查看: 2474|回复: 2
Simplest way to get "UDF 高级应用技术培训" (zero payment)...
发表于 2006-12-9 02:52:27 | 显示全部楼层 |阅读模式
FLUENT-UDF 高级应用技术培训-实例:
Step_01: Input   "UDF fluent source" in GOOGLE website
Step_02: Yuo will find:
          [PDF] FLUENT-UDF 高级应用技术培训-实例
Step_03: Single hit the mouse right Key, and SAVE.
Please enjoy it!
发表于 2006-12-15 10:57:27 | 显示全部楼层
为什么不直接输:[PDF] FLUENT-UDF 高级应用技术培训-实例,这样来的更直接
 楼主| 发表于 2006-12-15 23:42:35 | 显示全部楼层
Hi,znbiu,
   Thanks very much for your question. Now I would like to ask  you some questions:
  (1) Do you think the suggested method doesn';t work?
       --- Evidently, it is much faster to download via the method.
  (2)  Did you try to download "Fluent_UDF高级应用技术培训实例(很适合UDF高手研究)" publied by POPOLAR?
       -- I paid twice and I got nothing (cannot download it).
  (3) Could you help me confirm whether the PDF you downloaded from POPOLAR is similar to the PDF getten via the method  suggested here?
        -- If similar, then no one needs to pay for that. Furthermore, it is even worse if you paid but got nothing. And in this case I would like you to ask someone to delete that post instead of asking me to upload the same PDF.
       -- If they are not similar, please try first to download the PDF from POPOLAR, and then let me know what is the difference between Popalar';s PDF and the PDF vis Google searching.
I hope that you or some one else who got the "Fluent_UDF高级应用技术培训实例(很适合UDF高手研究)" posted by POPOLAR makes some comments and to clarify these questions.
Thanks for your care.
