查看: 6999|回复: 5
安装Gambit 2.3.16 时一定要先安装EXCEED9.0吗?
发表于 2009-3-13 22:46:25 | 显示全部楼层 |阅读模式
我是个FLUENT的入门用户,请问专家安装Gambit 2.3.16 时一定要先安装EXCEED9.0吗?
 楼主| 发表于 2009-3-13 22:49:41 | 显示全部楼层
Gambit 2.3.16的 license为什么无效?
我安装Gambit 2.3.16后,启动软件,总是有这样的提示,是为什么?我有license阿!
Locating Exceed installation ...
gambit failed in locating Exceed installation on your system.
Please try to start Exceed manually before you run gambit.
Starting D:\gambit\gambit2.3.16\ntx86\gambit.exe -device open -id default_id2176 -new  ...
*** Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature:       gambit
Server name:   ysl
License path:  D:\gambit\license\ntx86\..\license.dat
FLEXlm error:  -15,10.  System Error: 10061 "WinSock: Connection refused"
available at "www.macrovision.com".
Feature:       gambit-addon
Server name:   ysl
FATAL ERROR: Could not obtain valid license authorization.
Total of 0.01 cpu second(s), 101784 maximum memory.
 楼主| 发表于 2009-3-13 22:50:04 | 显示全部楼层
Feature:       gambit
Server name:   ysl
Server name:   ysl
发表于 2009-3-14 11:46:29 | 显示全部楼层
exceed一定要装,但是有可能不是exceed的问题,可能是license没安装好。
发表于 2009-3-15 10:17:24 | 显示全部楼层
不一定哦,装一个较小的Xmanager也可以
发表于 2009-4-1 17:22:22 | 显示全部楼层
装Fluent6.2遇到的问题
我的是Fluent6.2的,装ExceedV10的时候老是说请在其他时间完成的提示,怎么回事呢,请高人指点啊,我QQ号591784689
