查看: 5912|回复: 2
Define_Grid_Motion宏例子求助,网格不动,在线等!
发表于 2006-8-21 17:14:22 | 显示全部楼层 |阅读模式
#include "udf.h"
DEFINE_GRID_MOTION(BEAM,domain,dt,time,dtime)
  Thread *tf = DT_THREAD(dt);
  face_t f;
  Node *v;
  real NV_VEC(omega), NV_VEC(axis), NV_VEC(dx);
  real NV_VEC(origin), NV_VEC(rvec);
  real sign;
  int n;
  /* set deforming flag on adjacent cell zone */
  SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
  sign = -10.0 * sin (8* M_PI * time);
  Message ("time = %f, omega = %f\n", time, sign);
  NV_S(omega, =, 0.0);
  NV_D(axis, =, 0.0, 0.0, 1.0);
  NV_D(origin, =, 0.0, 0.0, 0.0);
  begin_f_loop(f,tf)
      f_node_loop(f,tf,n)
          v = F_NODE(f,tf,n);
          /* update node if x position is greater than 0.02
             and that the current node has not been previously
             visited when looping through previous faces */
          if (NODE_Y(v) > 0.020 && NODE_POS_NEED_UPDATE (v))
              /* indicate that node position has been update
                 so that it';s not updated more than once */
              NODE_POS_UPDATED(v);
              omega[2] = sign * pow (NODE_Y(v), 0.5);
              NV_VV(rvec, =, NODE_COORD(v), -, origin);
              NV_CROSS(dx, omega, rvec);
              NV_S(dx, *=, dtime);
              NV_V(NODE_COORD(v), +=, dx);
  end_f_loop(f,tf);
这个UDF和帮助中给的基本一样,只是我将角速度定义为OMGAE[2],悬臂梁在Y轴上,网格建立在XoY平面,见图所示。计算的过程中发现网格没有动,请帮忙!
计算域:x[-0.2m,0.8m] y[0,0.5m]
梁的尺寸:宽8mm,高0.1m,宽度中点位于坐标原点
 楼主| 发表于 2006-8-22 12:12:05 | 显示全部楼层
omga[2]表示绕Z轴旋转,水平方向X,竖值方向Y,垂直纸面向外为Z轴
 楼主| 发表于 2006-9-4 13:03:35 | 显示全部楼层
高手请帮忙!
