查看: 7857|回复: 3
请问:CFX出这种错误的原因是什么?
发表于 2009-3-3 14:00:18 | 显示全部楼层 |阅读模式
| The ANSYS CFX solver could not be started, or exited with return   |
| code 255: .  No results file has been created.                     |
End of solution stage.
|                An error has occurred in cfx5solve:                 |
| Error reported by IO module: setfilebusyflag: more than one user   |
| is reading                                                         |
| G:\CFX_working\anshan\roughness_Nu\EAF_roughness_001_001.dir\crash |
| or the wrong lock file                                             |
| G:\CFX_working\anshan\roughness_Nu\EAF_roughness_001_001.dir\cras- |
| h.lck exists                                                       |
| Error reported by IO module: iocnt: setfilebusyflag failed when    |
| writing a data set                                                 |
| Error from IO module while writing G/MON:EVERY:8:                  |
|  "iocnt: setfilebusyflag failed when writing a data set"           |
| IO_LOCKED(21): File is locked.  Remove the lock (lck) file if this |
| shouldn't be the case.                                             |
|                              Warning!                              |
| The ANSYS CFX Solver has written a crash recovery file.  This file |
| has been saved as                                                  |
| G:\CFX_working\anshan\roughness_Nu\EAF_roughness_001_001.res.err   |
| and may be an aid to diagnosing the problem or restarting the run. |
| More details should be available in the solver output section of   |
| the output file.  Note that a lock file was left for the crash     |
| file when the solver exited, and so it is probably incomplete.     |
| The following user files have been saved in the directory          |
| G:\CFX_working\anshan\roughness_Nu\EAF_roughness_001_001:          |
| mon        |
发表于 2009-3-9 13:04:12 | 显示全部楼层
我也有类似的错误,不知道怎么回事啊
发表于 2011-9-24 20:43:38 | 显示全部楼层
| code 255 我也有这种问题!
发表于 2011-9-26 02:03:42 | 显示全部楼层
可能是设置有问题,
好好检查。
