查看: 25555|回复: 6
OpenFOAM 标准求解器
发表于 2009-2-10 21:52:18 | 显示全部楼层 |阅读模式
An extensive set of OpenFOAM solvers has evolved (and is forever growing) that are available to users.
OpenFOAM is used mainly for CFD but has found use in other areas such as stress analysis, electromagnetics and finance because it is fundamentally a tool for solving partial differential equations rather than a CFD package in the traditional sense.
Below is a list of solvers available to our users.
‘Basic’ CFD codes
laplacianFoam    Solves a simple Laplace equation, e.g. for thermal diffusion in a solid
potentialFoam    Simple potential flow solver which can be used to generate starting fields for full Navier-Stokes codes
scalarTransportFoam   Solves a transport equation for a passive scalar
Incompressible flow
boundaryFoam   Steady-state solver for 1D turbulent flow, typically to generate boundary layer conditions at an inlet, for use in a simulation.
channelOodles   Incompressible LES solver for flow in a channel
icoDyMFoam      Transient solver for incompressible, laminar flow of Newtonian fluids with dynamic mesh
icoFoam            Transient solver for incompressible, laminar flow of Newtonian fluids
nonNewtonianIcoFoam     Transient solver for incompressible, laminar flow of non-Newtonian fluids
oodles               Incompressible LES solver
simpleFoam      Steady-state solver for incompressible, turbulent flow of non-Newtonian fluids
turbDyMFoam   Transient solver for incompressible, turbulent flow of Newtonian fluids with dynamic mesh
turbFoam          Transient solver for incompressible, turbulent flow
Compressible flow   ----------------------------------------------------------------------------------------------------------------------------------------------------------------
coodles   Compressible LES solver
rhoCentralFoam   Density-based compressible flow solver based on central-upwind schemes
rhoPimpleFoam    Transient solver for turbulent flow of compressible fluids for ventilation and heat-transfer
rhoPorousSimpleFoam    Steady-state solver for turbulent flow of compressible fluids with implicit or explicit porosity treatment
rhopSonicFoam  Pressure-density-based compressible flow solver
rhoSimpleFoam  Steady-state solver for turbulent flow of compressible fluids for ventilation and heat-transfer
rhoSonicFoam    Density-based compressible flow solver
rhoTurbFoam      Transient solver for compressible, turbulent flow
sonicFoam          Transient solver for trans-sonic/supersonic, laminar flow of a compressible gas.
sonicFoamAutoMotion    Transient solver for trans-sonic/supersonic, laminar flow of a compressible gas with mesh motion
sonicLiquidFoam    Transient solver for trans-sonic/supersonic, laminar flow of a compressible liquid
sonicTurbFoam     Transient solver for trans-sonic/supersonic, turbulent flow of a compressible gas
Multiphase flow
bubbleFoam    Solver for a system of 2 incompressible fluid phases with one phase dispersed, e.g. gas bubbles in a liquid
compressibleLesInterFoam   Solver for 2 compressible, isothermal immiscible fluids using a volume of fluid (VOF) phase-fraction based interface capturing approach, with LES
interDyMFoam     Solver for 2 incompressible fluids, which captures the interface using a VOF method with optional mesh motion
interFoam           Solver for 2 incompressible fluids, which captures the interface using a VOF method
interPhaseChangeFoam     Solver for 2 incompressible, isothermal immiscible fluids with phase-change, e.g. cavitation, using a VOF method
lesCavitatingFoam   Transient cavitation code with LES turbulence
lesInterFoam        Solver for 2 incompressible fluids capturing the interface. Turbulence is modelled using a runtime selectable incompressible LES model
multiphaseInterFoam   Solver for an arbitrary number of incompressible immiscible fluids, capturing the multiple interfaces using a VOF method
rasCavitatingFoam     Transient cavitation code with RAS turbulence
rasInterFoam      Solver for 2 incompressible fluids capturing the interface. Turbulence is modelled using a runtime selectable incompressible RAS model
settlingFoam        Solver for 2 incompressible fluids for simulating the settling of the dispersed phase
twoLiquidMixingFoam       Solver for mixing 2 incompressible fluids
twoPhaseEulerFoam         Solver for a system of 2 incompressible fluid phases with one phase dispersed, e.g. gas bubbles in a liquid
Direct numerical simulation (DNS) and large eddy simulation (LES)
dnsFoam    Direct numerical simulation solver for boxes of isotropic turbulence
Combustion
coldEngineFoam    Solver for cold-flow in internal combustion engines
dieselEngineFoam   Diesel engine spray and combustion code
dieselFoam           Diesel spray and combustion code
engineFoam       Solver for internal combustion engines
PDRFoam            compressible premixed/partially-premixed turbulent combustion solver that includes porosity/distributed resistance (PDR) modelling to handle regions containing solid blockages that cannot be resolved by the mesh
reactingFoam       Chemical reaction code
XiFoam                Compressible premixed/partially-premixed combustion solver with turbulence modelling
Xoodles                Compressible premixed/partially-premixed combustion solver with large-eddy simulation (LES) turbulence modelling
Heat transfer
buoyantFoam  Transient Solver for buoyant, turbulent flow of compressible fluids for ventilation and heat-transfer
buoyantSimpleFoam   Steady-state solver for buoyant, turbulent flow of compressible fluids for ventilation and heat-transfer
buoyantSimpleRadiationFoam  Steady-state solver for buoyant, turbulent flow of compressible fluids with radiation, for ventilation and heat-transfer
chtMultiRegionFoam     Solver that couples conjugate heat transfer in a solid to a buoyancy-driven flow simulation
lesBuoyantFoam           Transient solver for buoyant, turbulent flow of compressible fluids for ventilation and heat-transfer with LES turbulence modelling
Electromagnetics
electrostaticFoam   Solver for electrostatics
mhdFoam               Solver for magnetohydrodynamics (MHD): incompressible, laminar flow of a conducting fluid under the influence of a magnetic field
Stress analysis of solids
solidDisplacementFoam    Transient segregated finite-volume solver of linear-elastic, small-strain deformation of a solid body, with optional thermal diffusion and thermal stresses
solidEquilibriumDisplacementFoam    Steady-state segregated finite-volume solver of linear-elastic, small-strain deformation of a solid body
Finance
financialFoam  Solves the Black-Scholes equation to price commodities
Table 1:  Standard library solvers.
[ 本帖最后由 OpenFOAM 于 2009-2-10 21:55 编辑 ]
发表于 2009-2-25 19:11:56 | 显示全部楼层
我下载了一个linux版本的  不知道有没有windows版本的
[ 本帖最后由 ch06 于 2009-2-25 13:39 编辑 ]
发表于 2009-4-14 22:54:11 | 显示全部楼层
回复 2# ch06 的帖子
好像没有,openfoam目前只是在linux下开发的。
发表于 2009-5-25 23:39:19 | 显示全部楼层
不是好像,就是没有,而且目前没有移植到windows下的打算。
发表于 2009-5-26 14:22:41 | 显示全部楼层
windows版可以参考这里
http://www.cfluid.com/?uid-4654-action-viewspace-itemid-1583
http://openfoam-mswin.sourceforge.net/
不过没看到开发人员,应该不是官方版。
发表于 2009-5-26 18:48:32 | 显示全部楼层
长见识了
发表于 2011-9-8 11:27:26 | 显示全部楼层
请教openfoam实用性问题
各位好:我想问一下,对于可压缩流体的气动燃烧情况,openfoam是否能够适用啊?
