查看: 4691|回复: 15
求助_涡流函数法
发表于 2009-6-28 16:48:12 | 显示全部楼层 |阅读模式
小弟诚求涡流函数形式求解N-S方程的程序,欲计算圆柱绕流问题,与我现在的方法进行比较
发表于 2009-7-2 14:55:39 | 显示全部楼层
p1
program cavity_sv
c
c This program is to be used only under the
c stipulations of the licensing agreement.
c----------------------------------------
c--------------------------------------------------
c  Steady flow in a two-dimension cavity driven
c  by a moving lid, computed by the
c  stream function / vorticity formulation
c
c  The cavity extends over 0<x<Lx, 0<y<Ly
c
c  SYMBOLS:
c  -------
c
c  Lx, Ly:    cavity size
c  Nx, Ny:    Number of divisions in the x and y directions
c
c  X,Y:  grid-point coordinates
c  U,V:  velocity components
c  S:    streamfunction (psi)
c  O:         vorticity (omega)
c
      Implicit Double Precision (a-h,o-z)
      Double Precision Lx,Ly
      Dimension X(129,129),Y(129,129)
      Dimension U(129,129),V(129,129)
      Dimension S(129,129),Snew(129,129)
      Dimension O(129,129),Onew(129,129)
      Dimension Source(129,129)
      Real vector(5,2)  ! to draw vectors
c----------
c constants
c----------
      pi  = 3.14159265358 D0
      pi4 = 4.0D0*pi
      pis = pi**2
c-----------
c parameters
c-----------
c     write (6,*)
c     write (6,*) " Choose the data input mode"
c     write (6,*)
c     write (6,*) " Enter 0 to quit"
c     write (6,*) "       1 to read data from file: cvt_sv.dat"
c     write (6,*) "       2 to type in data"
c     write (6,*) " ------------------------------------------"
c     read  (5,*) Ienrd
      Ienrd = 1
      If(Ienrd.eq.0) Go to 99
      If(Ienrd.eq.2) then
      write (6,*) " Please enter the lid velocity"
      write (6,*) " -----------------------------"
      read  (5,*) UUlid
      write (6,*) " Please enter cavity dimensions Lx and Ly "
      write (6,*) " ---------------------------------------- "
      read  (5,*) Lx,Ly
      write (6,*) " Enter discretization levels Nx and Ny "
      write (6,*) " --------------------------------------"
      read  (5,*) Nx,Ny
      write (6,*) " Enter the viscosity "
      write (6,*) " ------------------- "
      read  (5,*) visc
      write (6,*) " Enter the density "
      write (6,*) " ----------------- "
      read  (5,*) rho
      write (6,*) " Enter the relaxation parameters "
      write (6,*) " relax(psi), relax(vort)   "
      write (6,*)
      write (6,*) " Optimal values are about 0.10, 0.10 "
      write (6,*) " ----------------------------------- "
      read  (5,*) rel_psi,rel_vort
      write (6,*) " How many local iterations "
      write (6,*) " for the stream function and the vorticity ? "
      write (6,*)
      write (6,*) " Better to choose less than 3 "
      write (6,*) " ---------------------------- "
      read  (5,*) Niter
      write (6,*) " How many global iterations before pausing ? "
      write (6,*) " ------------------------------------------ "
      read  (5,*) Niterg
      write (6,*) " Enter the inital guess for the vorticity "
      write (6,*) " at the grid points"
      write (6,*) " ------------------------------------ "
      read  (5,*) Vort_init
      write (6,*) " See transient streamfunction on screen ? "
      write (6,*)
      write (6,*) " Enter 0 for no; 1 for yes"
      write (6,*) " -------------------------"
      read  (5,*) IseeS
      write (6,*)
      write (6,*) " See transient vorticity on screen ? "
      write (6,*)
      read  (5,*) IseeV
c----------
       Else
c----------
        open (1,file="cvt_sv.dat")
         read (1,*) UUlid
         read (1,*)
         read (1,*) Lx,Ly
         read (1,*) Nx,Ny
         read (1,*)
         read (1,*) visc
         read (1,*) rho
         read (1,*)
         read (1,*) rel_psi,rel_vort
         read (1,*) Niter
         read (1,*) Niterg
         read (1,*) Vort_init
         read (1,*)
         read (1,*) IseeS
         read (1,*) IseeV
        close (1)
c-----------
      End If
c-----------
c----------
c constants
c----------
      Null  = 0
      None  = 1
      Ntwo  = 2
      Nfive = 5
      zero = 0.0D0
c--------
c prepare
c--------
      Nx1 = Nx+1
      Ny1 = Ny+1
      Dx = Lx/(Nx1-1.0D0)
