查看: 4583|回复: 5
安装fluent出问题了,,请教如何解决啊
发表于 2009-3-17 16:53:36 | 显示全部楼层 |阅读模式
Welcome to Fluent 6.3.26
     Copyright 2006 Fluent Inc.
     All Rights Reserved
Loading "C:\Fluent.Inc\fluent6.3.26\lib\fl_s1119.dmp"
Done.
Cannot find license file
The license files (or server network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Feature:       fluent
Filename:      C:\Fluent.Inc\license
tx86\..\license.dat
License path:  C:\Fluent.Inc\license
tx86\..\license.dat
FLEXlm error:  -1,359.  System Error: 2 "No such file or directory"
available at "www.macrovision.com".
Hit return to exit.
发表于 2009-3-17 17:15:47 | 显示全部楼层
要把License文件拷到\Fluent.Inc\license和\Fluent.Inc\lib里,LZ试试
 楼主| 发表于 2009-3-17 18:14:28 | 显示全部楼层
     All Rights Reserved
Done.
Server node is down or not responding
See the system adminstrator about starting the server, or
make sure the you're referring to the right host (see LM_LICENSE_FILE)
Feature:       fluent
Hostname:      122
tx86\..\license.dat
FLEXlm error:  -96,7.  System Error: 11001 "WinSock: Host not found (HOST_NOT_FOUND)"
Hit return to exit.
发表于 2009-3-17 18:30:28 | 显示全部楼层
你要在你的电脑里改一下端口,并拷贝许可文件。
发表于 2009-3-18 20:20:10 | 显示全部楼层
试回答
把license文件拷贝到:Fluent.Inc\license\licmsgs.dir,应该就可以了。
发表于 2009-4-7 09:09:45 | 显示全部楼层
把license文件拷贝到:Fluent.Inc\license 下替换原license.dat就ok 了
