查看: 3699|回复: 4
UDF的快捷编译方式及系统
发表于 2005-9-16 11:58:46 | 显示全部楼层 |阅读模式
大家现在普遍面临fluent中UDF编译不便,这里开发了一个很好的利用VC++的快捷编译系统,需要者请与Eric博士联系。huangpeng8@163.com
This is a demo program of developing fluent UDF by virsual c++
using this software, you can write c++ style udf programs, and you can use standard c++ libraries, MFC, and other C++ libraries if you like.
In the domo program, you can only choose 2d Fluent project, and you can only use DEFINE_ON_DEMAND macro. But in a registered edition, you can choose any type of project and freely use all mocroes supplied by FLUENT coopration .
How to use the program
0 It assumes you have installed FLUENT6.x in C:\fluent.inc directory. if you have install the FLUENT in other dirctory, please reinstall the Fluent again as requirement.
1 choose the type of Fluent project. 2d, 2ddp, 3d,or 3ddp
2 type the FLUENT project directory.also you can choose the directory by click SEARCH button
3 click the START button and will make progam and open the vc++ progam for you,if a vc++6.0 has installed on your computer.
4 in the function.cpp file in the vc++ project, you can write your C++ style program as you like.
5 compile the program to a dll file,Open FLUENT, load a cas file, load the udf dll file, and then you can run the function in it.
The demo program isn';t convenience, but the registered edtion has good qulity.
发表于 2005-9-21 01:57:30 | 显示全部楼层
UDF的快捷编译方式及系统
哪里可以下载demo?
发表于 2005-9-21 10:22:22 | 显示全部楼层
UDF的快捷编译方式及系统
[这个贴子最后由hp270388026在 2005/09/22 07:03pm 第 3 次编辑]
  http://www.fegensoft.com/phpwind/read.php?tid=1548&fpage=1
到那里下载去吧
发表于 2005-9-22 19:00:33 | 显示全部楼层
UDF的快捷编译方式及系统
到那里下载去吧
发表于 2005-9-26 03:05:45 | 显示全部楼层
UDF的快捷编译方式及系统
在http://219.232.54.3/cgi-bin/LB5000/topic.cgi?forum=51&topic=48&show=0
中,有一个用vc开发的例子