      Dy = Ly/(Ny1-1.0D0)
      Dx2 = 2.0D0*Dx
      Dy2 = 2.0D0*Dy
      Dxs  = Dx**2
      Dys  = Dy**2
      beta = Dxs/Dys
      rnu = visc/rho  ! kinematic viscosity
c Initialize vorticity and stream function
      Do I=1,Nx1
       Do J=1,Ny1
         X(I,J) = (I-1.0D0)*Dx
         Y(I,J) = (J-1.0D0)*Dy
         S(I,J) =   0.0D0
         O(I,J) = - Vort_init
       End Do
      End Do
c Beginning of global iterations
      Kter = 0       ! global iterations counter
      Jter = 0       ! batch iterations counter
98   Continue
c Iterate on Poisson equation
c for the stream function
c with Dirichlet boundary conditions
      Iter = 0      ! stream function iteration counter
  93  Continue
      Iter = Iter + 1
c Jacobi updating of the stream function
c at the interior nodes
      Errp = 0.0    ! pointwise error register
      Do J=2,Ny
       Do I=2,Nx
       res =        S(I+1,J)+S(I-1,J)-2.0*S(I,J)
     +      + beta*(S(I,J+1)+S(I,J-1)-2.0*S(I,J))
     +      +      Dx**2 * O(I,J)
       Snew(I,J) = S(I,J) + rel_psi * res
       If(abs(res).gt.ERRP) Errp = abs(res)
       End Do
      End Do
c-------
c update
c-------
      Do J=2,Ny
       Do I=2,Nx
        S(I,J) = Snew(I,J)
       End Do
      End Do
      If(Iter.le.Niter) Go to 93
c-----------------
c printing session
c-----------------
      If(IseeS.eq.1) then
        write (6,*)
        write (6,*) " STREAM FUNCTION "
        write (6,*)
        Do j=1,Ny+1
         write (6,101) (S(i,j),i=1,Nx+1)
        End Do
      End If
c Compute the vorticity
c at the internal grid points
c     Do I=2,Nx
c      Do J=2,Ny
c       O(I,J) = - (S(I+1,J)-2.0*S(I,J)+S(I-1,J))/Dxs
c    +           - (S(I,J+1)-2.0*S(I,J)+S(I,J-1))/Dys
c      End Do
c     End Do
c Compute the vorticity at boundary grid points
c using the velocity boundary conditions
c
c Lower-order boundary conditions are commented out
c---
c top and bottom walls
c---
      Do I=2,Nx
c       O(I,1  ) = 2.0*(S(I,1)  -S(I,2)) /Dys
c       O(I,Ny1) = 2.0*(S(I,Ny1)-S(I,Ny))/Dys - 2.0*UUlid/Dys
        O(I,1  ) = (7.0*S(I,  1)-8.0*S(I,2) +S(I,  3))/(2.0*Dys)
        O(I,Ny1) = (7.0*S(I,Ny1)-8.0*S(I,Ny)+S(I,Ny-1))/(2.0*Dys)
     +            - 3.0*UUlid/Dy
      End Do
发表于 2009-7-2 14:56:05 | 显示全部楼层
p2
c---
c left and right walls
c---
      Do J=2,Ny
c       O(1  ,J) = 2.0*(S(1,J)    - S(2,J) )/Dxs
c       O(Nx1,J) = 2.0*(S(Nx+1,J) - S(Nx,J))/Dxs
        O(1  ,J) = (7.0*S(1  ,J)-8.0*S(2,J) +S(3,   J))/(2.0*Dxs)
        O(Nx1,J) = (7.0*S(Nx1,J)-8.0*S(Nx,J)+S(Nx-1,J))/(2.0*Dxs)
      End Do
c Compute the velocity at the grid points
c         by central differences
      Do J=2,Ny
       Do I=2,Nx
        U(I,J) =   (S(I,J+1)-S(I,J-1))/Dy2
        V(I,J) = - (S(I+1,J)-S(I-1,J))/Dx2
       End Do
      End Do
c Iterate on Poisson's equation for the vorticity
c
c The source term is the rhs of equation (13.1.8)
c of Pozrikidis (1997)
      Iter = 0
  92  Continue
      Iter = Iter + 1
c---
c Jacobi updating
c---
      ErrO = 0.0D0    ! error register
      Do J=2,Ny
       Do I=2,Nx
       source(I,J) =  U(I,J)*(O(I+1,J)-O(I-1,J))/Dx2
     +              + V(I,J)*(O(I,J+1)-O(I,J-1))/Dy2
       source(I,J) = source(I,J)/rnu
       res =        O(I+1,J)+O(I-1,J)-2.0*O(I,J)
     +       + beta*(O(I,J+1)+O(I,J-1)-2.0*O(I,J))
     +       -      Dxs * source(I,J)
       Onew(I,J) = O(I,J) + rel_vort * res
       If(abs(res).GT.ErrO) ErrO = abs(res)
       End Do
      End Do
c---
c replace
c---
      Do J=2,Ny
       Do I=2,Nx
        O(I,J) = Onew(I,J)
       End Do
      End Do
      If(Iter.le.Niter) Go to 92
c-----------------
c printing session
c-----------------
      If(IseeV.eq.1) then
        write (6,*)
        write (6,*) " Vorticity"
        write (6,*)
        Do J=1,Ny1
         write (6,101) (O(I,J),I=1,Nx1)
        End Do
      End If
      write (6,103) Kter,ERRP,ERRO
c-----------------
c advance counters
c-----------------
      Jter = Jter + 1
      Kter = Kter + 1
      If(Jter.le.Niterg) Go to 98
c End of batch iterations
      Jter = 1
      write (6,*)
      write (6,*) " One more set of global iterations ?"
