查看: 2683|回复: 1
[紧急求助]C++程序链接到Fluent中出现错误
发表于 2007-1-30 10:16:52 | 显示全部楼层 |阅读模式
使用hp270388026开发的软件,前面的工作都已经完成,编译和读入UDF以后,在Fluent的Initialize时总是出现如下问题:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Fluent.Int\Fluent6.2.16\ntx86\3d\fl6216.exe
abnormal program termination.
各位高手知道以下到底出了什么问题呢?
具体程序如下:作为边界条件的UDF
#include "stdafx.h"
//write your include header here......
#include "iostream.h"
#include "stdio.h"
#include "stdlib.h"
#include "math.h"
#include "udf.h"
extern "C"{
DEFINE_PROFILE(boundary_mass_profile, thread, position)
face_t f;
begin_f_loop(f,thread)
  double t=RP_Get_Real("flow-time");
  const double thickness=0.02, time_step=1, delta_y=0.0001, D_wet=2.457e-05, D_dry=7.1e-11, C0=63.2e-6;
  int dim1=thickness/delta_y+1, dim2=t/time_step, j, k=3289;
  double r=time_step/(delta_y*delta_y);
  double** C=new double* [dim1];     /* 开辟浓度数组C,纵向层数dim1,横向时间dim2 */
  for(int i=0;i<dim1;i++)
   C=new double[dim2];
  for(i=0;i<dim1;i++)
   for(j=1;j<dim2;j++)
    C[j]=0.0;
  for(i=0;i<dim1;i++)               /* 设定初始值 */
   C[0]=C0;
  double *b=new double[dim1];      /* 开辟系数数组b,d,beta, Dm数组D, 追赶法中间解数组y*/
  double *d=new double[dim1];      /* 注意:这里系数数组a,c都等于1 */
  double *D=new double[dim1];
  double *y=new double[dim1];
  double *beta=new double[dim1];
  for(i=0;i<dim1;i++)
   b=0.0;
   d=0.0;
   D=0.0;
   y=0.0;
   beta=0.0;
  b[1]=-1.000001;
  d[1]=0.0;
  b[dim1-1]=-1.000001;
  d[dim1-1]=0.0;
// for(j=1;j<dim2;j++)
  for(j=1;j<4;j++)
   beta[1]=1/b[1];
   y[1]=d[1]/b[1];
   for(i=2;i<(dim1-1);i++)
    D=D_wet*pow(C[i-1][j-1]/C0,2)+D_dry*(1-pow(C[i-1][j-1]/C0,2));
    b=-1*(2+1.0/(D*r));
    d=-1*C[j-1]/(D*r);
    beta=1/(b-beta[i-1]);
    y=(d-y[i-1])*beta;
   beta[dim1-1]=1/(b[dim1-1]-beta[dim1-2]);
   y[dim1-1]=(d[dim1-1]-y[dim1-2])*beta[dim1-1];
   C[dim1-1][j]=y[dim1-1];
   for(i=dim1-2;i>0;i--)
    C[j]=y-beta*C[i+1][j];
  for(j=0;j<4;j++)
C[dim1-1][j]/=k;
  delete []beta;
  delete []y;
  delete []D;
  delete []d;
  delete []b;
  delete []C;
  F_PROFILE(f, thread, position)=2.17e-4*(C[dim1-1][j]-C[dim1-1][j-1]);
end_f_loop(f,thread)
发表于 2007-2-3 14:45:43 | 显示全部楼层
如愿意,请讲完整的msh,cas udf工程发送到huangpeng8@163.com
我来看看
