查看: 8292|回复: 2
请问:CFX出这种错误的原因是什么?
发表于 2009-3-3 14:01:28 | 显示全部楼层 |阅读模式
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| Floating point exception: Overflow                                 |
| The ANSYS CFX solver could not be started, or exited with return   |
| code 255: .  No results file has been created.                     |
End of solution stage.
|                An error has occurred in cfx5solve:                 |
| Error reported by IO module: setfilebusyflag: more than one user   |
| is reading                                                         |
| G:\CFX_working\anshan\roughness_Nu\EAF_roughness_001_001.dir\crash |
| or the wrong lock file                                             |
| G:\CFX_working\anshan\roughness_Nu\EAF_roughness_001_001.dir\cras- |
| h.lck exists                                                       |
| Error reported by IO module: iocnt: setfilebusyflag failed when    |
| writing a data set                                                 |
| Error from IO module while writing G/MON:EVERY:8:                  |
|  "iocnt: setfilebusyflag failed when writing a data set"           |
| IO_LOCKED(21): File is locked.  Remove the lock (lck) file if this |
| shouldn't be the case.                                             |
|                              Warning!                              |
| The ANSYS CFX Solver has written a crash recovery file.  This file |
| has been saved as                                                  |
| G:\CFX_working\anshan\roughness_Nu\EAF_roughness_001_001.res.err   |
| and may be an aid to diagnosing the problem or restarting the run. |
| More details should be available in the solver output section of   |
| the output file.  Note that a lock file was left for the crash     |
| file when the solver exited, and so it is probably incomplete.     |
| The following user files have been saved in the directory          |
| G:\CFX_working\anshan\roughness_Nu\EAF_roughness_001_001:          |
| mon        |
发表于 2009-3-4 09:59:25 | 显示全部楼层
帮你顶,我也不清楚,希望高手指教
发表于 2012-12-11 19:36:04 | 显示全部楼层
楼主,我也碰到这种问题了,不知道是什么原因。请问楼主现在知道是怎么回事了吗?能否告知一下,谢谢啦