      write (6,*)
      write (6,*) " Enter 0 for No, 1 for YES "
      write (6,*) " ---------------------------"
      read  (5,*) more
      If(more.ne.0) Go to 98
c End of global iterations
   99 Continue
c print the final stream function
      open (4,file="cvt_sv.str")
        write (4,*) Nx,Ny
        write (4,*) Dx,Dy
        Do j=1,Ny1
         write (4,101) (S(i,j),i=1,Nx1)
        End Do
        write (4,*)
        write (4,400) UUlid
        write (4,401) Lx,Ly
        write (4,402) Nx,Ny
        write (4,403) visc
        write (4,404) rho
        write (4,405) rel_psi
        write (4,406) rel_vort
        write (4,407) Niter
        write (4,408) Niterg
      close (4)
c print the final vorticity field
      open (4,file="cvt_sv.vort")
        write (4,*) Nx,Ny
        write (4,*) Dx,Dy
        Do j=1,Ny1
         write (4,101) (O(i,j),i=1,Nx1)
        End Do
        write (4,*)
        write (4,400) UUlid
        write (4,401) Lx,Ly
        write (4,402) Nx,Ny
        write (4,403) visc
        write (4,404) rho
        write (4,407) Niter
      close (4)
c print the final upper wall vorticity distribution
c along with the local solution for Stokes flow
      open (4,file="cvt_sv.vortw")
        write (6,*) " upper wall vorticity distribution"
        write (6,*)
        j=Ny1
        write (4,*) Nx1
        Do i=1,Nx1
         xh = (i-1.0D0)/Nx
         Ocorner = 0.0D0
         If(xh.ne.0) then
          Ocorner = - pi4/(pis-4.0D0) * UUlid/xh
         End If
         write (4,102) i,xh,O(i,j),Ocorner
         write (6,102) i,xh,O(i,j),Ocorner
        End Do
        write (4,*) Null
      close (4)
c Plot velocity vectors
c reduced by maximum magnitude
c for visualization
      open (4,file="cvt_sv.vel")
c---
c print cavity walls
c---
      write (4,104) Nfive
      write (4,104) None,None,zero,zero
      write (4,104) None,None,Lx  ,zero
      write (4,104) None,None,Lx  ,Ly
      write (4,104) None,None,zero,Ly
c-----
c for visualization
c----
      Umax = 0.0D0
      Do J=2,Ny
       Do I=2,Nx
        Umag = U(I,J)**2+V(I,J)**2
        If(Umag.gt.Umax) Umax = Umag
       End Do
      End Do
      Umax = Dsqrt(Umax)
      write (6,*) " Maximum velocity: ", Umax
      Do J=2,Ny
       Do I=2,Nx
        x1 = X(I,J)
        y1 = Y(I,J)
        Darx = 0.10*U(I,J)/Umax
        Dary = 0.10*V(I,J)/Umax
        call draw_arrow_2d
     +    (x1,y1
     +    ,Darx,Dary
     +    ,vector
        write (4,104) Nfive
        Do l=1,5
