查看: 2552|回复: 2
[原创]
发表于 2007-8-16 09:41:32 | 显示全部楼层 |阅读模式
[watermark]Tin;为固体内节点温度
T ;为固体表面温度
T;(t)为环境温度
DEFINE_PROFILE(T_profile, t, i)
real pi=3.14;
face_t tf;
cell_t c0;
Thread *t0;
real time=RP_Get_Real("flow-time");
real T_t=273.15+0.33+4.55*(0.96*sin(2*pi*(time-9)/24)+0.14*sin(4*pi*(time-9)/24));/*insert the function of time-dependent outdoor air temperature*/
real U_t=1.4; /*insert the function of time-dependent outdoor air moisture potential*/
real A1_ext=lambda_1/Dgrid+hq_1, A1_int=lambda_4/Dgrid+hq_4; /*T boundary equation coefficient*/
real C1_ext, C1_int, C2_ext, C2_int;
    begin_f_loop(tf, t)
   real xw[ND_ND];
               F_CENTROID(xw,tf,t);
   c0=F_C0(tf, t);
               t0=F_C0_THREAD(tf, t);
   C1_ext=lambda_1*C_UDSI(c0,t0,Temp)/Dgrid+hq_1*T_t; /*T boundary equation constant*/
   C1_int=lambda_4*C_UDSI(c0,t0,Temp)/Dgrid+hq_1*T_indoor; /*T boundary equation constant*/
   if(xw[0]<=x1+0.25*Dgrid) F_PROFILE(tf, t, i)=C1_ext/A1_ext;
               else if(xw[0]>=x2-0.25*Dgrid) F_PROFILE(tf, t, i)=C1_int/A1_int;
    end_f_loop(tf, t)
 楼主| 发表于 2007-8-20 12:41:57 | 显示全部楼层
[原创]
没人回复啊 ?
 楼主| 发表于 2007-8-26 13:32:56 | 显示全部楼层
[原创]
高手帮帮忙啊?
