查看: 1800|回复: 2
求救:报错原因求解
发表于 2009-6-23 10:51:21 | 显示全部楼层 |阅读模式
我最近在做一个流体分析,可是在执行Initialize的时候总是报错,报错代码如下:
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Body Force, size 67565544, t 2, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Body Force Corr, size 67565544, t 2, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Pressure, size 44778340, t 7, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Mass Flux, size 44778340, t 7, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc f_a0, size 44778340, t 7, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc f_a1, size 44778340, t 7, myid 1000000.
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
Error Object: ()
我开始学Flunet时间不长,不明白意思,那位明白人能帮我解释一下,万分感谢!!
发表于 2009-6-23 10:57:00 | 显示全部楼层
内存不够,换个机器试试
发表于 2009-6-23 11:36:58 | 显示全部楼层
内存不够,加个内存试试?
