查看: 3157|回复: 0
Star-CD4.06中通过posdat.f取某个单元流场参数值的方法
发表于 2009-5-8 09:07:03 | 显示全部楼层 |阅读模式
STARCD4.06与STARCD3.X系列相比,由于求解器的改变,计算中的数据结构发生了巨大的变化,因此posdat.f的使用方法也发生了很大的改变。近来对STARCD4.06的posdat.f做了点研究,发出来跟大家共享一下:
下面是给定四个单元编号(prostar), 按步取出二维流场中u,v,p的小例子。其中比较特别一点的地方是采用了一段小代码实现prostar单元编号到star单元编号的转换,因为posdat.f是直接对STAR求解器中间存储数据的读取,所以必须进行转换。
哪位高手如果发现有什么问题,欢迎指出,共同探讨。
c*************************************************************************
      subroutine posdat(level)
c     Post-process data
C*************************************************************************
C--------------------------------------------------------------------------*
C     STAR-CD VERSION 4.06.000
      USE allmod
      IMPLICIT NONE
      INCLUDE 'std.inc'
c
c     Argument variables
      INTEGER level
C
C     This subroutine enables the user to output data and is called
C     at the beginning and at the end of each iteration/time step,
C     i.e.
C          if (level.eq.1) then
c.>          called at the beginning of iteration/time step
C          else if (level.eq.2) then
c.>          called at the end of iteration/time step
C          end if
C          Any user code which is not enclosed in the IF condition will
C          be executed for both calls
C
C     Note: 1. File units available to the users for opening their own
C              files are from 84 to 89. Users may write to unit 6 or 60
C              if they want to see their output on the terminal or
C              the run file.
C           2. All variables passed to this routine use STAR cell
C              numbering, which is different from pro-STAR cell numbers.
C              pro-STAR cell number can be obtained from a STAR cell
C              number ICSTAR by ICPROSTAR=ICLMAP(ICSTAR)
c      Local variables
       INTEGER nd,nset,i,j,k,icprostar
       INTEGER moni(4)                              c-定义数组,存储4个prostar单元编号
       INTEGER monis(4)                            c-定义数组,存储对应的star单元编号
       DATA moni/111,112,113,114/          c -给定4个prostar单元编号
       DATA monis/0,0,0,0/
c&&&
       if (intflg(128).eq.0) then
CC--- Find out cell id of star from cell id of prostar,找出与prostar单元编号对应的star单元编号
       call cset(cs,0,ND_ALL,NSD_ALL,INTERNAL)
          do nset=1, cs%no
            do i=cs%ns(nset),cs%ne(nset)
              icprostar=iclmap(i)
                do j=1,4
                  if(icprostar.eq.moni(j))then
                   monis(j)=i
                   write(6,*)'monitor',j,'icprostar=',icprostar,
     &          'icstar=',monis(j)
                   write(60,*)'monitor',j,'icprostar=',icprostar,
                    exit
                  end if
                end do
            end do
          end do
CC---------------------------------------------------
C        first iteration, so open files, 第一步,打开三个文件,用于存储u,v,p
         if (.not.parrun) then
           open(85,file='MonitU',form='formatted',status='unknown')
           open(86,file='MonitV',form='formatted',status='unknown')
           open(87,file='MonitP',form='formatted',status='unknown')
         end if
         intflg(128)=1
c         else files already open
       end if
c
       if (level.eq.1) return
c
CC--获取u,v,p,并写入文件。
         write(85,800) iter,(u(1,monis(k)),k=1,4)
         write(86,800) iter,(u(2,monis(k)),k=1,4)
         write(87,800) iter,(pabs(monis(k)),k=1,4)
       end if
  800  format(i8,1p,5e11.3)
      end
C
