查看: 3638|回复: 1
fluent和CHEMKIN 耦合问题
发表于 2009-3-3 22:58:30 | 显示全部楼层 |阅读模式
耦合fluent 和chemkin的时候,kinetics-log提示以下内容,好像是license 问题,请问怎么解决:
KINetics(TM) Module
Version 2.1.1; Build Date: May 3, 2006
Copyright(c) 1997-2006 Reaction Design.  All rights reserved.
File Formats Compatible with CHEMKIN(R) 4.0.3 Libraries
Begin KINetics pre-processing of Gas-phase chemistry mechanism
End KINetics pre-processing of Gas-phase chemistry mechanism
Begin initializing KINetics Gas-phase internal storage
ERROR: could not get a license
Flexlm error report:
Invalid (inconsistent) license key.
The license key and data for the feature do not match.
This usually happens when a license file has been altered.
Feature:       FLUENT_KINETICS
License path:  d:\Program Files\Reaction\licenses\chemkin.lic;d:\Program -
    Files\Reaction\licenses\reaction.lic
FLEXnet Licensing error:-8,523
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
发表于 2009-9-29 21:48:23 | 显示全部楼层
回复 1# zpgreatwall2 的帖子
读入网格以后 通过File ——import   ——chemkin mechanism  输入化学反应动力学文件和数据库文件 就不会出现上边的问题
我用的是Fluent6.3, 你可以试试
