查看: 2864|回复: 2
Post-doc position available at City Univeristy of Hong Kong
发表于 2009-3-17 22:05:52 | 显示全部楼层 |阅读模式
A post-doc position is sought for a project on modeling two-phase flow in one
of the following projetcs:
(1) in indoor environments or
(2) in ventilation duct.
The research area is about the development of new RANS
modeling for solving the concentration of pollutants in one of the two
scenarios mentioned above. Initial
appointment, including competitive fringe benefits, will be for 12 months and
renewable to another 12 months, subject to satisfactory performance and
availability of funding.
Applicants should have a PhD (or equivalent) in mechanical engineering,
aerospace or environmental engineering or the equivalent with experience in
computational fluid dynamics.
The ideal candidate should have the following qualifications
- strong background in computational fluid mechanics
- C++/MPI programming experience
Another post-doc is sought for measuring aerosol/pollutant dispersion. Please
send your CV to the address shown below. The applicant must familiar with
surface catalyst.
Application procedure:
If interested, please send a CV, a PDF copy of the representative publication
and the name of two referees (along with their contact details) to
Dr. Alvin Lai, Associate Professor
Department of Building and Construction
City University of Hong Kong
http://www.personal.cityu.edu.hk/~alvinlai/
Email:
alvinlai@cityu.edu.hk
 楼主| 发表于 2009-3-17 22:06:40 | 显示全部楼层
It is posted on behalf of Prof. Alvin Lai. If you are interested in this position, please follow the application procedure and contact Dr. Lai directly. I will not be able to check any message on this site.
 楼主| 发表于 2009-3-17 22:07:07 | 显示全部楼层
Hi, all, please help post this message to your university's BBS. Thanks you.
