
  可能坛子上搞飞机空气动力学的朋友不多,所以对李先生论文的讨论并不热烈。
发表于 2006-9-26 22:58:30 | 显示全部楼层
李湘渝的 Delta Wing 論文
也可能是没看懂。
发表于 2006-9-27 12:14:25 | 显示全部楼层
李湘渝的 Delta Wing 論文
  欢迎李先生回故乡!
发表于 2006-11-5 15:28:55 | 显示全部楼层
李湘渝的 Delta Wing 論文
为什么每次都说我的盗连
下不来呀
提供论文名也好呀
我们学校这能下AIAA的资料
发表于 2006-11-5 15:44:21 | 显示全部楼层
李湘渝的 Delta Wing 論文
An Analytical Representation of Delta Wing Aerodynamics
发表于 2006-11-10 23:08:15 | 显示全部楼层
李湘渝的 Delta Wing 論文
thank you very much!
发表于 2006-12-24 18:31:37 | 显示全部楼层
李湘渝的 Delta Wing 論文
Thank very much!
发表于 2007-1-6 12:04:00 | 显示全部楼层
李湘渝的 Delta Wing 論文
Thank very much!
发表于 2007-6-18 19:20:01 | 显示全部楼层
李湘渝的 Delta Wing 論文
thanks a lot
