查看: 13971|回复: 43
original cfd fluent tutorial with source code files
发表于 2009-6-2 14:41:28 | 显示全部楼层 |阅读模式
file names:
Tutorial 1. Introduction to Using FLUENT: Fluid Flow and Heat Transfer in a Mixing Elbow
Tutorial 2. Modeling Periodic Flow and Heat Transfer
Tutorial 3. Modeling External Compressible Flow
Tutorial 4. Modeling Unsteady Compressible Flow
Tutorial 5. Modeling Radiation and Natural Convection
Tutorial 6. Using a Non-Conformal Mesh
Tutorial 7. Modeling Flow Through Porous Media
Tutorial 8. Using a Single Rotating Reference Frame
Tutorial 9. Using Multiple Rotating Reference Frames
Tutorial 10. Using the Mixing Plane Model
Tutorial 11. Using Sliding Meshes
Tutorial 12. Using Dynamic Meshes
Tutorial 13. Modeling Species Transport and Gaseous Combustion
Tutorial 14. Using the Non-Premixed Combustion Model
Tutorial 15. Modeling Surface Chemistry
Tutorial 16. Modeling Evaporating Liquid Spray
Tutorial 17. Using the VOF Model
Tutorial 18. Modeling Cavitation
Tutorial 19. Using the Mixture and Eulerian Multiphase Models
Tutorial 20. Using the Eulerian Multiphase Model for Granular Flow
Tutorial 21. Modeling Solidification
Tutorial 22. Using the Eulerian Granular Multiphase Model with Heat Transfer
Tutorial 23. Postprocessing
Tutorial 24. Turbo Postprocessing
Tutorial 25. Parallel Processing
download:
http://rapidshare.com/files/142219394/tut01-Introduction-.rar
http://rapidshare.com/files/142219295/introduction.zip
http://rapidshare.com/files/1422 ... odic_flow_heat-.rar
http://rapidshare.com/files/142219415/periodic_flow_heat.zip
http://rapidshare.com/files/1422 ... l_compressible-.pdf
http://rapidshare.com/files/142219648/external_compressible.zip
http://rapidshare.com/files/1422 ... dy_compressible.rar
http://rapidshare.com/files/142220530/unsteady_compressible.zip
http://rapidshare.com/files/1422 ... ural_convection.pdf
http://rapidshare.com/files/1422 ... ural_convection.zip
http://rapidshare.com/files/1422 ... _conformal_mesh.pdf
http://rapidshare.com/files/142220963/non_conformal_mesh.zip
http://rapidshare.com/files/142221174/tut07-porous.pdf
http://rapidshare.com/files/142221143/porous.zip
http://rapidshare.com/files/142221221/tut08-single_rotating.pdf
http://rapidshare.com/files/142221205/single_rotating.zip
http://rapidshare.com/files/142221288/tut09-multiple_rotating.pdf
http://rapidshare.com/files/142221254/multiple_rotating.zip
http://rapidshare.com/files/142221706/tut10-mixing_plane.pdf
http://rapidshare.com/files/142221612/mixing_plane.zip
http://rapidshare.com/files/142221865/tut11-sliding_mesh.pdf
http://rapidshare.com/files/142221832/sliding_mesh.zip
http://rapidshare.com/files/142222081/tut12-dynamic_mesh.pdf
http://rapidshare.com/files/142222053/dynamic_mesh.zip
http://rapidshare.com/files/142222226/tut13-species_transport.pdf
http://rapidshare.com/files/142222133/species_transport.zip
http://rapidshare.com/files/1422 ... ixed_combustion.pdf
http://rapidshare.com/files/142222393/non_premix_combustion.zip
http://rapidshare.com/files/142222834/tut15-surface_chem.pdf
http://rapidshare.com/files/142222803/surface_chem.zip
http://rapidshare.com/files/142223097/tut16-evaporate_liquid.pdf
http://rapidshare.com/files/146212742/tut17-vof.rar
http://rapidshare.com/files/142536237/vof.zip
http://rapidshare.com/files/142223029/evaporate_liquid.zip
http://rapidshare.com/files/142223143/tut18-cavitation.pdf
http://rapidshare.com/files/142223105/cavitation.zip
http://rapidshare.com/files/1422 ... rian_multiphase.pdf
http://rapidshare.com/files/142223924/mix_eulerian_multiphase.zip
http://rapidshare.com/files/1422 ... iphase_granular.pdf
http://rapidshare.com/files/1422 ... iphase_granular.zip
http://rapidshare.com/files/142224145/tut21-solidification.pdf
http://rapidshare.com/files/142224090/solidification.zip
http://rapidshare.com/files/1422 ... n_granular_heat.pdf
http://rapidshare.com/files/142224248/eulerian_granular_heat.zip
http://rapidshare.com/files/142224613/tut23-postprocess.pdf
http://rapidshare.com/files/142224385/postprocess.zip
http://rapidshare.com/files/142225654/tut24-turbo_postprocess.pdf
http://rapidshare.com/files/142225512/turbo_postprocess.zip
http://rapidshare.com/files/142225869/tut25-parallel_process.pdf
http://rapidshare.com/files/142225811/parallel_process.zip
发表于 2009-6-2 14:43:58 | 显示全部楼层
回复 1# 上善若水 的帖子
一登陆就看到这么好东西,谢谢楼主了
发表于 2009-6-2 15:03:36 | 显示全部楼层
回复 2# qxtxdy 的帖子
怎么一点速度都没有?不知楼主可否把第2 ,8 9 10 11,23 24教程和zip文件发给我,小弟不胜感谢。我的邮箱是qxggtg@126.com
发表于 2009-6-5 09:18:09 | 显示全部楼层
怎么回事,文件全都被损坏了?
发表于 2009-6-8 08:51:23 | 显示全部楼层
楼主快给大家更新吧
发表于 2009-6-8 09:13:38 | 显示全部楼层
回复 5# haohaoxuexi123 的帖子
得想办法把http://rapidshare.com的账号搞到
 楼主| 发表于 2009-6-8 09:17:54 | 显示全部楼层
Tutorial 1[pdf]
 楼主| 发表于 2009-6-8 09:23:33 | 显示全部楼层
Tutorial 1-1(共30)
tutorial 1.part01.rar
341.8 KB, 下载次数: 779
 楼主| 发表于 2009-6-8 09:24:27 | 显示全部楼层
Tutorial 1-2
tutorial 1.part02.rar
341.8 KB, 下载次数: 756
 楼主| 发表于 2009-6-8 09:25:04 | 显示全部楼层
Tutorial 1-3
tutorial 1.part03.rar
341.8 KB, 下载次数: 716
 楼主| 发表于 2009-6-8 09:25:26 | 显示全部楼层
Tutorial 1-4
tutorial 1.part04.rar
341.8 KB, 下载次数: 677
 楼主| 发表于 2009-6-8 09:25:48 | 显示全部楼层
Tutorial 1-5
tutorial 1.part05.rar
341.8 KB, 下载次数: 660
 楼主| 发表于 2009-6-8 09:26:57 | 显示全部楼层
抱歉,有流量限制。明天再上传。
 楼主| 发表于 2009-6-9 13:38:25 | 显示全部楼层
Tutorial 1-6
tutorial 1.part06.rar
341.8 KB, 下载次数: 636
 楼主| 发表于 2009-6-9 13:39:00 | 显示全部楼层
Tutorial 1-7
tutorial 1.part07.rar
341.8 KB, 下载次数: 648