         write (4,104) J,I,vector(l,1),vector(l,2)
        End Do
       End Do
      End Do
      write (4,104) Null
      write (4,*)
      write (4,400) UUlid
      write (4,401) Lx,Ly
      write (4,402) Nx,Ny
      write (4,403) visc
      write (4,404) rho
      write (4,407) Niter
      close (4)
c-----
c Done
c-----
  100 Format (2(1x,f15.10))
  101 Format (200(1x,f10.5))
  102 Format (1X,I4,3(1x,f15.8))
  103 Format ("Iter: ",i4,", Max error in psi and omega ",
     +       2(1x,f15.10))
  104 Format (2(1x,i2),20(1x,f10.5))
400  Format (1x," UUlid       ",F10.5)
401  Format (1x," Lx,Ly       ",F10.5,1x,F10.5)
402  Format (1x," Nx,Ny       ",I3,1x,I3)
403  Format (1x," Viscosity   ",f10.8)
404  Format (1x," Density     ",f10.8)
405  Format (1x," rel_psi     ",f10.8)
406  Format (1x," rel_vort    ",f10.8)
407  Format (1x," Niter       ",I5)
408  Format (1x," Niterg      ",I5)
      Stop
      End
发表于 2009-7-2 14:56:55 | 显示全部楼层
dat
1.0  UUlid
1.0 0.5     Lx, Ly
32 16 64 32 128 64 128 128        Nx, Ny
0.01         viscosity
1.00         density
0.1 0.1 0.20 0.20    relaxation factors for psi and omega
05 10 03 02        number of inner iterations
100          number of global batch iterations
0.0          initial vorticity
0            IseeS
0            IseeV
 楼主| 发表于 2009-7-2 21:52:09 | 显示全部楼层
回复 4# liuhuafeifei 的帖子
非常感谢,要是能有圆柱绕流的例子就更好了
发表于 2009-7-3 08:30:41 | 显示全部楼层
兄弟,你也太懒了,涡量流函数法是CFD中比较简单的一种,写程序没几句。
直交坐标改柱坐标,很直接,一天估计就搞定,不就是要考虑r吗
发表于 2009-7-3 08:39:18 | 显示全部楼层
哦,不是柱坐标,估计需要适体坐标。还又可能涉及多块,看你怎么作了。
有点难度。参考一下。
不过我以前有适体的单块涡量流函数的程序,回去找找,好多年了。
发表于 2009-7-3 08:45:14 | 显示全部楼层
真的有那么复杂吗?
发表于 2009-7-3 08:47:43 | 显示全部楼层
两种途径,一是直接找参考文献就是了,圆柱绕流涡量流函数算的,这会少么?
          二是自己写一段
发表于 2009-7-3 10:31:10 | 显示全部楼层
re
先想想,常规的坐标系能处理吗(直角,柱,球)?
如要分析分离等现象,单块结构化网格可以吗?
发表于 2009-7-3 10:57:28 | 显示全部楼层
随便看了一篇,是单块直交坐标,有限差分,圆柱边界处采用阶梯网格,陶老师的红皮书上介绍过,还算简单,将上面程序修改一下,细心一点即可。哎,很古老的方法,近些年都搞非结构的,差点忘了。对付这个问题可以。
另一种是多重坐标,太繁,不推荐。
 楼主| 发表于 2009-7-3 20:22:43 | 显示全部楼层
回复 11# liuhuafeifei 的帖子
我看到的文献多是用极坐标,这样可以描述圆柱的曲线边界,然后经坐标转换,变成直角坐标,利用差分法求解。
    其实,问题是这样的,我发现两篇文献用涡流函数形式的N-S方程所得时均升力为正值,而其它方法结果为负值。其所模拟流动Re=50-150,属于层流状态,涡已经脱离。
    我用LBM计算,时均升力也是负值,顾想找个涡流函数形式程序,比较一下。
发表于 2009-7-4 11:51:46 | 显示全部楼层
这个肯定地说,没有意义
 楼主| 发表于 2009-7-4 20:33:21 | 显示全部楼层
回复 13# onesupeng 的帖子
onesupeng君为什么说这没有意义呢,请指教。
我是想看看究竟是边界条件,阻塞比,网格粗细等引起不同学者的结果不一样,还是其它什么原因引起的,按理说升力均值的方向在特定Re下应该是一定的。
发表于 2009-7-4 21:45:01 | 显示全部楼层
我说的就是,你说得上面讲要研究的这些,是没有意义的。按理说,应该是零,所谓正负由于数值误差和不同初值条件引起的而已。所有你提到的,肯定有非常多的人做过,高兴多调研一下就好了。
类似网格什么的,任何一种算法的基本功而已,不足以当个话题研究什么的
