查看: 5404|回复: 2
ansys fluent12 zai vista下不能进行双核并行计算
发表于 2009-5-26 15:21:06 | 显示全部楼层 |阅读模式
显示的信息如下:
Host spawning Node 0 on machine "username"(ntx86)
999999:mpt_get_dot_address:warning:username->127.0.0.1.Check your system network configuration!
You can press CTRL+C to stop the startup process!
WARNING:No cached password or password provided.
        use '-pass' or '-cache' to provide password
mpid:Cannot connect to mpirun(0.0.0.0,49178):Unknown error
connect_mpirum failed
 楼主| 发表于 2009-5-29 19:34:45 | 显示全部楼层
已解决,是没联网
发表于 2010-8-3 19:52:35 | 显示全部楼层
我导入过程中有个warning时这个~怎么回事?但是导入好像没受影响的
